Old Jul 19, 2005, 03:19 PM
Dave Lauck is offline
Find More Posts by Dave Lauck
90% of the game is half mental
Dave Lauck's Avatar
Penn Valley California
Joined Jun 2004
Great Planes Mfg. ElectriFly Yak 55 3D Electric ARF
Remarkably durable!
Amazing aerobatic adventures can be as close as a your back yard with
the Yak 55 3D Electric ARF! It's flight-ready in no time, and a
wingspan of less than 3 feet makes it easy to transport. The
FlightFlex advantage is a real confidence-builder for aspiring
hotdoggers, and the quiet, yet powerful electric motor allows the Yak
55 to be flown anywhere where there are noise restrictions.
SPECIFICATIONS:
* Wingspan: 34.5 in (875mm)
* Wing Area: 352 sq in (22.7dmē)
* Weight: 14-16 oz (397-454g)
* Wing Loading: 5.7-6.5 oz/sq ft (17-20g/dmē)
* Length: 38 in (965mm)
* Includes: 370 ball bearing motor, 5:1 gear drive, prop, prop saver
* Requires: 4-channel radio w/4 micro servos, 6" and 8" servo
extensions, 25A ESC, Y-harness, 3-cell 1500mAh Lithium Polymer battery
pack
The entire airframe is made of built-up EPP (Expanded Polypropylene)
that's extremely lightweight and durable. Carbon fiber tubes are used
to strengthen the wing. The receiver, ESC and battery pack are easily
accessed under the zippered canopy inside the fuselage.
A low parts count and pre-applied trim scheme cut final assembly time
to just 2-3 hours. Low-temperature hot-melt glue or silicone-type
adhesives are ideal. Large control surfaces allow for incredible
aerobatics in small spaces, as well as extreme 3D maneuvers such as
harriers, blenders, inverted flat spins, torque rolls and more. Plus,
it flies easily in winds of 10-12 mph.
The wing is made of built-up EPP foam that's extremely sturdy and
bounces back easily from a mishap. Carbon fiber tubes are used to
Thanks to extremely durable FlightFlex construction, modelers can fly
with confidence * knowing that the Yak 55 will bounce back from
virtually any crash to fly again!
Ready for easy installation, the preassembled Speed Force* 370 dual
ball bearing brushed motor and 5:1 gear drive provide plentiful power.
GPMA1274 Yak 55 3D EP ARF
Retail $99.99
Street 79.99
DUE IN STOCK EARLY OCTOBER
http://www.hobbico.com/prelease369/
Dave Lauck is offline Find More Posts by Dave Lauck
Article Great Planes Yak 55 3D Foamie ARF Review Jim Walker Electric Plane Talk 31 May 28, 2011 11:22 AM
Great Planes Mfg. ElectriFly Silver Series Brushless ESCs Dave Lauck Product Announcements 0 Jun 27, 2005 02:02 PM
Yak 55 3D EP Arf Wing Halves Alignment Question ?? KillerWatt 3D Flying 3 Apr 24, 2005 05:10 AM
Hobbico - Great Planes Mfg. ElectriFly 1250mAh Li-Po Batteries Dave Lauck Product Announcements 0 Apr 18, 2005 05:11 PM
Great Planes Mfg. ElectriFly T-370 Gear Drive Systems w/ & w/o ESC AMCross Product Announcements 0 Apr 17, 2004 07:03 AM
