Old Jul 10, 2005, 03:37 PM
Starguard is offline
Find More Posts by Starguard
Going Home
Starguard's Avatar
Mighty Midwest
Joined Apr 2004
Found some 10 year old 15% Nitro fuel. What should I do with it?
Went digging through the closet and found some 10 year old 15% Nitro fuel. What should I do with it?
Starguard is offline Find More Posts by Starguard
Old Jul 10, 2005, 03:39 PM
Viper Pilot is offline
Find More Posts by Viper Pilot
God is good
Viper Pilot's Avatar
Banjul
Joined Jan 2001
Still sealed??? Give it a try.
Read this
VP
Viper Pilot is offline Find More Posts by Viper Pilot
Old Jul 10, 2005, 05:37 PM
gwh is offline
gwh
Find More Posts by gwh
gwh
Fort Worth, Texas
Joined Dec 1996
As long as it has been sealed it should be ok. I've used some 5+ year old fuel with no problems. The $7.95 price on the bottle really got the LHS owners attention.
gwh is offline Find More Posts by gwh
Old Jul 10, 2005, 07:02 PM
Going Home
Starguard's Avatar
Mighty Midwest
Joined Apr 2004
Its been opened. The gallon sized bottle is only 3/4ths full. The price tag is still on it, but its faded so bad that it can't be read.
Old Jul 10, 2005, 07:22 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Use it at the field in the winter time to get the fire in the barrel going..
I'd bought some 50% nitro some time ago to use in a .061 motor.. never got around to running the motor, but did watch the fuel bottle get skinnier and skinnier as the nitro evaporated thru the plastic over the years.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Jul 10, 2005, 08:59 PM
lectraplayer is offline
Find More Posts by lectraplayer
Professional Crasher
Joined Apr 2004
I say give it a try and have some new fuel around. If your old fuel is good, use it up! ...though you may notice better performance off the new fuel once you start getting into it.
lectraplayer is offline Find More Posts by lectraplayer
Old Jul 11, 2005, 05:57 PM
NewbtoRC is offline
Find More Posts by NewbtoRC
Joined Jan 2005
put a match in it
NewbtoRC is offline Find More Posts by NewbtoRC
Old Jul 11, 2005, 08:57 PM
Joined Apr 2004
Originally Posted by NewbtoRC
put a match in it
If you're gonna do that, you might as well put it on a stump. Get some use out of it! Maybe it might be just what you need to get rid of that stubborn stump!
Otherwise, I suggest you see how it does in the engine. The lubricants in it shouldn't be too much concern, though the nitro may be (though nitro mostly only affects the acutal running, as it is the fuel, along with the alcohol). Only really burn the stump if the fuel's a wierd color or if it don't run worth a crap and new fuel runs great.
Old Jul 12, 2005, 11:17 AM
blizzardwarrior7 is offline
Find More Posts by blizzardwarrior7
In Massive Debt
Northampton Massachussetts
Joined Jun 2005
Usually open fuel that is 10 years old wont perform very well. I would burn it also, but dont mention my name when the fire department asks what your doing.
blizzardwarrior7 is offline Find More Posts by blizzardwarrior7
Old Jul 12, 2005, 11:52 AM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
I'd mix a 8 oz. of the old fuel with 8 oz. fresh 15% nitro fuel and run it in one of my engines. If it works as good as 10% nitro fuel, I'll mix the rest of it with the same quantity of fresh fuel and use it. If not - you had some "good" suggestions.
ivanc is offline Find More Posts by ivanc
Old Jul 12, 2005, 04:44 PM
FenceMagnet is offline
Find More Posts by FenceMagnet
Vintage Flyer
Treasure Island, FL
Joined Jan 2002
use it to break in that next engine during the "slobbering rich" stage.... that's what I did with a 15-20 year old jug of FAI fuel.... my Saito 180 broke in just fine....
FenceMagnet is offline Find More Posts by FenceMagnet
Old Jul 12, 2005, 09:00 PM
Joined Apr 2004
That doesn't sound like a good idea to me as it may make break-in a pain, as you don't know how the fuel will even run. I suggest you do break-ins with fresh fuel, and then get it tweaked for performance with that fresh fuel. After you get it rockin', then give it some of the old fuel and see how it runs. If it runs good, burn it up!
Old Jul 13, 2005, 06:32 AM
Vintage Flyer
Treasure Island, FL
Joined Jan 2002
Break-in IS a pain !!!! Even bad, waterlogged fuel will run real rich at part throttle with the ignitor attached.... as long as the engine is getting plenty of lube (i.e. very rich) all it needs to do is spin a while in the beginning.... not for ABC/ABN though !!!
Old Jul 13, 2005, 11:30 AM
Fordplay is offline
Find More Posts by Fordplay
Wheels up!!!
Pelham, Alabama
Joined Jun 2005
Sounds like a good ant killer to me.
Fordplay is offline Find More Posts by Fordplay
Old Jul 13, 2005, 11:48 AM
Z06kal is online now
Find More Posts by Z06kal
DS JUNKY
DA VALLEY, CA
Joined Jun 2004
I've never had success with fuel stored this long. From what I understand the fuel can pull moisture right through the plastic bottle at hte moleculor level. My guess is engine will run very badly and unreliabley if it starts at all. But give it a shot if you don't mind landing dead stick a few times till you figure out its the fuel.
Z06kal is online now Find More Posts by Z06kal
Should I bring my 10 year old to a Shins concert? Mitch G Life, The Universe, and Politics 8 Mar 13, 2005 11:22 AM
Can a 10 year old AeroChopper Program be made to work?? Waldo Pepper Beginner Training Area (Aircraft-Electric) 5 Dec 27, 2004 10:25 PM
New flyer resurrecting a 10 year old trainer out from mothballs. Hello. Iso Octane Beginner Training Area (Aircraft-Electric) 79 Jan 28, 2004 02:59 PM
