Old Jul 19, 2005, 12:52 PM
rcgreaves is offline
Find More Posts by rcgreaves
Electrics, Tricopters, FPV
rcgreaves's Avatar
USA, WI, Stoughton
Joined Jun 2000
CAD, STL,DXF Need Help finding some source files to get started.
Wanting to learn some CAD, are there images sources out there, id B17, or T33 or or or..?
rcgreaves is offline Find More Posts by rcgreaves
Old Jul 19, 2005, 01:07 PM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
I self-taught myself on DesignCAD around 12 years or so back. Diddled around with other's drawing files and found it to be of little practical use.
In the end, I jumped in at the deep end and not only drew up a plan on DCAD, I also built and flew the model.
I had a fair amount of drawing time on "conventional" drawing board set-ups, and just applied those skills to CAD - a line's a line, whether you draw it on-screen or with a pencil on paper. The trick is to learn how to best place lines and make them go in the desired direction. My first try was a simple sports RC model - doing something like a B17 for a first effort might be a little ambitious.
Interesting aside - I did drawings much faster by pencil and drafting gear than I've ever done in CAD. With a pencil, a line goes down after much thought, and stays down - with CAD, things are so easy to change, you keep on changing them. This is backed up by a friend of mine who is a professional architectural draftsman and a very good model aircraft designer. He prefers to use 'traditional' techniques over CAD at both hobby and making a living...
CAd can be time-absorbing, you have been warned
Regards
Dereck
Dereck is offline Find More Posts by Dereck
I need help finding a source blucor foam! Picoflyer Foamies (Kits) 23 Oct 18, 2009 07:35 AM
Discussion Need help finding some wire MX DIY Electronics 2 Oct 11, 2006 06:09 PM
Need help finding some posted pictures BrentLA Aerial Photography 2 Oct 30, 2003 11:02 PM
NEED HELP finding a new radio jh2 Parkflyers 10 Sep 10, 2001 08:45 PM
I need help with some 50 mAh packs. for MHLG e-sailpilot86 Power Systems 3 Jul 24, 2001 02:20 PM
