Old May 24, 2009, 05:49 AM
osgood232 is offline
Find More Posts by osgood232
Joined May 2007
my heli
Its strange, precision helis post inspired me to fly the heli again and post about the mods I have made!
Well after 3 years heres what I have had to do to get the heli robust and reliable. I am actually an electronic engineer by trade so my personality helps with these things although ive never once studied areodynamics or mechanics.
Ive also never owned a heli so this is the only heli I have learnt with (appart from a sim)
Heres a list of my changes
Buy the hardened blades so they DONT SNAP
Changed the tail rotor blade guard for wire so it DOESNT SNAP
Spend a long time making that carbon fibre landing gear so they DONT SNAP
Put an extra tube around the swashplate assembly to provide stability
Changed the battery velcro for a strong rubber band
Angled the tail motor for increased stability
but a carbon fibre rod between the flybar paddles so they DONT SNAP
Used string to strengthen joints such as landing gear attatchment
changed the connector for some that I had lying around so I can buy more cells
use 200mAh
With this, lots and lots and lots of patients and money on replacement parts (before I figured out I had to start hardening things) I now get a good, crashable, reliable flight!
It probably isnt quite as bad as it sounds as I still cant fly well as I see myself as a beginner and really still into my rc cars but all the same it would have been nice if some of these parts wore more robust for the customer...
Also special thanks to spookycopters page, maybe precision heli can link to this as its bee an absoutly great help!
osgood232 is offline Find More Posts by osgood232
Old May 24, 2009, 06:01 AM
Joined May 2007
my heli
opps, didnt mean to post twice...
Old May 24, 2009, 10:10 AM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
http://www.rcgroups.com/forums/showthread.php?t=1053615
village_idiot is offline Find More Posts by village_idiot
Old Jun 02, 2009, 12:17 PM
Precision Heli is offline
Find More Posts by Precision Heli
www.precisionheli.com
Joined Jun 2007
Thanks for your post please let me know I can help you in anyway.
Sounds like you have a very old model, because most of the areas you have been talking about have been hardened, thickened or completely replaced to increase strength and reliability.
If you are still a beginner try out new weighted cradle this makes a world of differance.
Precision Heli is offline Find More Posts by Precision Heli
Old Jun 23, 2009, 04:15 PM
Rello is offline
Find More Posts by Rello
Joined Mar 2007
Originally Posted by Precision Heli
Since we have taken over the company we have gone to great efforts to figure out this problem that comes and goes. With plenty of testing we have confirm this is caused by warped blades or out of balance rotor blades. Since this helicopter is so small any slight warp or balance problem shows so we came up with a new teeter type flybar that solves even the most warped blades guaranteed. The part number is M080
Thank you,
Hi,
is there a picture? I did not see any on your page!
...my way to stabilize the baby was to reduce the lift of the blades (by precisely cutting the down edges). Then I could fly with more head speed and it made the V2 almost flyable. But still it bounces around pretty much. I would like to see the new Stabilized Cradle to understand what you mean...
also: do you have ratio recommendations for the motor/main gear?
I could imaging that for different weight levels there should be some recommended setting in order not to overstress the motor
Rello is offline Find More Posts by Rello
Old Jun 23, 2009, 08:19 PM
zaksdad is offline
Find More Posts by zaksdad
zaksdad
USA, TX, DeSoto
Joined Apr 2006
I have a v2.5 and I'm having problems keeping the swash plate from riding up and down on the shaft, any ideas?
zaksdad is offline Find More Posts by zaksdad
Old Jun 23, 2009, 10:09 PM
lazer155 is offline
Find More Posts by lazer155
lazer155's Avatar
Phoenix, Arizona
Joined Jan 2009
How does this heli compare to the 4#3q?
lazer155 is offline Find More Posts by lazer155
Old Aug 25, 2009, 01:51 PM
Joined Jun 2007
You can put two small o-rings above the swashplate to hold it down, but if everything is level you should not need this. Work from the tp of the head down to the servos making sure everything is nice and level horizontally.
Thank you
Old Aug 25, 2009, 01:53 PM
Joined Jun 2007
Originally Posted by Rello
Hi,
There is no picture of the part as of yet I should have something up soon. Cutting the blades is not going to solve your problem you need the new cradle.
Use the 108 tooth and 10 tooth this is the best overall.
Thank you,
Old Sep 01, 2009, 02:26 PM
Rello is offline
Joined Mar 2007
Hi,
I ordered the new cradles - and wouldn´t have done if I would have seen the pics. You added quite a lot of additional weight on 2 more "paddels".
this amount of weight will for sure avoid the wobbling - but it it will make the heli so much more slow in the air...
Cutting the blades or using the 4#3 ones is the best suggestion yet in my opinion. combined with a brushless the much higher headspeed is the only way to get the baby really smooth flying in my opinion (after trying for 3 years now)...
This tread has all the details...
http://www.rcgroups.com/forums/showt...0#post12666395
Old Nov 14, 2010, 07:39 PM
Tag1260 is offline
Find More Posts by Tag1260
USA, Eastern Ohio
Joined Jan 2005
Is Precision Heli gone now? Any source for parts for these?
Tag1260 is offline Find More Posts by Tag1260
Old Nov 15, 2010, 01:07 AM
topgearuk is offline
Find More Posts by topgearuk
topgearuk's Avatar
United Kingdom, London
Joined Dec 2003
I hope so!! Biggest waste of money I've ever had.... I've been flying helis for 20 years and yet I couldn't get this to fly for more then 20 seconds!!
I've still got my heli with a load of spares that I would gladly part with for a small some of$$ if your interested? You may have better luck with it then me!!
topgearuk is offline Find More Posts by topgearuk
Old Nov 15, 2010, 08:28 AM
Meshuggah is offline
Find More Posts by Meshuggah
Nothing flies like a Pitts
Meshuggah's Avatar
Stockholm, Sweden
Joined Aug 2006
i probably spent more on my Micron than my Trex-250 and 4g3 together...
Meshuggah is offline Find More Posts by Meshuggah
Help! How can i get a micron palm size heli in china? chflyer Scratchbuilt Indoor and Micro Models 1 Apr 30, 2007 10:13 AM
GWS r-4p mod for palm size heli devmonkey Scratchbuilt Indoor and Micro Models 8 Dec 05, 2003 02:25 PM
~~~ Free Palm-size Heli Plans ~~~ Mario Scratchbuilt Indoor and Micro Models 9 Dec 04, 2003 03:05 PM
***Palm Size *** Heli Forum Option Mario Micro Helis 27 Oct 26, 2003 10:56 PM
How do you make a palm size heli out of a micro rc car? Flamy Micro Helis 10 Oct 19, 2003 01:32 PM
