Old Jul 18, 2005, 11:49 AM
Da V. is offline
Find More Posts by Da V.
You can do it!!!
Da V.'s Avatar
Joined Mar 2005
New Komodo KH-283 Outrunner Motor Kit is available now at US$25.88 only!!!
Hello to all,
The new Komodo KH-283 Outrunner Motor Kit is available now at www.komodohobby.com Price at US$25.88only
KH-283 Outrunner Motor kit includes the following parts:-
1pc Pre-pressed CNC Aluminum End-Bell and Flux Ring
2pcs 23.8mm Stator
1pc CNC Aluminum Back Mount Bearing Carrier
2pcs Ball Bearings
1pc 3.17mm Hardened Steel Shaft
40ft 23 AWG Enameled Magnet Wire
12pcs 2.08mm Curved NdFeB Magnets
1pc Propeller saver
2pcs Propeller Saver Adaptors
3pairs Connectors (Male and Female)
7pcs Shrinking Tubes
1pc C-clip
Net Weight (RTF): 69g
KH-283 outrunner motor is powered by two 23.8mm stators with 2.08mm thickness curved NdFeB magnets. It can produce explosive power for your RC plane. Swing a large propeller to produce high thrust and high pitch speed at low current is the main task of Komodo KH-283 outrunner motor.
In this motor kit, all parts are designed carefully and produced in high quality material. In order to make the motor kit easy to assemble, we have imported new precious pressing machines to pre-press the endbell and the flux ring together. Now, you can say bye bye to your "Vice" .
Curved NdFeB magnets are included in this motor kit. They are perfectly fit into the flux ring. By this design, the magnetic flux lines can be shaped optimally and it can increase the efficiency of the motor . Moreover, the size of magnet is perfect match each other, builder do not need spacer or jig for placing them into the bell . We would say assemble KH-283 Outrunner Motor kit is a piece of cake .
EXTRA Propeller Saver and Replacement Rings are added to KH-283 outrunner motor kit as a gift . It can protect your propeller from hitting ground, but also let you install GWS SF, GWS HD, APC E and APC SF propeller easily.
The building Instruction is available to download at www.komodohobby.com under the Tuturial Download session
Here is the overview of this new KH-283 Outrunner Motor Kit
Da V. is offline Find More Posts by Da V.
Old Jul 18, 2005, 12:11 PM
Da V. is offline
You can do it!!!
Da V.'s Avatar
Joined Mar 2005
Initial Performance Data of KH-283 Outrunner Motor
10 Turns, 23g Magnet Wire, Wye, EP1047SF Propeller
7.7V, 6.3A, 4900rpm, 421g Thrust
8.8V, 7.7A, 5500rpm, 525g Thrust
9.9V, 9.0A, 5900rpm, 607g Thrust
10.1V, 9.2A, 6000rpm. 634g Thrust
11V, 10.3A. 6400rpm, 720g Thrust
10 Turns, 23g Magnet Wire, Wye, EP9047SF Propeller
7.7V, 4.3A, 5400rpm, 303g Thrust
8.8V, 5.2A, 6100rpm, 376g Thrust
9.9V, 6.0A, 6700rpm, 454g Thrust
10.1V, 6.2A, 6800rpm, 465g Thrust
11V, 6.9A, 7300rpm, 529g Thrust
7Turns, 22g Magnet Wire, Wye, EP9050HD Propeller
7.7V, 7.4A, 6700rpm, 432g Thrust
8.8V, 9.0A, 7400rpm, 538g Thrust
9.9V, 10.7A, 8100rpm, 647g Thust
10.1V, 10.9A, 8200rpm, 660g Thrust
11V, 12.3A, 8900rpm, 766g Thrust
12.1V, 14.1A, 9400rpm, 884g Thrust
13.2V, 16.1A, 10080rpm, 1013g Thrust
13.4V, 16.2A, 10200rpm, 1024g Thrust
14.3V, 17.8A, 10700rpm, 1120g Thrust
Da V.
Komodo Hobby
Old Jul 18, 2005, 12:36 PM
Bill Bergman is offline
Find More Posts by Bill Bergman
Houston, Tx.
Joined Jan 2003
Beautiful motor Da V.
Bill Bergman is offline Find More Posts by Bill Bergman
Old Jul 18, 2005, 12:37 PM
Da V. is offline
You can do it!!!
Da V.'s Avatar
Joined Mar 2005
Thank you, Bill.
Da V.
Komodo Hobby
Old Jul 18, 2005, 12:57 PM
Houston, Tx.
Joined Jan 2003
I really didn't need another motor but I just ordered one.
Old Jul 18, 2005, 01:42 PM
Kbofwy is offline
Find More Posts by Kbofwy
non-recovering R/C addict
Wyoming, USA
Joined Dec 2004
I ordered two early this morning. Looks like a great kit and affordable too. Can't wait to try one!
Kbofwy is offline Find More Posts by Kbofwy
Da V. is offline
You can do it!!!
Da V.'s Avatar
Joined Mar 2005
So that, now you need another plane to play with your new motor
Thank you very much for your order
Da V.
Komodo hobby
Old Jul 18, 2005, 01:44 PM
Houston, Tx.
Joined Jan 2003
I need to crash! I also have too many planes.
Da V. is offline
You can do it!!!
Da V.'s Avatar
Joined Mar 2005
Your motors are packed and will be shipped to you tomorrow morning. Thank you very much.
Enjoy the winding game!
Da V.
Komodo Hobby
Old Jul 18, 2005, 01:48 PM
Da V. is offline
You can do it!!!
Da V.'s Avatar
Joined Mar 2005
Send some to me. I can do it professionally.
Da V.
Old Jul 18, 2005, 02:13 PM
Houston, Tx.
Joined Jan 2003
I would but shipping cost would be prohibitive
Old Jul 18, 2005, 03:12 PM
hokonghing is offline
Find More Posts by hokonghing
hokonghing's Avatar
Houston
Joined Jan 2002
Da V. do you have any idea of the finish weight of the motor? for a typical winding, that is.
Kong Ho
hokonghing is offline Find More Posts by hokonghing
Old Jul 18, 2005, 04:01 PM
Scott_NJ is offline
Find More Posts by Scott_NJ
RC Geek
Scott_NJ's Avatar
United States, NJ, Stanhope
Joined Dec 2004
DaV,
Looks great, can't wait to see some more results and build details on these.
Curious as to what sort of motor mount comes with, or is available for the double?
_Scott
Scott_NJ is offline Find More Posts by Scott_NJ
Old Jul 18, 2005, 06:24 PM
MorrisM is offline
Find More Posts by MorrisM
MorrisM's Avatar
Oklahoma City
Joined May 2004
Da V.
You run the 7 turn at over 250 watts
Does it get hot when you push it this hard?
Morris
PS - ordered 2 kits, can't pass up a good deal.
MorrisM is offline Find More Posts by MorrisM
Old Jul 18, 2005, 07:08 PM
mjdee14 is offline
Find More Posts by mjdee14
mjdee14's Avatar
Nashville TN, USA
Joined Jun 2004
Don't need another one but ordered one anyway.....
Great looking motor at a fantastic price. Nothing better than seeing oneof your motors humming along on a plane you built from foam!!!
mjdee14 is offline Find More Posts by mjdee14
Alert New well designed KH-257D Outrunner Motor Kit is available now! Da V. Power Systems 154 Feb 24, 2008 09:28 PM
Alert New Powerful Komodo "KH-257 Outrunner Motor Kit" is available now!!! Da V. Power Systems 845 Mar 21, 2007 11:32 AM
Alert Komodo KH-283 Outrunner Motor Kit Version 2 available now!!! Da V. Power Systems 612 Jan 30, 2007 11:14 PM
Discussion Komodo Hobby KH-257 Outrunner Motor kit questions. bamm Power Systems 7 Dec 13, 2006 12:17 PM
Alert Great News! Super Offer of Komodo Hobby KH-278 Outrunner Motor Kit Da V. Power Systems 32 Mar 31, 2005 10:51 PM
