Old Jul 13, 2005, 11:43 AM
Ravenseye is offline
Find More Posts by Ravenseye
Foam-n-Stein
Syracuse NY
Joined Dec 2004
Question
What material is best for foam cuttin' templates?
So, with the help of my flight club here at rcgroups, I've built myself a foam cutting tool.
Now, I need to make some templates that I can use to cut out all these beautiful planes I see here!! What is the material you have used to make these, and why?
I have posterboard available, pressboard, illustration board as well as thin sheets of mdf. I'm leaning towards bressboard as its the cheapest, free, and it is the most plentiful that I have.
Again, thank you to the awesome posters here who have taught me much over the past few months of reading and thinking!
-Mike
Ravenseye is offline Find More Posts by Ravenseye
Old Jul 13, 2005, 11:58 AM
klong66 is offline
Find More Posts by klong66
Joined Aug 2004
mike,
for wing airfoils I use formica, hard and sands super super smooth for zero snags.
For general plane templates i've read where people have used picture framing mat. or even place mats. They reported that these hold up for about 10 cuts...
What is press board? Where can it be purchased.. I'd think for just making a few planes from 3mm depron, the posterboard would be good enough, just don't press to hard against it.
klong66 is offline Find More Posts by klong66
Old Jul 13, 2005, 01:03 PM
minifly is offline
Find More Posts by minifly
Robots... robots everywhere
minifly's Avatar
Cape Town, South Africa
Joined Jan 2003
i use fiberglass pcb with the copper removed, also works great for motor mounts
minifly is offline Find More Posts by minifly
Old Jul 13, 2005, 03:29 PM
DeaninMilwaukee is offline
Find More Posts by DeaninMilwaukee
Motors beat engines!
Milwaukee Wisconsin, United States
Joined Feb 2001
Picture framing matt is what I use, ( the thick stuff). Cuts easily and last well if you don't allow the wire to stop. ( you should'nt anyway). My wing jig for my parkracers has cut about 75 cores so far and still looks like new.
Dean in Milwaukee
DeaninMilwaukee is offline Find More Posts by DeaninMilwaukee
Old Jul 13, 2005, 03:37 PM
foamflyer is offline
Find More Posts by foamflyer
Trapped in California
foamflyer's Avatar
United States, CA, Arcadia
Joined Nov 2003
I use posterboard for the following reasons:
1. Easy to draw on, or glue a printed airfoil on to it.
2. Easy to cut (sisccors or hobby knife).
3. Inexpensive (<$1 per sheet) and readily available (Walmart or similar).
However, keep the wire temperature down or it will burn. Also, after a few uses the edges will "glaze" over resulting in an even smoother surface for the wire to run on. I've not experienced any snagging with the wire temperature low (with EPS foam, I don't use posterboard templates for EPP due to the higher wire temp). I've assembled a library of different types and sizes of airfoils and other templates, all ready to use.
foamflyer is offline Find More Posts by foamflyer
Old Jul 14, 2005, 04:35 AM
Foam-n-Stein
Syracuse NY
Joined Dec 2004
wow, quite the variety to work from.
I will work in order from cheap, posterboard, to the more expensive (if I have to).
Thanks a lot fellas!
-Mike
Old Jul 14, 2005, 08:48 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
We've been using Formica for at least 25 years .... usually find scraps around home sites (free) or home stores .... cut on the bandsaw, and the edges sanded , burnished rubbed with a soft graphite pencil ....they are excellent for high production / longevity
if you're doing ones and twos , the mat board is the way to go ....rubbing the pencil on the edges does help
gpw is offline Find More Posts by gpw
Old Jul 14, 2005, 12:08 PM
Crash & Burn is offline
Find More Posts by Crash & Burn
Crash & Burn's Avatar
Palmdale, Ca
Joined Jul 2004
another thing you can use is the plastic "for sale" signs found at most stores. cuts with scissors and lasts through quite a number of cuttings.
Crash & Burn is offline Find More Posts by Crash & Burn
Old Jul 16, 2005, 07:24 PM
Foam-n-Stein
Syracuse NY
Joined Dec 2004
My Mission...should I choose to accept it...
is to start scavanging all the building sites in the area for the formica...
I don't mind having templates that will eventually fall apart...but, I'm into durability...I want it to last as long as possible..
I have some aluminum roofing flash that I'll try for something to see how that works..
I'd imagine the process for prepping that would be similar to that for the formica.
1) lay out the plans
2) trim the plans out carefully
3) file/sand/grind the aluminum down smooth
4) see if it works!
Sound about right to the assembled masters?
-Mike
What type of wire for foam cutter? AirVenture Foamies (Kits) 6 Jan 27, 2008 04:32 AM
What prop is best for this set up deeman GWS (Grand Wing Servo) 0 Aug 16, 2004 02:20 PM
What bladegrips is the best for the corona? larsen2000 Electric Heli Talk 1 Jul 06, 2004 05:32 AM
What radio is best for 3D? barnyardflyer 3D Flying 11 Nov 09, 2003 03:12 PM
What type of gule for foam blocks and sanding? Gary Warner Electric Ducted Fan Jet Talk 10 Sep 21, 2001 04:52 PM
