Old Jul 13, 2005, 10:49 AM
reusty2k5 is offline
Find More Posts by reusty2k5
reusty2k5's Avatar
Western New York
Joined Aug 2004
How to Scale down a PDF file???
Does anyone know of a way I can scale down a PDF document?
I would like to create a smaller plane than the plans I have are made for.
I searched the forum, but didnt find a method for doing this
How can this be done?
Thanks in advance for the help!!!
reusty2k5 is offline Find More Posts by reusty2k5
Old Jul 13, 2005, 10:57 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
I have had some luck with this, depending on how the PDF was created. Email me the file and I can try for you.
Pat MacKenzie
edit - or post the link to it.
pmackenzie is offline Find More Posts by pmackenzie
Old Jul 13, 2005, 06:37 PM
SoCalGliderFlyr is offline
Find More Posts by SoCalGliderFlyr
Think Thermals!!!!
SoCalGliderFlyr's Avatar
Costa Mesa, California
Joined Mar 2004
Has to be scaled when it is printed. The printer driver will have a percentage input. This will force it's scalling.
SoCalGliderFlyr is offline Find More Posts by SoCalGliderFlyr
Old Jul 13, 2005, 08:35 PM
Michael Ga is offline
Find More Posts by Michael Ga
Just-Fly-It
Augusta, Ga
Joined Sep 2004
I use Jasc Paint Shop Pro 8. Converts PDF to Paint Shop format, then you can resize up or down. Then you can print any "portion of plan" you want actual size. Free trial for 30 or 45 days. A great graphics program at bargain price. Let me know if you need help.
Michael Ga
Michael Ga is offline Find More Posts by Michael Ga
Old Jul 13, 2005, 08:42 PM
reusty2k5's Avatar
Western New York
Joined Aug 2004
I used the "low-tech" method, Printed the plans full scale, then scanned them into a pdf, using the scanner's driver to do the scaling.
Not effecient, but effective
Thanks for the help!!
Old Jul 13, 2005, 08:48 PM
Think Thermals!!!!
Joined Mar 2004
Eeeeek!!!
Old May 31, 2009, 04:45 PM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Hey, I googled "scale down pdf" and guess what the first link was... this thread. Since there's no info to follow here, I figured I'd explain how I scale down plans. In this example, we have the original non-tiled plans and we want to scale them to 80% of the original size, and print them on a typical home/office letter sized printer.
I use Acrobat 8. Open the full size untiled plan, print to pdf, and set the scaling to whatever (80% in this case). The scaling setting is under the pdf driver "properties", in the "paper/qualities" tab, in the "advanced" settings menu. Be sure to set it back to 100% after you're done, hehe. That should produce a full size plan scaled to 80% of the original.
Then, if you don't do Kinko's or have a plotter, open the 80% plans and print to a tiled pdf if necessary (making sure the pdf scaling is set to 100%). Note that before printing to the tiled pdf, I like to decrease the paper size manually to 7.75x10.75 under "adobe pdf settings"\"adobe pdf page size", which is found in the pdf driver "properties". This makes the tiled pages fit in most printer margins, otherwise my printer crops the cut marks off. When you do this, make sure to set your printer driver back to letter size before you print the tiles pages. This will not change scaling, as long as you print the tiled pages with no scaling.
Hope this helps a few builders out there!
Cheers,
Kev
Truglodite is offline Find More Posts by Truglodite
Old May 31, 2009, 06:03 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
I am just testing to see if Corel Draw will import a PDF and rescale it..bear with me..takes time to boot bloody WinDoze on this machine..
Blimey. 15 minutes..something's not right, but yes, Corel Draw can import and resize PDFS, it seems.
Old Jun 01, 2009, 06:31 AM
Hemikiller is offline
Find More Posts by Hemikiller
-insert witty saying here-
Hemikiller's Avatar
United States, CT, Killingworth
Joined Dec 2005
Photoshop can resize PDFs as well.
Image -> Image Size, check the "constrain proportions" checkbox, enter the new image dimension size and "OK".
Photoshop Elements 7 has a free trial as well...
http://www.adobe.com/products/photoshopelwin/
Hemikiller is offline Find More Posts by Hemikiller
Old Jun 03, 2009, 01:54 AM
dpot is offline
Find More Posts by dpot
dpot's Avatar
France, Auvergne, Lapalisse
Joined Dec 2005
acad design review it free no trial and prints to scale
http://usa.autodesk.com/adsk/servlet...&siteID=123112
dpot is offline Find More Posts by dpot
Old Jun 03, 2009, 07:38 AM
Andrew0820 is offline
Find More Posts by Andrew0820
Western KY
Joined Sep 2003
I would suggest that you look into Tile Print. It was written by a modeler for modelers. Actually, Andrew is a professional programmer, but also quite an excellent builder. Tile Print allows PDFs to be scaled to any size and allows smaller PDFs to be expanded to match the rulers usually found on most plans. It has the added bonus of tiling the printed output so you don't need access to large scale printers.
the other andrew
Andrew0820 is offline Find More Posts by Andrew0820
Old May 13, 2011, 08:40 AM
Photon is offline
Find More Posts by Photon
Ph.D in Depronology
Photon's Avatar
Armageddon
Joined Aug 2004
I was reading this thread while looking for a solution myself. In my case it was scaling up.
Then I figured out a simple and effective way to do it, all with free software.
The trick is to print the PDF through a PDF printer driver.
I use CutePDF which is free and using its advanced properties, I set the paper size to custom and make it exactly as the relative size should be. I also set the print scaling and voila...
Photon is offline Find More Posts by Photon
Old May 13, 2011, 12:23 PM
TFM70 is offline
Find More Posts by TFM70
USA, GA, Carrollton
Adobe reader X
TFM70 is offline Find More Posts by TFM70
Discussion how do i tile a pdf file? rumplestilskin Foamies (Scratchbuilt) 6 Sep 03, 2006 11:47 AM
Question How to Scale down a successful model? PrasadL Scratchbuilt Indoor and Micro Models 1 Dec 02, 2004 09:18 AM
how to turn a drawing on paper into PDF file? Stefan lamers Foamies (Kits) 5 Oct 29, 2004 12:57 AM
How do I scale down Plans fly4fun 3D Flying 7 Oct 22, 2004 07:00 AM
How to scale down plans fourstarforty Sport Planes 28 Sep 24, 2004 08:15 PM
