Mar 19, 2006, 09:59 PM
Columbus, Indiana
Joined Nov 2004
Ecoliburger,
The rear end NGV is actually two pieces. Well, two pieces plus the vanes. First you make the innner ring which attaches to bearing tube. Careful if you make the bearing tube from aluminum and NGV from stainless. The aluminum will swell with heat if the fit is too tight and will cause damage upon disassembly. Anyway, the inner ring was first turned on a lathe to what I wanted and then put in a rotary table set up vertically on a mill. I then used a hole saw (bi-metal) in a tool holder I made to cut the radial slots for the vanes. THis step takes some experimentation to get the correct angle. Once you find the correct place to cut the radial grooves, cut one then rotate the rotary table for however many vanes you plan on using. The easiest way to form the vanes is to use tubing that is the same size as the hole saw you used to cut the grooves. Cut the vanes out of the tubing on a bandsaw or cut them out with a die grinder. Careful you don't lose the radius of the tubing. Once you have all vanes cut out and de-burred you can weld them into the center piece. Preferably use a tig welder, you really need to control the weld here. After that, chuck the center piece again into the lathe with the vanes out and cut them to match the outer piece. I actually put a little step on the end of the vanes on the OD to fit into slots in the outer piece. **You have to cut the matching slots in the outer piece by hand to fit the center piece with vanes. If you only weld three vanes to the outer housing you should be good. Don't weld all of them as this piece needs to move around with the heat and if it's held by all vanes being welded you risk cracking something. Hopefully you can picture what I did. If not I can take some pics. Here is a sad sad drawing (done by hand) of a cross section of the back end. I'll have to see if I still have my prints laying around and could post them. They may shed some light on this a little more..
The front end diffuser is pretty easy, first turn the backplate center hole to clear shaft, bearing tube fit on back, front side center must be undercut to clear back side of compressor. Take that piece and saw radial grooves ( you can see them well in the third pic on post #6). Then get some aluminum and cut out the vanes oversized, they must be radiused to match slots. I used a slip roll to form mine. Then insert them in the slots and tack weld the back side. Again with tig welder. The next step is tricky. You must turn a blank to fit the bearing tube location diameter on the back side of the diffuser. Don't take it out of the lathe. I used a very low melting pt (~150 degrees F.) bismuth alloy. You can get it at plumbing stores, Mc-master carr, MSC etc. Beware it is not cheap. anyway, melt that and pour it around the vanes so you have a solid block. Then put some foil down on the lathe to catch that stuff, again it's expensive. Turn the OD of the fins to fit both the front end and the canister. You need to match the radius on the back of the front housing to the top of the fins. Then remove from lathe and melt the alloy out. Voila you have a diffuser. Then you need to put some holes in there for the bearing tube to bolt to, and for the front end to bolt to. Again check pic three on post 6. Sounds very easy right....Actually it is a lot easier to do if you could see the part in your hand. It sounds discouraging, but it's not that hard. You could do the diffuser like the one that's on the big turbine on pic 4 post 9. That's a little bit different setup but I can tell you about that if you want. Either way will work. The one in the big turbine needs a lot more machining skill to be done correctly. All the holes you see go through to the front end and three of them are pins that locate the diffuser to the front end. Anyway, if you want I can detail that setup...
Man my fingers are tired....
Hope this helps.
Later...
Martin
