Old Jul 25, 2005, 06:51 AM
neuroblade is offline
Find More Posts by neuroblade
neuroblade's Avatar
Naples, FL
Joined Jul 2005
Question
How long does it take to charge your LiPo?
Using my Esky charger lastnight it took two hours to charge my 11.1V 3 cell pack? I am using it with a 12V 1500mah AC power supply from Radio Shack. Is this normal charge time?
neuroblade
neuroblade is offline Find More Posts by neuroblade
Old Jul 25, 2005, 06:54 AM
tbeine is offline
Find More Posts by tbeine
Tonyt
Joined Jan 2005
Depend on the rate at which your charging!! What size is the pack?
tbeine is offline Find More Posts by tbeine
Old Jul 25, 2005, 07:07 AM
neuroblade's Avatar
Naples, FL
Joined Jul 2005
Just the standard 3 cell it came with. I don't have the option of changing the rate on the charger.
Old Jul 25, 2005, 07:10 AM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
what size is the battery? The problem might be your weak PS...
dacaur is offline Find More Posts by dacaur
Old Jul 25, 2005, 07:39 AM
neuroblade's Avatar
Naples, FL
Joined Jul 2005
11.1 V, 1000 mAh
Old Jul 25, 2005, 07:59 AM
Tassie stu is offline
Find More Posts by Tassie stu
Tasmania
Joined Jul 2005
neuroblade
It's a good chance your battery is a 1000 mah. Now depending on the amp out put on your P/S it could take a while to charge. Try this: Time the amount of time it takes to charge off a charged car battery. I use a car battery charger with a 10amp 12v power supply in the charger itself and it takes around 20mins.
Reguards Tassie stu
Tassie stu is offline Find More Posts by Tassie stu
Old Jul 25, 2005, 08:09 AM
tbeine is offline
Tonyt
Joined Jan 2005
I wouldn't think they would give you a 1000mah batt and a charger that does 1500mah this would be very dangerous. More then likely you are just getting a trickle charge whatís sounds like half of the batt 1c rating this would come out to about two hours.
Every battery that I have if charged at itís 1c rating will take about an hour. You have no chose in the matter with a wall charger. Get youíre self a decent charger that handle lipos this will make life a lot easier.
Old Jul 25, 2005, 08:21 AM
neuroblade's Avatar
Naples, FL
Joined Jul 2005
Any suggestions on a charger? Plantraco? Is the charger I'm using bad for my pack, or shortening the life of it?
Old Jul 25, 2005, 09:05 AM
Minimole is offline
Find More Posts by Minimole
Sponsered By My Wallet!
Minimole's Avatar
Colwyn Bay, North Wales, UK
Joined May 2004
How much can you spend?
Do you want to be ablke to charge other types of batteries, like Nimh, Hicad and so on?
Duane
Minimole is offline Find More Posts by Minimole
Old Jul 25, 2005, 09:11 AM
neuroblade's Avatar
Naples, FL
Joined Jul 2005
Duane,
This will be strictly for LiPo's. $100 is my maximum amount right now.
Chuck
Old Jul 25, 2005, 09:16 AM
Minimole is offline
Minimole's Avatar
Joined May 2004
Im not too sure, but I just got a Triton, and am really pleased with it.
They go on eBay, brand new for about $120, so you might be able to find a good deal, or get one second hadn of eBay for under $100.
This might not be the bect charger for you, as it does most battery types, and you are obviously paying mpore for that, maybe someone can recommend a Lipo only charger that is good...?
Duane
Old Jul 25, 2005, 09:49 AM
WreckRman2 is offline
Find More Posts by WreckRman2
WreckRman2's Avatar
United States, FL, Apopka
Joined Mar 2002
Just by looking at your picture your charger has an putput of 0.8 amps. This means if you are charging a 800mah pack it would take approx 1 hour. If you are charging a 1500mah pack it might take 2 hours.
If you had a charger that you could set the output to 1C of the battery rating and if it charges at that 1C for the entire charge they will charge in approx 1 hour.
The Trition I had never charged at what I set it at... and everytime it took almost 2 hours to charge a pack. The Astro 109 on the other hand always charges at what you set it to and no matter how small or larger the pack it charges in approx 1 hour.
WreckRman2 is offline Find More Posts by WreckRman2
Old Jul 25, 2005, 09:56 AM
Cobra is offline
Find More Posts by Cobra
MaxiR, Sniper
Lansdale, PA, USA
Joined Dec 2004
I like my Vision Peak Ultra. It even has AC input, so you won't need a transformer to run it. You'll have to make a cable for your lipo connector. I just cut off the tamiya dc connector supplied and put a deans on mine.
It's lower cost than the Triton and does AC, two big plusses. It doesn't have temp sensor input though, which the triton can do.
It's about $90 new. Todd's models used to have it, and it looks like horizon hobby has it also.
http://www.horizonhobby.com/Search/D...&OverallCatID=
(Make sure you look at the Ultra, not the 2. Only the Ultra does lipo as well as nimh and nicad.)
Cobra is offline Find More Posts by Cobra
Old Jul 25, 2005, 10:09 AM
WreckRman2's Avatar
Joined Mar 2002
Duane,
Chuck
Without doubt you need an Astro 109.
Old Jul 25, 2005, 10:58 AM
dankers is offline
Find More Posts by dankers
OpenPilot
dankers's Avatar
Melbourne, Australia
Joined Apr 2004
We had a guy at our indoor meet charging at 2C, should have seen the area around his charger clear after people found out....
dankers is offline Find More Posts by dankers
Discussion how long does it take my li-po wall charger to charge a pack full?? john-rcg Batteries and Chargers 11 Aug 20, 2006 04:20 PM
How long does it take to charge up your micros? Ni-Mh? Lipo? gotime242 Micro Helis 6 Oct 20, 2005 08:44 AM
How long does it take you to type www.ezonemag.com in your browser? e-sailpilot86 Life, The Universe, and Politics 14 Sep 08, 2005 02:04 PM
How long should it take to charge a lipo ? livinma1 Batteries and Chargers 25 Oct 06, 2004 01:45 PM
How long does it take to build T-52? bobw@halcyon.com Foamies (Kits) 6 Sep 24, 2001 11:17 AM
