Old Apr 28, 2002, 11:48 PM
dshuen is offline
Find More Posts by dshuen
Canada
Joined Aug 2000
Throttle hold in governor mode
I am flying with the Hacker B40-8L,the Schulze 45He ESC and the JR 8103DT. I have my Schulze set in governer mode and plugged to the AUX2 channel; controlled by the pitch trim knob.
How do you use the throttle hold to shut down the motor? The Schulze manual said to use a progrm mix to tie the throttle hold switch to the governor channel to shut down the motor. I need more detail on the exact setting.
Don
dshuen is offline Find More Posts by dshuen
Discussion throttle pitch curves in governor mode NZ_Nitro Mini Helis 3 May 19, 2006 10:58 AM
why do people run 100 percent throttle in governor mode??? mattijs321 Micro Helis 6 Aug 30, 2005 08:24 PM
48-3P / 15XL Throttle Curves in Normal Mode K.C. Electric Heli Talk 1 Jul 20, 2003 04:36 PM
Problems in governor mode with my Phoenix 45 JohnM Castle Creations 0 Jun 22, 2003 04:10 PM
Phoenix-10 in governor mode skirtz Electric Heli Talk 3 Sep 25, 2002 08:46 PM
