Old Jul 27, 2005, 05:30 PM
JBrant is offline
Find More Posts by JBrant
Joined Jul 2005
Hitec HS-55 servo
Is there a difference between the HS-55 and the HS-55 Economy or the Feather? Is there a difference between the black and blue case? ( I know, the color is different.) I think my first electric order should be from a company that can work with me on the phone to be sure all of the gear matches and is correct for each plane.
Jim
JBrant is offline Find More Posts by JBrant
Old Jul 27, 2005, 05:39 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
Jim
wow, go the serious approach about vendor selection!
...the servo specs are usually available on the retailer sites. Weight, torque, etc. Just pick the servo for the use. I'd use the HS-55 class servos on all the mid size planes... 30-40 inch wingspan. Any micro servo for smaller. And larger as needed. It's just one of those fuzzy things. Some planes will put larger strains on the servos, like racers and aerobats, so may shop for higher torque. Some servos seem to fail for no reason, others seem to really go above the call of duty.
theKM is offline Find More Posts by theKM
ScrewDriver Size - Hitec HS-55 Servo's mag1 Parkflyers 9 Jun 03, 2005 08:39 AM
Hitec HS-55 Servo arms - Where can I find some? mrebman Parkflyers 6 Jan 24, 2005 07:08 PM
Hitec HS-55 Servo Price Reduction aeropal Radios 4 Jun 01, 2004 02:43 PM
FS: GWS Naro 6Ch Rx with Ch19 X-Tal/ Hitec HS-55 Servo/ GWS Pico Servos-Free Shipping LESLIEx317537 Aircraft - Electric - Airplanes (FS/W) 3 Apr 27, 2004 11:14 PM
FS: Hitec HS 55 servo Nik-rc Aircraft - Electric - Airplanes (FS/W) 10 Jun 18, 2003 03:49 PM
