Old Jun 25, 2001, 07:58 PM
Magna is offline
Find More Posts by Magna
Malaysia
Joined Jun 2001
Before buying the Stick, some questions...
Hi all
I need some advices with the Lite Stick. As Iím totally new and also from Malaysia, this type of flying is very rare and will have zero LHS support. After much reading, I decided to buy this lite stick but I have some questions before I mail order it from US:
How durable is the motor?
Should I get the hop up motor?
Can I use up to 8 cell?
I believe I need extra prop,right?
What is the maximum capacity/weight of batteries can I use before I exceed the Stick strength ie breakage/folding?
I only have standard receiver(Futaba 127), is this too heavy? Have no other choice as the price of another feather receiver is way off my budget.
I do have the Hitec HS55 or HS81MG. The 81MG is heavier but it is metal gear so very unlikely to break the servo gear. I have read many beginner broke like dozens of servo gear.
What I wanted to do is that if I were make my order, I want to purchase some of the replacement parts at the same time so that I can sustain my fun longer rather than having it break and wait for ages to purchase the parts, not to mentioned another round of S&H.
I saw some site selling 2 stick for the $50 which is a good deal. It can be my back up parts. But I rather purchase some extra parts ie maybe gears or the motor etc.
Any helps much appreciated!
Magna is offline Find More Posts by Magna
Old Jun 25, 2001, 08:11 PM
VWtechie is offline
Find More Posts by VWtechie
Columbia, MO USA
Joined Feb 2001
1. As long as you use a 6 or 7 cell pack the stock DX-A is very durable.
2. You should order a carbon brush motor to keep on hand until your first one burns out.
3. 8 cells make this plane fly very well but will greatly reduce motor life, probably by at least half.
4. You should get 3 or 4 extra props. They're very cheap and tend to break on your first few "landings"
5. I've flown with 700mAh NiCd's but the wings were very stressed. Even with a carbon fiber spar they were showing a lot of flex.
6. The Futaba 127 is OK as long as you remove the case.
7. I would use the HS55's . Extra gear sets for them are only about US$7.
Remember to keep this plane <u>Lite</u>. The lighter it is, the better it'll fly. An extra motor/gearbox is highly recommended as they tend to shatter if they strike concrete.
You should also look at Doug Binder's DuskStik. It's superior to the LiteStik in almost every way but costs about $50. It uses the same gear but performs much better. Check it out here www.duskstik.com and see what else I had to say about it here http://litestick.rcplanet.com/articl...tikreview.html .
Good luck and welcome to the hobby!
Brad
<a href="http://litestick.rcplanet.com">The LiteStick Forum</a>
VWtechie is offline Find More Posts by VWtechie
Old Jun 25, 2001, 08:15 PM
mrebman is offline
Find More Posts by mrebman
Cincinnati, Ohio USA
Joined Nov 2000
The Futaba #R127DF Receiver is probably too big, I have one. I would get a GWS Pico Pack, it costs like $80.00 & comes with a Micro #R4P FM receiver, ESC, Battery & 2 sub-micro pico servos, can't beat the price for $80.00 & it's specifically designed for the Litestick/Picostick. I am building my Litestick right now as I write this, I'm waiting for the glue to dry. I called my Local Hobby Shop & he will have my Pico Pack & Crystal ready for me on Wednesday. All you need is some sort of FM Transmitter to use with this receiver. Remember, weight is your enemy when working with small planes like this. I am told you need at least 7-cell packs with the Litestick, The Pico pack comes with a 6-cell, you may need to add a cell, an 8-cell pack is gonna be hard on the little motor but I have heard guys doing it. let me know how yours goes & I'll post the progress on mine.
mrebman is offline Find More Posts by mrebman
Old Jun 25, 2001, 11:55 PM
Magna is offline
Malaysia
Joined Jun 2001
Hi Brad
At $47, is the Duststick come complete or do I need to get that motor,prop, gear etc?
Mrebman,
I will weight a few more questions before I take the plunge. Your progress is certainly something I look forward to.
Old Jun 26, 2001, 01:29 AM
VWtechie is offline
Columbia, MO USA
Joined Feb 2001
Magna,
You'll still need to buy a motor/gearbox if you go with the DuskStik. It probably better to get a LiteStik and then upgrade to the DuskStik when you're ready for better performance. On the other hand, the DuskStik is <u>much</u> stronger and easier to fly than the LiteStik.
Brad
Question Some Slow Stick upgrade questions... kingair42 Parkflyers 16 Jan 31, 2006 05:35 AM
thinking of buying and building some GB motors and have questions Catkicker Power Systems 6 Jul 11, 2004 07:01 AM
Some Questions About Ultra Stick 40 Conversion Don Leitz Sport Planes 4 May 24, 2004 10:11 PM
another 010 powered Slow Stick takes to the skies..have some questions too uglyplane Parkflyers 5 Jan 30, 2003 01:48 AM
Trying out Motocalc, some questions... Looooeeee! Electric Plane Talk 2 Jun 12, 2001 01:10 PM
