View Poll Results: Bungee or Hand launch ???
Bungee 40 32.52%
Hand Launch 83 67.48%
Voters: 123. You may not vote on this poll
Old Jul 24, 2005, 03:34 PM
Chris T is offline
Find More Posts by Chris T
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Build Log
L-39 Albatros, 1:25 Scale, Microfan, CD-ROM
Hi all,
finally I am posting my current project. It is a tiny L-39 Albatros. It is built from balsa, glas and some carbon. And it is scale!
Specs:
Wingspan: 38cm (15'')
Weight: 145g (incl. battery)
EDF: WEMOTEC Microfan 50mm modified (shroud has been removed), pictures will follow...
Inlet / Outlet Diameter: 35mm
Motor: CD-ROM, 6 stator poles, 8 magnet poles (stock), 10 windings (I believe), turns up to 33000rpm, then gets out of sync (it's the controller limit I think). New motor with 6 magnets and standard stator in progress for higher rpm...
Battery: 3s Li-Poly 520mAh
Functions: flaperons, elevator, throttle, lights
To be discussed in this thread:
Modelling techniques
Optimization of fan, motor and ducting for top speed
Comparison with other nano scale models and setups
Best launching strategy
Flight report
anything else?
Have fun, and don't hesitate to give me feedback...
Regards,
Chris T
Chris T is offline Find More Posts by Chris T
Old Jul 24, 2005, 06:10 PM
roccobro is offline
Find More Posts by roccobro
Watts your motivation
roccobro's Avatar
San Bernardino, CA
Joined Aug 2003
I like!
Justin
roccobro is offline Find More Posts by roccobro
Old Jul 24, 2005, 07:45 PM
FredN is offline
Find More Posts by FredN
Having Fun!!!
FredN's Avatar
Cary, North Carolina, United States
Joined Jun 2001
ME TOO!!
Fred
FredN is offline Find More Posts by FredN
Old Jul 24, 2005, 07:52 PM
kdk is offline
kdk
Find More Posts by kdk
kdk
NJ USA
Joined Mar 2005
Very nice job so far Chris, looks scale and great. I love this aircraft and I have about 30 miniutes flying one. I may have to get the plans from you and build one
kdk is offline Find More Posts by kdk
Old Jul 24, 2005, 10:08 PM
dapple63 is offline
Find More Posts by dapple63
dapple63's Avatar
Joined Jun 2005
It is beautiful. You're quite a craftsman. Yeah, I'd be interested in the launch technique. Looks to me as a solid, but VERY fast bird. Getting up to the best speed....bungee?
I see no cheater, and even with the nice-sized intakes I wonder if you're going to grab all the thrust you can get.
Do you have a static thrust number as mounted?
dapple63 is offline Find More Posts by dapple63
Old Jul 24, 2005, 11:21 PM
Robbie d is offline
Find More Posts by Robbie d
Crazy Cessna Owner
Robbie d's Avatar
Australia, SA, Windsor Gardens
Joined May 2001
What stator are you using for the rebuild?
On my EDF-50's in my A-10 im running a 17mm Stator with 10 turns of 26gauge wire with 6 magnets per motor. Thrust is in excess of 150g per motor drawing 5.5A each.
Robbie d is offline Find More Posts by Robbie d
Old Jul 25, 2005, 03:05 AM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Static Thrust
dapple63: static thrust as mounted is 70g at about 31500rpm. Power is around 60-70W (have to measure again). Static thrust goes up to 100g, when wing is removed -> big cheater hole at the bottom.
I intend to go up to 100W with new motor. Do you think cheater hole kills high speed performance?
There is still a gap between the rotor and the side wall as you can see in the photo (up to 2.5mm). That will be fixed and I expect thrust to go up more.
Static thrust seems to be low, but related to the total size of the plane and its weight, it is considerable. On the other side, a very high efflux velocity is created due to an outlet diameter of only 35mm and considering the slim aerodynamic shape, high top speeds are expected.
I wonder if I need the cheater hole at top speed. To my opinion it destroys more the aerodynamic than it helps the dynamic thrust. I will test it...
Inlet diameter is 35mm effective.
Old Jul 25, 2005, 04:30 AM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Motor Specs
Robbie d, stators of both motors are 20mm. I will use 5x5x1mm magnets for the rebuild. Motor is integrated inside the rotor of the fan... fan and motor weigh roughly 1oz. (30g).
Old Jul 25, 2005, 04:45 AM
clausxpf is offline
Find More Posts by clausxpf
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
I would go for 4 magnet poles... not 6... on a 6 pole stator.
Claus
clausxpf is offline Find More Posts by clausxpf
Old Jul 25, 2005, 05:50 AM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
3-View
Here is a nice 3-view...
Old Jul 25, 2005, 05:51 AM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Claus
clausxpf, the 6 magnets would be with a 9 pole stator...
Old Jul 25, 2005, 06:58 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
The I can follow you.
Claus
Old Jul 25, 2005, 09:53 AM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Modelling Technique
kdk, the 3-view is all you need to build it. I didn't use any other drawings. The body was built from 1mm balsa, that was bent over ribs. Then everything was coated with glas and in the end the ribs were removed using some brute force (didn't use so much glue here). So the duct was cleared. I think, this is a good method for prototyping (certainly not for mass production)...
Old Jul 25, 2005, 10:17 AM
Happy|Harry is offline
Find More Posts by Happy|Harry
veni,vidi, roto volubilis
Happy|Harry's Avatar
Aberdeen, Scotland
Joined Jul 2003
very nice work chris! , i hope you took construction photos as you built?
phil
Happy|Harry is offline Find More Posts by Happy|Harry
Old Jul 25, 2005, 10:34 AM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
...sorry Phil, no construction photos. But I will try to explain, how I did it...
... and I will show some close-ups so things get clear...
For Sale K&A Models L-39 Albatros w/scale wings... Racebelly Aircraft - Electric - Airplanes (FS/W) 3 May 31, 2005 03:08 PM
L-39 Albatross Power Slope Scale Jet neilo Aircraft - Sailplanes (FS/W) 2 Jul 24, 2003 01:17 AM
L-39 Albatros Pylon Racing Mark Nankivil Electric Ducted Fan Jet Talk 6 Jul 27, 2002 03:12 PM
K&A Models L-39 Albatros GlasairAllen Electric Ducted Fan Jet Talk 20 Nov 28, 2001 11:04 PM
K & A L-39 Albatros J Bergsmith Electric Ducted Fan Jet Talk 1 May 30, 2001 09:40 PM
