Old Apr 25, 2002, 09:28 PM
Mike C is offline
Find More Posts by Mike C
Mike C's Avatar
Roxboro, NC U.S.A.
Joined Sep 2000
Got a bet going. What do you call this?
Having a debate about what you call a triangular ruler. Has one corner at 90 degrees and the other at 45 degrees. I say it is called a triangle (simple huh?) My friend says it is called a speed square. I know speed squares are used in carpentry. I see this used in drafting a lot but have never heard a technical name before. Thanks for helping to settle this bet.
Mike C is offline Find More Posts by Mike C
Old Apr 25, 2002, 09:36 PM
EBob is offline
Find More Posts by EBob
Sacramento, CA
Joined Sep 2001
It's called a 45 degree triangle. The 'other' kind is a 30-60-90 degree triangle. Simple, huh??
Do you know what the other name for a (pair of) pliars is, you know the kind that has a slip joint? In the military, it's called a universal speed wrench (more trivia than you wanted to know).
EBob is offline Find More Posts by EBob
Old Apr 25, 2002, 09:56 PM
DBCherry is offline
Find More Posts by DBCherry
Worcester, MA.
Joined Nov 2001
My $0.02.
If it's plastic and generally used on a drafting table, it's called a triangle; metal and used by carpenters, a speed square. Simple huh?
DBCherry is offline Find More Posts by DBCherry
Old Apr 25, 2002, 10:05 PM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
My bro says it aint a speed square unless it's got an lip on it.
With lip=speed square
Without lip=triangle
William A is offline Find More Posts by William A
Old Apr 25, 2002, 10:09 PM
Stregone is offline
Find More Posts by Stregone
Stregone's Avatar
Manassas, VA, USA
Joined Feb 2002
I've never heard it called a speed square before, always simply 'a square'.
Stregone is offline Find More Posts by Stregone
Old Apr 25, 2002, 10:31 PM
Philipp is offline
Find More Posts by Philipp
Philipp's Avatar
Grand Prairie, Texas, USA
Joined Mar 2000
A carpenters "SQUARE" is not a triangle or a square either, for that matter, it's an "L" shape.
I think that William A is correct with the lip-or- not value.
My 1.5 cents
Philipp is offline Find More Posts by Philipp
Old Apr 25, 2002, 11:01 PM
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
Old Apr 25, 2002, 11:05 PM
Mike C is offline
Mike C's Avatar
Roxboro, NC U.S.A.
Joined Sep 2000
Thanks guys looks like I was closest to being right! I appreciate all of the quick responces. The lip part makes sense after you brought it up. I always said that the smartest folks on the net are right here
Old Apr 26, 2002, 02:58 AM
tim hooper is offline
Find More Posts by tim hooper
Single-task at best...
tim hooper's Avatar
Telford, UK
Joined Feb 2000
It's a set-square over here
tim
tim hooper is offline Find More Posts by tim hooper
Old Apr 26, 2002, 05:48 AM
DBCherry is offline
Worcester, MA.
Joined Nov 2001
Good point William. I hadn't thought about the lip.
Old Apr 26, 2002, 07:07 AM
cruzomatic is offline
Find More Posts by cruzomatic
San Antonio, Texas USA
Joined Feb 2001
Guys,,,,,,guys,,,,,,,,,,,,it's a square.
cruzomatic is offline Find More Posts by cruzomatic
Old Apr 26, 2002, 07:29 AM
gnofliwr is offline
Find More Posts by gnofliwr
aka: A.Roger Wilfong
gnofliwr's Avatar
Novi, Michigan, United States
Joined Jan 2001
A square triangle?
Isn't that an oxymoron?
gnofliwr is offline Find More Posts by gnofliwr
Old Apr 26, 2002, 08:31 AM
DBCherry is offline
Worcester, MA.
Joined Nov 2001
Only if it's like the one in the picture. If it's plastic, used for drafting it's a triangle.
Old Apr 26, 2002, 08:55 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I have that exact same triangular square.. it's a sqaure, no doubt..
Now this is silly..
..a
Old Apr 26, 2002, 09:11 AM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
That's a set square.
Prime component of every schoolboy's geometry set along with the protractor, ruler and a set of compasses.
http://www.technologyindex.com/educa..._sq/set_sq.htm
Brian
leccyflyer is offline Find More Posts by leccyflyer
What Do You Call This Winding Method?? alaskagoldman Power Systems 12 Sep 28, 2005 02:35 PM
What do you call this manouver? Xoltri Parkflyers 4 Sep 09, 2002 04:42 PM
What would you call this plane? Martin Hunter Electric Plane Talk 18 Jun 02, 2002 12:37 AM
Guys, what do you think of this kit ? NetForce2K Foamies (Kits) 11 Apr 30, 2002 10:13 PM
