Old Jul 27, 2005, 07:02 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
How to reverse a servo?
Hi
I"m putting together a Bob-E-Cat EDF and for the flaps to work right, one of the flap servos needs to be reversed. Because there are two servos i cant just use the reverse on the TX. One of the guys at work says i can jsut switch 2 of the servo wires (like reversing a brushed motor). Can i do that??
Or do i have to shell out for a reverse module thingy?
ash
ashdec87 is offline Find More Posts by ashdec87
Old Jul 27, 2005, 07:12 PM
dgoslee is offline
Find More Posts by dgoslee
dgoslee's Avatar
Seaford, DE
Joined Jan 2002
You need to reverse the wires on the motor AND reverse the outer wires on the feedback potentiometer (pot). If you don't reverse the pot, it will go to the end of the travel and jam and smoke.
Dan
dgoslee is offline Find More Posts by dgoslee
Old Jul 27, 2005, 07:35 PM
Popsflyer is offline
Find More Posts by Popsflyer
Oldie but goodie
Popsflyer's Avatar
United States, CA, Orange
Joined Jun 2003
If the plane is already built, electronics installed and linkages hooked up. You can buy a servo reverser that plugs inline with that particular servo.
Popsflyer is offline Find More Posts by Popsflyer
Old Jul 27, 2005, 09:22 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
Ya everyhting is all hooked up.
I was jsut hoping i could do it without buying a reversing thing. Oh well, no biggie.
thanks
ash
Old Jul 27, 2005, 10:04 PM
emnm79 is offline
Find More Posts by emnm79
Yakkin' it up!
emnm79's Avatar
Kennett Square, PA
Joined May 2005
Hmm, I think you can do it to larger digital servos via a programmer, not sure though... I need to do the same for my funtana's elevator servos
emnm79 is offline Find More Posts by emnm79
Old Jul 27, 2005, 10:47 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
ya you can, but i'm using an hs-85mg...not quite a programmable digi servo
ash
Old Jul 28, 2005, 06:17 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
What kind of Tx do you have? Most 6-channel and up support two flap servos.
..a
Old Jul 28, 2005, 08:52 AM
Cubber is offline
Find More Posts by Cubber
Naturally altered
Joined Feb 2005
Am i missing something? Now why do you need to reverse one of the servos? Possibly, there is physical limitation the way the plane is designed or built but....
With a Y adapter, two servos will work in unison if linkages are attached to the same side of the horn (both on the left side of the servo wheel, or both on the right), or opposite if linkages are attached to opposite sides of the servo wheel (typical aileron linkage for a single servo, or even two for that matter).
A computer radio should be able to handle two flap servos, either from built-in feature or by using a programmable mix.
If all the above fails, then you are left with the servo-reverser thingy option.
Cubber is offline Find More Posts by Cubber
Old Jul 29, 2005, 10:03 AM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
I"m using an Eclipse 7.
The way the servos are laid out, both flap servos face inward and both ail servos face outward. So the servos work in opposite directions. And sicne i'm using a y-cable i cant just reverse the direction of the servo through the TX.
Ash
Old Jul 29, 2005, 12:31 PM
Oldie but goodie
Popsflyer's Avatar
Joined Jun 2003
If you're using an Eclipse 7 and your receiver has enough channels, you can plug the servos into different channels and use one of the pre-set or custom mixes availible on the E-7. This will allow you individually program the normal direction the servo turns.
Otherwise break down and pay the $15 for a servo mixer.
Old Jul 29, 2005, 12:37 PM
Montag DP is offline
Find More Posts by Montag DP
Sink stinks
Montag DP's Avatar
Joined Apr 2005
Ash
So you're using two flap servos and two aileron servos? Couldn't you just move the pushrod to the other side of one of the flap servo control arms, so that both flaps move in the same direction?
Sorry if I'm not understanding your setup correctly.
Montag DP is offline Find More Posts by Montag DP
Old Jul 29, 2005, 01:27 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
I use a Y-harness with a servo reverser built-in..
They are available.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Jul 29, 2005, 02:00 PM
markmm is offline
Find More Posts by markmm
Joined Jul 2005
Just hook up the pushrod to the other side of the servo arm. One side moves one way, while the other side moves the other way. Regardless of the orientation of the servo itself, what side it's connected on will determine which way the pushrod moves.
Of course if there is some kind of physical limitation (i.e. - you can't attach the pushrod to the other side because something is in the way, or the pushrod cannot be routed to that side, etc.), then you'd have to find an alternative method.
markmm is offline Find More Posts by markmm
Old Jul 29, 2005, 02:07 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I asked which Tx as the best answer is to use dual flap servo programming, if your Tx supports it - which it appears it does. That way, you don't have to reverse anything, and you get independant sub-trims, which you do not have with a mixer/reverser/y-harness setup.
..a
Old Jul 29, 2005, 03:55 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
ok thanks for all of your input.
To answer one of the questions. It's got a sheeted wing, so i trimmed the servo arm so that one arm protrudes through the bottom of the wing.
I'll check the programming on the TX. Although i think the 2 flap servo option is only in glider mode. I guess if nothing else works, i can use the y adapter with the servo reverse. My only problem with that is the extension is LONG and my leads are already very long.
Thanks again
ash
stupid newbee question - how to reverse a servo? garfield Foamies (Kits) 7 Mar 28, 2009 10:39 AM
How do I reverse a servo? RandyK1 Radios 9 Oct 09, 2003 08:32 PM
how to reverse rotation with a brushless motor bpu6999 Power Systems 2 Mar 08, 2002 06:06 PM
how do i reverse the servo and esc on my old radio? Sonic Electric Plane Talk 7 Jul 08, 2001 11:55 PM
