Old Jul 28, 2005, 09:04 PM
Al P is offline
Find More Posts by Al P
small electrics r BIG FUN
Iowa
Joined Aug 2000
Anything better than a Himax 2025-4200 in a Formosa ?
I'm having a great time with my Formosa, powered by a Himax 2025-4200 4.3:1, 9x7.5 APC and 3s TP 2100. Around 16 amps static, will inside loop at 3 clicks below half throttle. Easily flies 20 minutes.
Been thinking I might try an outrunner next, something quieter but equally capable performance-wise. Would like to use the plastic cowling too, but perhaps that won't be possible with an outrunner and the stock stick mount location ?
Al P is offline Find More Posts by Al P
Old Jul 29, 2005, 07:10 PM
KillerAir is offline
Find More Posts by KillerAir
Plane dodger
KillerAir's Avatar
Stratford Sikorsky, Connecticut, United States
Joined Dec 2001
Hacker 20-20l same prop or go bigger 10x5.5e
Axi 2212-26
Hyperion
torque 20
Outrunners anyway.
Killer
KillerAir is offline Find More Posts by KillerAir
Old Jul 29, 2005, 07:26 PM
Al P is offline
Iowa
Joined Aug 2000
Axi 2212-26
Hyperion
torque 20
Outrunners anyway.
Killer
Thanks, Killer. Will these motors mount to the stock motor stick, and will I be able to use the stock cowling ?
Old Jul 29, 2005, 11:20 PM
Plane dodger
KillerAir's Avatar
Joined Dec 2001
Stevens Aeromodels has laser cut mounts as well as other for these motors. Maybe problem with off set a little.
Old Jul 29, 2005, 11:59 PM
guapoman2000 is offline
Find More Posts by guapoman2000
Account closed
Joined Oct 2002
Yes, a RAZOR RZ-400 Brushless in the EPS-300C/350C gearbox with "C" gearing (5.33:1 ratio) and swinging the APC "Slow Flyer" 9 X 7.5 Propeller.
http://www.rcgroups.com/forums/showthread.php?t=269342
guapoman2000 is offline Find More Posts by guapoman2000
Old Jul 30, 2005, 12:28 AM
sledge29 is offline
Find More Posts by sledge29
Joined Mar 2004
try the fiegao 2045-4800 in a himax gear box 6.6-1 gear and 11/4.7 prop or 5.4 wit a 10/6 apc
want lotsa thrust slap a 12/4.7 on with a 6.6 gear and use a 2100 or better lipoly 10 to 15c discharge rate i use poly quest 2200s and can get 42 oz of thrust with the 12/4.7 prop however i have to build in extra throw on the ailerons to handle the tork roll with a 12/4.7 apc
want speed go with a 5400kv himax motor and 9/6 prop on a 6.6 gear 2100mah bat or better , you could even go 5400 kv with the 9.6 on a 5.4 gear with a 2600 poly quest long pack and at least a 30 amp speed controller especialy if you plan on useing larger props.
fiegao motors can be purchased at parkflyermotors .com they are hard to come by especialy the 2045-4800 dunno why .. but any way the fegao motors are the same size as all the himax 2025 series motors however there kv is a tad higher making for a bit more power with slight amp draw increase however not enough to realy cause a problem if you use 2100 packs or better ive had the best results with the 2200s made by poly quest packs. check the specks on them at bishops power products..
if you realy want to go all out buy a lener motor from bishops and a cobri gear box
peace!
sledge29 is offline Find More Posts by sledge29
Yippee! Himax 2025/4200 in a Zagi ? djindivik Flying Wings 26 Jun 15, 2005 04:54 AM
Question Himax 2025-4200 in an Alpha Mig? jhamm Electric Ducted Fan Jet Talk 0 Jan 25, 2005 04:41 PM
Himax 2025-4200 in gws "d" box q? Air plane Power Systems 4 Dec 05, 2004 11:13 AM
Question Himax 2025-4200 in GWS Gearbox orangepeel Power Systems 25 May 15, 2004 04:10 PM
Question Himax 2025-4200 in GWS Gearbox orangepeel Parkflyers 3 May 13, 2004 10:19 AM
