Old Jul 16, 2005, 06:20 PM
Ferocious Franki is offline
Find More Posts by Ferocious Franki
Ferocious Franki's Avatar
San Jose,Ca
Joined May 2005
Yippee!
Official Parkzone P-51 Owner's Thread Part 2
I thought it was time for part 2.
Here's part 1.
http://www.rcgroups.com/forums/showthread.php?t=377311
Just as same as the last one. Come and talk about your Parkzone P-51.
Ferocious Franki is offline Find More Posts by Ferocious Franki
Old Jul 16, 2005, 09:40 PM
Spencer J is offline
Find More Posts by Spencer J
USA
Joined Jun 2002
They arn;'t closing threads over 500 posts anymore I found that out with a estarter thread
Spencer J is offline Find More Posts by Spencer J
Old Dec 04, 2007, 07:55 AM
super cub is offline
Find More Posts by super cub
Joined Aug 2007
parkzone p-51
I love my p-51 and I have had some really good flights with it.
super cub is offline Find More Posts by super cub
Old Dec 12, 2007, 09:46 AM
btalley is offline
Find More Posts by btalley
Joined Oct 2007
The belly landings can get hairy if you are new to warbirds!!
btalley is offline Find More Posts by btalley
Old Dec 12, 2008, 11:58 PM
lakewash is offline
Find More Posts by lakewash
Joined Jul 2008
ailerons
My P-51 doesn't seem to very good aileron control. Has anyone found a way to make the movement larger??
lakewash is offline Find More Posts by lakewash
Old Dec 16, 2008, 03:08 PM
electriceye is offline
Find More Posts by electriceye
Kiss the Sky
electriceye's Avatar
Dorking, Surrey, UK
Joined Jul 2006
Are you sure the push rods are not binding? Many say you need to remove, rub with wet and dry to remove any corrosion then replace after coating them lightly in vaseline, WD 40 or similar lubricant/corrosion inhibitor.
electriceye is offline Find More Posts by electriceye
Old Dec 16, 2008, 09:52 PM
Gohmer is offline
Find More Posts by Gohmer
Owatonna MN 55060
Joined Sep 2005
Ailerons
Use the control horn hole closest to the aileron.
Longer servo arm.
Computer radio.
Have you flown it? Doesn't take much aileron movement to make it turn.
Gohmer is offline Find More Posts by Gohmer
Old Dec 16, 2008, 10:03 PM
papabatman is offline
Find More Posts by papabatman
Shut up and fly
papabatman's Avatar
United States, CO, Dacono
Joined Jun 2008
http://www.rcgroups.com/forums/showthread.php?t=418686
papabatman is offline Find More Posts by papabatman
Old Oct 23, 2009, 09:42 PM
Jsutherland8 is offline
Find More Posts by Jsutherland8
ELECTRIC R/C
Jsutherland8's Avatar
Canada, ON, Woodstock
Joined Feb 2006
$ 2 Upgrade To Metal Gear Servo
After seeing the nice metal gear servoes in my Corsair, and finding out the price of putting in a PKZ1090 (metal gear) instead of a PKZ1080 (plastic gear) is ~ $2. I will be using them when I can, in any spot a PKZ1080 would go.........The P-51 Rudder and Elevator servo would swap out, or just swap if you do not use the rudder much. If you are driving a tail wheel then this is the way to go. Spend the $14 and get the Metal Gear Servo.......Too bad it does not come in a long lead......yet...! for the allerons.
Just got my tail glued in and lipo on charge. As I was looking the P-51 over, I did not like the way the decals were put on, and the rudder seeems a bit loose. Rudder will get a servo, so it will not matter. Like the idea of putting hinges on it.
Jsutherland8 is offline Find More Posts by Jsutherland8
Old Jan 16, 2014, 08:35 AM
Copperhead13 is offline
Find More Posts by Copperhead13
Joined Nov 2013
How will you change the stab if needed.
Copperhead13 is offline Find More Posts by Copperhead13
Old Mar 23, 2014, 09:41 PM
Somethin' Extra is offline
Find More Posts by Somethin' Extra
**** this ****
Somethin' Extra's Avatar
Joined May 2013
You cut out the old and put in the new. It's not hard I be done it before.
Somethin' Extra is offline Find More Posts by Somethin' Extra
Latest blog entry: <vent>
Old Apr 02, 2014, 07:42 AM
Joined Nov 2013
I've noticed that some of the p51's only come with ailerons.
Particularly the park zone and the art tech 30 inch. In general, do all p51's fly ok without using rudder, or are these designed so they are able to?
Old Apr 02, 2014, 10:19 AM
Leo L is offline
Find More Posts by Leo L
United States, NY, Queens
Joined Oct 2005
I can't speak for the Art Tech, but the PZ P-51 flies perfectly well with no rudder, as long as you are willing to handlaunch and bellyflop. If you decide to add landing gear, you will need to make the rudder functional for ground control.
Leo L is offline Find More Posts by Leo L
Old Apr 02, 2014, 11:05 AM
**** this ****
Joined May 2013
lol bellyflop
Old Apr 02, 2014, 11:09 AM
Joined Nov 2013
Is this in general with all planes that have ailerons, or just P-51's?
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Cool Parkzone P-51 Owner's Club Ferocious Franki Parkflyers 20 May 06, 2009 07:24 AM
Sold 2 qty. Parkzone P-51 / FW-190 nimh batteries, $20.00 niner555 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Sep 06, 2006 06:17 AM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
MM P-38 Build Thread - Part 2 jamesgood72 Parkflyers 514 May 11, 2005 10:52 AM
