Old Jun 22, 2001, 09:54 AM
DLC is offline
DLC
Find More Posts by DLC
DLC
Houston, TX USA
Joined Jun 2001
Micro-light Build Questiions
Thanks for your help. Based on your suggestions, I have decided what to do with everything but the battery. For several reasons I want to be able to replace it quickly and easily. I haven't found a straightforward way to do that with the Micro-Bipe design. I may, at least for initial flights, take a brute force approach and just strap it under the fuselage.
[This message has been edited by DLC (edited 06-23-2001).]
DLC is offline Find More Posts by DLC
Old Jun 22, 2001, 11:24 AM
CoClimber is offline
Find More Posts by CoClimber
Mountain Models Wannabe
CoClimber's Avatar
Ithaca, NY USA
Joined Mar 2001
I use scotch tape to hinge my tail surfaces on my DuskStik. Works great so far.
Doug
www.duskstik.com
CoClimber is offline Find More Posts by CoClimber
Old Jun 22, 2001, 12:12 PM
Megowcoupe is offline
Find More Posts by Megowcoupe
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
I'll second the tape idea. I used to use really cut down CA type hinges, but tape is easier and I think it works better. I use Magic tape which is much stronger than scotch tape.
I glue components in. If I'm trying to save weight, I cut the mounting tabs off of servos- rails are too heavy anyhow. Rxs I generally let flop around- they're so light the wires attached keep them around. I use Zap a Dap A Goo II for gluing motors on, batteries etc. The stuff is strong, sticks to nearly anything- watch out on foam though-sets up quick and if you're really determined you can pull it off. I've glued a Turbo 450 motor on an airplane with this stuff, and I'm not worried about it. Use small amounts of CA to make sure that the position of your battery is correct, mark it, break it loose, and use this stuff.
Sam Brauer
Norwalk, CT
Megowcoupe is offline Find More Posts by Megowcoupe
Old Jun 22, 2001, 02:38 PM
WAR is offline
WAR
Find More Posts by WAR
WAR
Austin, TX, USA
Joined Apr 2001
I have a Micro-Lite which is a prebuilt ARF balsa/covered slowflyer (8.5oz).
I was built by the factory with some type of clear cellophane tape (scotch or magic). Anyway the horizontal control surfaces on the elevator were misaligned so I had to remove and replace with my own tape.
I used Crystal Clear Scotch tape as replacement and has worked great. I used Clear Scotch Packing Tape on my Litestik and that has lasted forever. Very good stuff, easy to get, easy to install, lightweight and cheap!!!
WAR is offline Find More Posts by WAR
Old Jun 22, 2001, 02:45 PM
WAR is offline
WAR
WAR
Austin, TX, USA
Joined Apr 2001
To clarify:
The Micro-Lite uses tape as a hinge for the built-up tail surfaces. The tape sticks very well on the Litespan covering.
In my Micro-Lite (built-up fuselage, not a stick) the servos are secured with double-sided tape. The battery is secured with hook and loop fastener (Velcro). And the 280 motor and Horst geardrive are mounted with screws to the firewall on the front of the plane.
These are very light-weight solutions. Like I mentioned previously, it weighed only 8.5oz complete including battery. Pretty light for a 280 speed plane with 8-cell 300mAh NiMH.
Old Jun 22, 2001, 03:17 PM
Pierre Audette is offline
Find More Posts by Pierre Audette
RPV builder & operator
Pierre Audette's Avatar
Canada, QC, Gatineau
Joined Jan 2001
There's a clear medical tape, like band-aid material, but I forget the exact name, which is great for full length hinges. It's about 1" wide, comes in a 'scotch tape' like dispenser, it's waterproof and very flexible. Available at most drugstores.
Pierre Audette is offline Find More Posts by Pierre Audette
Micro Hydroplane Build Attemp thailandboy2 Racing Boats - Electric 29 Aug 25, 2015 11:31 AM
Micro speedwing build schoey Foamies (Kits) 46 Aug 08, 2005 11:22 AM
Mini Funtana weights and super light build 3d_Crazy 3D Flying 68 Dec 29, 2004 11:55 AM
House of Balsa Micro Cub Build OCModels Parkflyers 52 Aug 29, 2003 11:47 PM
