Old Jul 11, 2005, 07:13 PM
jetspud is offline
Find More Posts by jetspud
shreveport
Joined Oct 2003
What motors are you using in your T-Rex
Well after a few flights, my T-rex with a chili pepper, has burt up the motor.. Seeing that chili peppers are not being made anymore I need a replacement.. I have the pheniox 25 with TP 2100's Any help would be great
David
jetspud is offline Find More Posts by jetspud
Old Jul 11, 2005, 07:15 PM
TheX is offline
Find More Posts by TheX
Old new guy
TheX's Avatar
United States, TX, Austin
Joined Sep 2004
on 3s the Mega 16/15/3 rocks. A lot of people are very happy with the Align 420 3200KV as well.
TheX is offline Find More Posts by TheX
Old Jul 11, 2005, 07:26 PM
OzzieFlyer is offline
Find More Posts by OzzieFlyer
Melbourne Australia
Joined May 2003
yeah..i'm happy with the 420lf, but i'm not a 3Der. It's a good sport/duration motor in my opinion. If you want serious power (at the expense of flight time), then there are better motors than the align 420lf....but they're almost twice the cost as well.
the aon 3500kv is apparrently excellent..but it's heavy at 100gms and it's trick to get it fitted inside the frame as it's quite large.
OzzieFlyer is offline Find More Posts by OzzieFlyer
Old Jul 11, 2005, 07:52 PM
ukgroucho is offline
Find More Posts by ukgroucho
ukgroucho's Avatar
Stratford upon Avon
Joined Jul 2004
I have a 3200LF in a 3S. Working better since I shifted to High Governor (from fixed) on the CC35 (thanks Oz.. you motivated me to do that tweak). Performance is respectable... it loops OK (not sure that I do) and I think some mild 3D would be OK even on a 13t.
There is footage of someone doing lunatic stuff on a 15t with that motor - on the Align web site.
4S runs a Neu 1105/3Y.... I guess 4S is part of the difference but it is (most definitely) a different animal. 3D capable without a doubt... my inept thumb fumblings in loops have shown that it will leap around with some enthusiasm.
BUT... you can buy the 3200LF for $42... and a Neu or pretty much any of the 'performance' motors is $80 - $100+...
ukgroucho is offline Find More Posts by ukgroucho
Old Jul 11, 2005, 09:47 PM
dgswheels is offline
Find More Posts by dgswheels
Joined Feb 2005
AON 3500 very happy with this motor on 2100's
dgswheels is offline Find More Posts by dgswheels
Old Jul 11, 2005, 09:53 PM
canadianshark74 is offline
Find More Posts by canadianshark74
581 gram hubdave rex
canadianshark74's Avatar
Acton
Joined May 2005
Mega 16/15/3 - probably overkill for a newbie like me.
canadianshark74 is offline Find More Posts by canadianshark74
Old Jul 11, 2005, 11:24 PM
woots is offline
Find More Posts by woots
woots's Avatar
Houston, Tx
Joined Sep 2004
aveox 2713/3
http://wpenny.rchomepage.com/
woots is offline Find More Posts by woots
Old Jul 11, 2005, 11:54 PM
djdaveq is offline
Find More Posts by djdaveq
I'd rather be flying...
djdaveq's Avatar
New York City
Joined May 2005
im happy with the align 420 with a thunder power 3 cell lithium 2100mah 11.1 volt..LOOK OUT!
djdaveq is offline Find More Posts by djdaveq
Old Jul 11, 2005, 11:56 PM
Philpops is offline
Find More Posts by Philpops
Australia
Joined Mar 2004
the new 450T outrunner kills most setups out there, Im flying this motor on 3s and it beats my other setup 5s 1500mah mega 16-15-5
Philpops is offline Find More Posts by Philpops
Old Jul 12, 2005, 12:16 AM
thomer is offline
Find More Posts by thomer
Off roading with the Fun Cub!
thomer's Avatar
CA
Joined Mar 2003
I bought an Astro 803T (020) that I will be using with a Kokam 3s 2000 lipo. 180-270 watts should be fun with the Trex!
thomer is offline Find More Posts by thomer
Old Jul 12, 2005, 04:33 AM
Crewdogg998 is offline
Find More Posts by Crewdogg998
Crewdogg998's Avatar
Battle Creek Mi
Joined Jan 2005
Aon 3500!!! Crewdogg
Crewdogg998 is offline Find More Posts by Crewdogg998
Old Jul 12, 2005, 04:44 AM
stevenkelby is offline
Find More Posts by stevenkelby
I'll Mace You Good!!!
stevenkelby's Avatar
Adelaide, Australia
Joined Sep 2004
I have a Neu 1105/3Y, probably too much for you.
Sorry by that I mean it really needs 4 cells and more than aCC25, not too much power. In that case its toom uch for me!
I had a 400DH from justgofly.com and they are great, light and cheap.
Phils right, the new 450T is insane. Also light and cheap.
stevenkelby is offline Find More Posts by stevenkelby
Old Jul 12, 2005, 07:48 AM
chris higdon is offline
Find More Posts by chris higdon
rogue_medic
chris higdon's Avatar
portkennedy ,western australia
i have a mega 16-15-4
works well on 3 cells and the biggest pinion in the trex kit
works great on 4 cells and a 13 tooth pinion
chris higdon is offline Find More Posts by chris higdon
Old Jul 12, 2005, 07:51 AM
Jeffro is offline
Find More Posts by Jeffro
Joined Jul 2003
AON 3500 is the best three cell motor I have found for the Rex. I now have it in my XL.
Jeffro is offline Find More Posts by Jeffro
Old Jul 12, 2005, 02:36 PM
TonyTypeS is offline
Find More Posts by TonyTypeS
United States, CA, Hacienda Heights
Joined Jun 2004
I had an Aon 3500 on a 3s setup and climbout was ballistic at only 80% throttle
TonyTypeS is offline Find More Posts by TonyTypeS
Poll What blades are you using on your T-Rex? siavreg Mini Helis 69 Feb 22, 2008 10:56 AM
Discussion What Flightpower Lipos are you using with your T-Rex? Tweeky Mini Helis 5 Jun 25, 2007 07:40 AM
Poll What blades are you using on your T-Rex? siavreg Mini Helis 10 Jun 14, 2006 11:26 PM
What battery are you useing in your t-rex jetspud Mini Helis 2 Dec 27, 2004 12:38 AM
What cells are you using in your Sokols? Jensst High Performance 10 Jul 13, 2001 08:43 AM
