Old Apr 25, 2002, 01:30 PM
dom is offline
dom
Find More Posts by dom
dom
Toronto, Canada
Joined Sep 2001
Need help with location of esc on brushless T-33
Should I put the speed controller behind the motor and have long wires on the battery side or put the esc up front next to the battery and have long wires on the motor side? I can't find a spot in between unless I put it in the ducting or on the outside of the fuselage. I am using a Fun 480-33 on 10 RC2400. Any advice would be appreciated.
dom is offline Find More Posts by dom
Old Apr 25, 2002, 01:34 PM
Paul Willenborg is offline
Find More Posts by Paul Willenborg
Registered Lifeform
Paul Willenborg's Avatar
Little Rock,AR,USA
Joined Jun 1999
Definitely toward the front. You want the shortest possible wires between the battery and controller. Mine is mounted directly under the elevator servo at the rear of the battery compartment. This did require a little foam carving. It has worked just fine for over three years.
Paul Willenborg is offline Find More Posts by Paul Willenborg
I need help with Mosfet identification on my Jeti esc WickedFunRC Power Systems 35 Sep 24, 2013 02:13 PM
Need help with finding info on Batt\ESC\Motor combos Skawrpion Parkflyers 5 Sep 19, 2003 01:43 PM
Need help with charging difficulties on NIMH..... matchlessaero Parkflyers 4 Jan 06, 2003 09:05 PM
need help with elevon mixing on a Futaba FP-T7UAP epkoncept Electric Plane Talk 2 Jul 22, 2002 08:07 PM
need help with elevon mixing on a Futaba FT-T7UAP epkoncept Foamies (Kits) 0 Jul 21, 2002 11:23 PM
