Old Jul 30, 2005, 02:52 AM
Noto is offline
Find More Posts by Noto
RC Dans
Round Rock, Tx
Joined Jun 2005
Servo signal
This probably is a stupid question to you guys but what is sent over the servo wires from the Rx?
What in kinda trying to figure out is I want to have a switch that when you hit full throttle it makes a connection between 2 electronic points... Or when at full turn of a servo.
I hope this makes sense its almost 3 am and im tried heh
Noto is offline Find More Posts by Noto
Old Jul 30, 2005, 05:59 AM
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
Noto,
The industry standard servo signal is a positive pulse from about 2V up to the battery voltage. This pulse length is between 1ms and 2ms and is repeated approximately every 20ms. The neutral point is normally 1.5ms.
I designed a simple CMOS circuit for switching things on and off from an RX channel, I'll dig it out and post it.
Andy.
AndyOne is offline Find More Posts by AndyOne
Old Jul 30, 2005, 06:29 AM
AndyOne is offline
Oxford Panic
AndyOne's Avatar
Joined Feb 2003
Noto,
See attached circuit. The 200k pot adjusts the switching point. The circuit only works in one direction but with the addition of an inverter between IC1 pin1 and the gate of T3 it can switch in the other sense..
This circuit was edited down from an on-board-glow switch so the componet references don't follow in sequence.
Andy.
Old Jul 30, 2005, 09:49 AM
Noto is offline
RC Dans
Round Rock, Tx
Joined Jun 2005
Andy, thanks for the info will see if I can get this working now.
-Daniel
Discussion 4 in 1 servo signal pin billyzelsnack Micro Helis 3 Aug 08, 2006 10:05 PM
Discussion servo signal to 0-5k ohm signal Bob K DIY Electronics 5 Apr 05, 2006 02:15 PM
PWM to servo signal conversion? mcross DIY Electronics 13 Jul 05, 2005 08:48 PM
FS - 2M glider, Rx, (2)servo signal filter/boost extensions Skid Aircraft - Electric - Airplanes (FS/W) 6 Oct 09, 2003 03:53 PM
