Old Jul 21, 2005, 08:14 PM
Chuck is offline
Find More Posts by Chuck
Balsa to the Wall
Chuck's Avatar
Deep in the East Texas Piney Woods
Joined Dec 2001
Question
So how do you balance the blades on a Honeybee 2/Blade?
After some minor repair, I'm sure these need balancing, but I don't have a clue. Can someone take me thru Helicopter Rotor Blade balancing 101?
Is there a balancing tool required?
Chuck
Chuck is offline Find More Posts by Chuck
Old Jul 21, 2005, 08:35 PM
uav51 is offline
Find More Posts by uav51
uav51's Avatar
MI
Joined Jan 2005
http://www.helihobby.com/html/balancing_blades.html
uav51 is offline Find More Posts by uav51
Old Jul 21, 2005, 11:12 PM
Project is offline
Find More Posts by Project
Joined Mar 2005
u can do what i did. Isnt 100 percent accurate but its pretty good for main blades. What i first do is check the CG of each blade with a razor. If the CG is good strap them to the heli. If not, balance them so CG is dead on. After that, spin the heli up. and make sure the blades are in track. If the blades are out of balance, some insane wobbling and stuff will occur. All u have to do is take some electrical tape, bout 1 inch, and smack it dead onto the cg point of one blade, if the wobble/vibration gets worse, ITS THE WRONG BLAAAAAAADDEE. and put the tape on the other blade. Keep trying with different lengths of tape, and eventually its balanced. Not as accurate as getting a digital scale and everything, but atleast itll fly decent
Project is offline Find More Posts by Project
Discussion How do you balance the blades on HB King V2? geoffrs Micro Helis 0 Jul 05, 2007 07:38 AM
Discussion How do you trim a micro heli and what makes a Blade CP so "hard" to fly? flyingace451 Micro Helis 24 Jun 23, 2006 11:15 AM
Discussion Landing skids keep falling off my blade cp, how do you keep them on? SteveCH Micro Helis 10 Mar 13, 2006 12:15 PM
How do you reduce resolution on photos so they can be posted Pat Daily Electric Plane Talk 9 May 27, 2004 10:01 PM
How do you Balance the blades on a hornet? JStory Electric Heli Talk 2 Oct 03, 2001 06:09 PM
