Old Dec 01, 2009, 06:13 PM
Ken Jack is offline
Find More Posts by Ken Jack
Joined Dec 2008
Turbine hybrid
Hi Rich,It is an idear i have had for about 7 years when i was informed that brushless motors are akin to alternators and if this is true it would work very well as they become more efficient at high rpm.Then i found out that full size by-pass turbo fan engines are going this way because it is more efficient than present gearbox use.If so then use of this in models looks very good on paper .Thanks for your interest ,Regards,Ken Jack
Ken Jack is offline Find More Posts by Ken Jack
Old Dec 02, 2009, 09:18 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
Ken. I see no reason why that wouldn't work and sounds like a perfectly good solution to get better performance. actually, you would get better performance on less power than most modern systems and/or be able to run on significantly less battery than is currently available. hmmmmmmmmm. now I'm thinking too. LOL. could be dangerous.
Rich
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Dec 02, 2009, 09:28 PM
Joined Jan 2009
actually, a little off topic, but along the same lines........could you not also do this with an EDF combo too?.........have an EDF efflux driving a turbine driven motor/rotor that drives a bigger bypass fan? or would the efflux of the EDF not be powerful enough to make a power gain for the bypass fan? see, I told you thinking would be dangerous. not sure if that would work or not, but at least the idea in my head sounds like it could. LOL.
Old Mar 03, 2013, 09:48 AM
AirplaneFreak100 is offline
Find More Posts by AirplaneFreak100
as the name says!
AirplaneFreak100's Avatar
Barbados
Joined Sep 2012
was this finished?
AirplaneFreak100 is offline Find More Posts by AirplaneFreak100
Old Jan 15, 2014, 08:28 AM
F15McAir is offline
Find More Posts by F15McAir
Joined Jan 2014
would an aluminum alloy with better high temperature properties, higher stiffness and a lot lower expansion at temperature help make this engine better. I'm retired aerospace structures guy and now work for company that makes metal composites in precision shapes for specialty applications
F15McAir is offline Find More Posts by F15McAir
Old Jan 16, 2014, 12:06 PM
Dr Honda is offline
Find More Posts by Dr Honda
Dr Honda's Avatar
Pittsburgh Allegheny, Pennsylvania, United States
Joined May 2004
not really.
regular aluminum alloy's are fine on the compressor, and diffuser. But... on the "Hot End"... you are looking at temps at 700 to 800 c. Aluminum, of any regular alloy will melt far below that. Inconel is the lest expensive metal that can still operate in those temps.
Dr Honda is offline Find More Posts by Dr Honda
Old Jan 26, 2014, 02:36 PM
morwan_gsm is offline
Find More Posts by morwan_gsm
Joined May 2013
excellent job !!!
morwan_gsm is offline Find More Posts by morwan_gsm
Old Sep 24, 2015, 04:30 PM
Manish9808 is offline
Find More Posts by Manish9808
Joined Sep 2015
Taking Jet Engine Fabrication as college project
Hi,
I wonder if anyone is reading my post here. I'm new here. I and my friends have decided to build a gas turbine engine for our college project. This thread has a lot of information in this regard. I'll be posting my progress here. Hoping for your help and expertise.
Manish9808 is offline Find More Posts by Manish9808
Old Sep 24, 2015, 05:22 PM
xairflyer is online now
Find More Posts by xairflyer
Bleriot's R Us
xairflyer's Avatar
Ireland, Donegal
Joined Nov 2003
hi post away most who have subscribed to the thread will still be getting notifications so look forward to watching your progress and any will help in anyway we can
xairflyer is online now Find More Posts by xairflyer
Old Sep 26, 2015, 07:58 AM
richardC is offline
Find More Posts by richardC
Joined Jan 2007
Originally Posted by Manish9808 View Post
Hi,
Have a look at the GTBA site www.gtba.co.uk - you can get a CD with lots of usefule stuff if you join the gtba.
richardC is offline Find More Posts by richardC
build your own turbine mitchamus Fuel Jet Talk 1 Apr 19, 2003 01:30 AM
Building your own packs?-Need all your help austinelse Batteries and Chargers 8 Dec 05, 2002 09:01 PM
Building your own gearbox? pohlmeyr Power Systems 13 Jan 11, 2002 05:51 PM
