Old Jul 24, 2005, 04:51 PM
emachineshop.com is offline
Find More Posts by emachineshop.com
Joined May 2005
Cool
Ouncey - 1 oz micro electric
Motor & Lipo - from Wattage Flyer
Span: 18"
PCB - JMP Combo
Fuse - CF
Tail - V
Prop - 6"
Gear - 4:1
Xmitter - HiTech
Actuators - flush mount
Wing material - Balsa
Airfoil - Flat
Air time - ~5 min
See tips and CAD drawing at link below.
More pix and contruction details here: http://www.emachineshop.com/projects/micro-electric.htm
emachineshop.com is offline Find More Posts by emachineshop.com
Old Jul 24, 2005, 05:00 PM
Pete P is offline
Find More Posts by Pete P
Micro Flyer, Big Poster
Pete P's Avatar
Joined Feb 2005
That's a nice craft! I like the blue.
I dont think that one is powered by a pager motor, IE is disqualified in this sticky (Working Pager Powered Models).....
Pete P is offline Find More Posts by Pete P
Old Jul 24, 2005, 06:57 PM
Joined May 2005
Ouncey
Thanks. The motor is 10x15mm - I thought that was pager class but perhaps I am wrong. If so, where should I post it?
Old Jul 24, 2005, 08:26 PM
Pete P is offline
Pete P's Avatar
Joined Feb 2005
You give it it's own thread! :-)
BTW Pager-class were originally the 6mm and 4mm variety coreless motors, and later came to include the 7mm coreless variety and the cored 6mm motors which have the same outer appearence of the 6mm coreless motors.
90% or so of the WPPM entries are 15g (1/2oz) or less. I dont know who for certain, but Peter Smart and myself hold the fattest WPPM entries (mine is about 50g, I just went and measured the parts I have left from it).
Old Jul 24, 2005, 08:55 PM
Joined May 2005
Ouncey
OK - But now I see no UI for deleting posts :-(
Old Oct 09, 2008, 02:10 PM
KC55555 is offline
Find More Posts by KC55555
Joined Feb 2007
I noticed in a 'closed thread' that some are using 2mmX6mm and 2mmX7mm pagermotors. Any info on manufacturer or distributors? Thanks,Keith
KC55555 is offline Find More Posts by KC55555
Old Oct 09, 2008, 08:26 PM
spainman is offline
Find More Posts by spainman
Aachen, Germany
Joined Jun 2007
Wow... thats really small! Can you please give a link to that thread...?
spainman is offline Find More Posts by spainman
Old Oct 09, 2008, 09:48 PM
Pete P is offline
Pete P's Avatar
Joined Feb 2005
No such motors exist. Must be a typo. There are motors which are 6mm and 7mm in diameter, but are around or longer than 1cm.
Old Oct 09, 2008, 09:54 PM
KC55555 is offline
Joined Feb 2007
I have a 3.2mm diameter one from Shicoh and I heard that they once made a 2.8,so I thought maybe there was a source again.
Old Oct 10, 2008, 05:03 AM
spainman is offline
Aachen, Germany
Joined Jun 2007
Well I have smaller motors than the dimensions you mentioned myselft (4mm diameter) so while it is a HUGE step down to 2mm diameter I assume that it may not be a typo.
Again: Do you have a link to that dead thread you mentioned. I would like to read it myself. Thank you.
Old Oct 10, 2008, 08:17 AM
KC55555 is offline
Joined Feb 2007
Here is the link to that dead thread. First entry and third from bottom (Motors 2x6mm and 2x 7mm pager motor,respectively).:
http://www.rcgroups.com/forums/showt...=225017&page=8
Maybe they took a 3.2mm and stripped off the case.-Keith
Old Oct 10, 2008, 08:25 AM
spainman is offline
Aachen, Germany
Joined Jun 2007
Oh... ok. From my understanding the posts refer to using TWO 6mm and 7mm motors and not to motors with 2x6/2x7mm dimensions
Old Oct 10, 2008, 11:05 AM
all4smallrc is offline
Find More Posts by all4smallrc
Founder of the EDF20 club!
all4smallrc's Avatar
Minnesota
Joined Apr 2008
Yes, Shicoh made a 2.8mm pager. Here's the proof!
Shicoh 2.8mm Motor Test (0 min 42 sec)
all4smallrc is offline Find More Posts by all4smallrc
Old Oct 10, 2008, 03:04 PM
KC55555 is offline
Joined Feb 2007
Yeah,my source for the 3.2mm told me he wasn't sure if or when the 2.8mm would be available again.
Old Oct 10, 2008, 05:10 PM
Veteran is offline
Find More Posts by Veteran
Mc-Fly
Veteran's Avatar
Melbourne-Australia
Joined Mar 2008
The 3.2mm can be bought from Koichi here: http://translate.google.com.au/trans...%3Den%26sa%3DG
Koichi just got some new stock in so he should have quite a few available.
For international orders you must email him with the excel order form whic you can download from his site.
Ive scoured the web for the 2.8mm and theres only a few pages linking to 2.8mm Shicoh motors, none of which are useful to us. I think it was a limited production run anyway.
Theres a couple of builders here who will fill us in more on the 2.8mm shicoh
Veteran is offline Find More Posts by Veteran
Discussion Working Micro BL Powered Models Gordon Johnson Scratchbuilt Indoor and Micro Models 40 Mar 18, 2014 08:30 AM
Cool Working Pager Powered Models Graham Stabler Scratchbuilt Indoor and Micro Models 153 Jul 31, 2007 08:05 PM
Conversion of Rubber-Powered Models E-Challenged Scale Kit/Scratch Built 0 Nov 08, 2002 06:19 PM
Sterling C/L and/or rubber powered models Martin Hunter Parkflyers 13 May 10, 2002 12:39 PM
