Go Back   RC Groups > Aircraft - Electric - Airplanes > Indoor and Micro Models
Old Jul 18, 2005, 05:28 AM   #1
RotHeli1: 9" RC UFO DIY project
Hi all!
After the microheli4 project (http://www.rcgroups.com/forums/showthread.php?t=297067), this is my new DIY project : RotHeli1 (photos below)
This is an All Rotating Aircraft concept that is fully controlable.
The platform is based on "Vectron ultralite" saucer (steven davis patent, good idea steven!) that you can find at your local toy store. This saucers are very stable in hovering but you only have 1 channel (up-down). I´d like to make it fully RC with 4 channels like a normal Heli.
To achieve this the first step is to put an electronic compass and a PIC to resolve the first problem (where is the heli pointing?) and a LED to indicate where is the heli "virtual tail". This resolve the orientation problem...
The second big problem is how to move the heli? The answer is an stabilization bar (really a desestabilization bar...) that is controled by a magnetic actuator and the PIC. If you change the angle of the stabilization bar in the same point on each revolution of the body you get (90º later) a move of the heli... Ok this is a simple explanation...
RotHeli1 specs :
- Lenght(Diameter) : 23 cm (9")
- Height : 13 cm
- Total weight : 79g
- Body construction : Depron, balsa & 2mm Carbon rods
- Battery : LiPo 250mAh
- Battery life : about 10 min.
- Rx : Schulze Alpha 4 (without case)
- Motor : 1 x GWS LPS 5:1 (RXC motor)
- Prop : GWS 9x4.7 cutted to 8.5x4.7
- Servos : NO
- Stability : Self-stable
- Gyro : NO (the compass works as a heading-hold gyro)
- Actuator : 1 x Magnetic actuator (coil + magnet)
- Functions : 4 (Throttle, Roll, Pitch and Yaw)
- Electronics : home made electronics
- Compass module : magnetoresistive sensor + OPamp
- Procesor : PIC 16F876
- Price : This is a cheap project (the most expensive component is the electronic compass at about 20$)
I could say that this "thing" is very stable in hover and you can control in all directions like a normal heli. This first version is a little lazy to move buy i am working on this...
I´d like to know how do you think about this project and new ideas/question to improve it. I can post more info if you want. I am now working on a version 2...
Here are some photos.
JoseJ.
  • Name: RotHeli1_1.jpg
  • Name: RotHeli1_2.jpg
  • Name: RotHeli1_3.jpg
  • Name: RotHeli1_5.jpg
JoseJ is offline Find More Posts by JoseJ   Reply With Quote
Old Jul 18, 2005, 09:50 AM   #2
Pro Bro #495
fwilly's Avatar
Wow!!! Thats awesome!
fwilly is offline Find More Posts by fwilly   Reply With Quote
Old Jul 18, 2005, 09:55 AM   #3
The ceiling is the limit!
micromad's Avatar
Wow that looks complicated.
micromad is offline Find More Posts by micromad   Reply With Quote
Old Jul 18, 2005, 11:59 AM   #4
Thats NOT indestructible
j8m8l's Avatar
Amazing project!
Do you have any flight videos?
Josh
j8m8l is offline Find More Posts by j8m8l   Reply With Quote
Old Jul 18, 2005, 12:06 PM   #5
TheyreComingToTakeMeAway!
derk's Avatar
thats cool 4 channels, one actuator. thats awsome.
how did you get it to tell when to light the led in the right spot every time?
a timing circut linked to the compass?
derk is online now Find More Posts by derk   Reply With Quote
Old Jul 18, 2005, 12:24 PM   #6
Micro Flyer, Big Poster
Pete P's Avatar
Awesome!!! Post some plans and such!
Pete P is offline Find More Posts by Pete P   Reply With Quote
Old Jul 18, 2005, 12:42 PM   #7
Compass Info?
Hello!
Great project. Can you tell us more about the PIC, what that is, and how you set up a heading with the compass? Any links would be great, and thanks in advance!
Pappy
PappyAVG is offline Find More Posts by PappyAVG   Reply With Quote
Old Jul 18, 2005, 01:51 PM   #8
unsped's Avatar
another person salivating for more info
unsped is offline Find More Posts by unsped   Reply With Quote
Old Jul 18, 2005, 02:07 PM   #9
build to fly, not to crash
micro_builder's Avatar
Send a message via Yahoo to micro_builder
amazing work. i just read through your MicroHeli 4 project, and the amount of work that must've been involved is staggering. simply fantastic
nick
micro_builder is offline Find More Posts by micro_builder   Reply With Quote
Old Jul 18, 2005, 04:31 PM   #10
Check your PM, please!
3D Devil is offline Find More Posts by 3D Devil   Reply With Quote
Old Jul 18, 2005, 06:31 PM   #11
DC Concepts
superdave42's Avatar
Send a message via MSN to superdave42
I'll buy one if ya mod one up for me :-)
superdave42 is offline Find More Posts by superdave42   Reply With Quote
Old Jul 18, 2005, 06:37 PM   #12
Thanks for the Fish!
aerogel's Avatar
electronic compass Thingy is Brilliant
aerogel is offline Find More Posts by aerogel   Reply With Quote
Old Jul 18, 2005, 06:45 PM   #13
Thanks for your interest
Here there is a better explanation:
The yaw stick, control where the heli is pointing. As all the body is rotating we use a LED that blinks in the same point of the revolution as an orientation point (imagine this as the tail of an heli) so when you see the blue LED you know where is the tail. (you can see this on the last photo of the first post).
If you move the yaw stick the LED rotates to the left or to the right as an heli tail does. I call this a "virtual yaw" o "virtual tail". Also because we have an electronic compass this tail works as if we have an heading-hold gyro because if we dont touch the yaw stick, the virtual tail is always pointing in the same direction.
With the Roll and Pitch stick is a bit more complex. With Roll and Pitch we calculate at what point of the revolution with respect to the virtual yaw (LED) we have to move the actuator to achieve the correct movement of the body (we have also to take acount of the gyroscopic precesion).
Here is a simple drawing of this...
I am planning to post videos tomorrow ( I hope)
JoseJ.
  • Name: explicacion1.jpg
Old Jul 18, 2005, 06:50 PM   #14
DC Concepts
that is sooo cool.
Old Jul 18, 2005, 07:31 PM   #15
My member is not
Bronze Member
Zlatko's Avatar
JoseJ,
That is sooo good .
I tried to make a 4 rotor microheli like your first atempt, inspired by your work, but I used 3 gyros, 4 ESCs and 3 V-Tail mixers. I didn't have much luck with that method. The mixers would just "oscilate" by themselves ( I had two cascades ) . I tried a different brand of mixers, but not much luck. I used normal gyros, not HH gyros.
I would like to try the Vectron mod, this looks less complicated.
Will you be shearing the schematics and the code?
Cheers
Zlatko
BTW I've ordered the X-UFO "thing" but still waiting for delivery .
Zlatko is offline Find More Posts by Zlatko   Reply With Quote
MicroHeli4: a servoless micro heli DIY project JoseJ Coaxial Helicopters 52 Jun 28, 2006 03:24 PM
I created an rc-UFO ! Brian Raab rec.models.rc.air 8 Oct 11, 2004 01:11 AM
micro rc helicopter - DIY build a rc helicopter RCHeliFans rec.models.rc.helicopter 0 Sep 15, 2004 05:11 AM
The Bluecor Bakeoven - DIY project flieslikeabeagle Foamies (Kits) 36 Sep 08, 2004 09:05 AM
Infrared DIY project phil555ip Indoor and Micro Models 8 Feb 19, 2004 10:35 AM
Congratulations SimpleM!
