Old Jul 12, 2005, 12:39 AM
Magna is offline
Find More Posts by Magna
Malaysia
Joined Jun 2001
How V Tail setup and deflect?
If I were to look at the plane from behind, if I turn my rudder stick to the left, both v tail should swing to left, correct?
In another word if I were to put my plane on its fuse side, where one of the vtail touching the table and the other vtail is almost straight up, it will deflect as in a normal tail plane? Am I correct.
I believe some people say its the opposite of aileron movement if one were to look from behind.
Am I correct?
Thanks!
Magna is offline Find More Posts by Magna
Old Jul 12, 2005, 01:39 AM
Leif is offline
Find More Posts by Leif
JART Builder/flyer :)
Leif's Avatar
Oslo, Norway
Joined Feb 2005
yep I think that when you turn the fuse so one side of the V-Tail is pointing straight up it should deflect like a conventional rudder... At least it works for me.....
Leif is offline Find More Posts by Leif
Old Jul 12, 2005, 07:32 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Just imagine the two surfaces folded up until they are both vertical. Now, rudder movement is the same as for a normal rudder.
So, for left rudder, left surface "down", right surface "up"..
..a
Old Jul 12, 2005, 07:05 PM
Magna is offline
Malaysia
Joined Jun 2001
Thanks Leif and Andy
Old Jul 12, 2005, 09:19 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Leif, where you located? (I know a guy named Leif up in TN.. )
Old Jul 13, 2005, 01:46 AM
Leif is offline
Leif's Avatar
Oslo, Norway
Joined Feb 2005
I am in Oslo, Norway.... TN????
Old Jul 13, 2005, 02:24 AM
Cody's Neighbour is offline
Find More Posts by Cody's Neighbour
Vertically Challenged...
Cody's Neighbour's Avatar
Ash Vale Hampshire UK
Joined Jul 2004
V-Tail movements
The RBC Paddle is a bit confusing though!
Cody's Neighbour is offline Find More Posts by Cody's Neighbour
Old Jul 13, 2005, 06:18 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Tennesee, USA!
..a
Old Jul 13, 2005, 01:50 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
I had an inverted vee-tail "paddleize" itself inflight... flew OK before and after.. but did reglue the broken joint after landing..
The booms have to be securely mounted...
Sparky Paul is offline Find More Posts by Sparky Paul
Old Jul 14, 2005, 02:15 AM
Leif is offline
Leif's Avatar
Oslo, Norway
Joined Feb 2005
presumably the inverted V-Tail in the photo reacts well since the roll component of the v-tail action and the rudder component are acting in the same direction? doesnt this make the controls even better?
Old Jul 28, 2005, 07:06 AM
Joined Jul 2004
Leif,
It does work ok, and is quite sensitive, but because the control surfaces are well out of the prop wash I have to be careful not to slow the Paddle down too much. The control movements are small - about 5mm each way to stop it being too twitchy. As it slows down the controls become less and less effective until there is none - then it does it's own thing! Sort of free-flight with motor control! Then I open up the throttle and as soon as the speed builds up I'm ok again.
Bert
Old Jul 28, 2005, 03:30 PM
Old Bag Lady Al is offline
Find More Posts by Old Bag Lady Al
The Old Bag LAdy
Chico, Calif
Joined May 2004
Sounds like you need to set up dual rates on your radio. At slow speeds V tails are somewhat inefective.. So when you slow down you'll need way more movement to stay in control...
looks like a fun plane..
Cheers
Al
Old Bag Lady Al is offline Find More Posts by Old Bag Lady Al
V-Tail Setup Question Bill K. Parkflyers 12 Mar 21, 2003 07:29 PM
Smart V-tail setup Clay High Performance 7 Nov 27, 2002 12:13 AM
Question Eclipse TX with V-tail, setup? 10Thumbs Hand Launch 9 Sep 17, 2002 10:35 AM
Question Tiny V tail setup d12bn Parkflyers 3 Feb 10, 2002 11:11 AM
Smart V-tail setup? Hammer Electric Sailplanes 2 Oct 30, 2001 10:14 PM
