Old Jul 10, 2005, 12:25 AM
flybike is offline
Find More Posts by flybike
Lance Armstrong- 7 times!
flybike's Avatar
Madison, Wisconsin
Joined Sep 2001
Simple Cheap J-250 Pusher- Build Thread & Free Plans
Over the last few months to my surprise the most popular plane on my website has been this little J-250 powered pusher design. That prompted this build thread.
A little history- Last fall I wanted something that was quick to build for using in combat so I came up with this design. They were great fun. Eventually I also taught two people how to fly using them since they are stable and durable. I've built about 10 of these now, in slightly different versions.
It wont 3D and it's not a rocket, but it's a simple, quick, fun to fly little parkflyer.
Free plans are on my website www.pinkfoamplanes.com/cp.html There's AutoCad and PDF versions on there now.
The build thread will follow-
flybike is offline Find More Posts by flybike
Old Jul 10, 2005, 12:30 AM
flybike is offline
flybike's Avatar
Madison, Wisconsin
Joined Sep 2001
Cut two fuselage sides from fanfold foam.
Old Jul 10, 2005, 12:36 AM
flybike is offline
flybike's Avatar
Madison, Wisconsin
Joined Sep 2001
Glue them together.
Old Jul 10, 2005, 12:52 AM
flybike is offline
flybike's Avatar
Madison, Wisconsin
Joined Sep 2001
Here's the tricky part- cut out the wing panels. Feel free to make the wingtips rounded or any other minor changes to the wings- it probably wont affect flight characteristics at all. Now get a mailing tube or something round to bend them on, then heat them up with a heat gun and bend a nice airfoil into the wing panels. You can use the top of the fuselage as a guide.
Once the wing panels are curved nicely you're almost done.
Old Jul 10, 2005, 01:03 AM
flybike is offline
flybike's Avatar
Madison, Wisconsin
Joined Sep 2001
Glue them together. Put a soda can under one wingtip for dihedral. You'll have to carve a little bit of the wing root to make them join nicely.
Old Jul 10, 2005, 01:09 AM
flybike is offline
flybike's Avatar
Madison, Wisconsin
Joined Sep 2001
Build yourself two of these, they will help for the next step. These are really complicated..
Old Jul 10, 2005, 01:16 AM
flybike is offline
flybike's Avatar
Madison, Wisconsin
Joined Sep 2001
Put one of those can towers under each wingtip in this step.
Glue the wings to the fuselage.
Old Jul 10, 2005, 01:18 AM
badaltitude is offline
Find More Posts by badaltitude
badaltitude's Avatar
kentucky
Joined Dec 2003
Looks interesting.
badaltitude is offline Find More Posts by badaltitude
Old Jul 10, 2005, 01:21 AM
flybike is offline
flybike's Avatar
Madison, Wisconsin
Joined Sep 2001
Cut two little braces from fanfold foam. Then glue these in under the wing.
Old Jul 10, 2005, 01:29 AM
flybike is offline
flybike's Avatar
Madison, Wisconsin
Joined Sep 2001
glue in your stabilizer, then hinge the moving parts with clear tape
Old Jul 10, 2005, 01:38 AM
flybike is offline
flybike's Avatar
Madison, Wisconsin
Joined Sep 2001
Glue your motor on to the top of the wing. You might need to glue in some shims to get it level.
The second picture shows the location of the battery.
The idea of this plane is to use old equipment that you dont use anymore, that's why I'm using an old brushed motor and a Gen 1 lipo. I usually use 8 cell nimh batteries for combat just in case they happen to hit the ground..
Old Jul 10, 2005, 01:41 AM
flybike is offline
flybike's Avatar
Madison, Wisconsin
Joined Sep 2001
Well, that's enough for tonight. Tomorrow we'll install the rest of the electronics and go fly. Any questions? Comments, suggestions?
-Hans
Old Jul 10, 2005, 02:35 AM
willin is offline
Find More Posts by willin
willin's Avatar
In my Blu heaven! near Lincoln NE
Joined Mar 2003
another beauty for us to behold and to try. Thanks flybike! ( Hans)
Robert
willin is offline Find More Posts by willin
Old Jul 10, 2005, 08:28 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Looks great and simple, Hans. Love the callibrated blocks for assembly
What's that, a 4025 prop?
Gene Bond is offline Find More Posts by Gene Bond
Old Jul 10, 2005, 09:33 AM
lift off is offline
Find More Posts by lift off
HELL no you cant fly it!
lift off's Avatar
Joined May 2004
Classic flybike. The soda cans I mean!
lift off is offline Find More Posts by lift off
Build Log “STC” Build guide, free plans, and videos! WaterDog Foamies (Scratchbuilt) 4473 Nov 30, 2015 04:04 AM
Twin Boom A/P Slow Stick "Dragon" pusher build thread. CactusJackSlade Aerial Photography 37 Apr 28, 2006 11:07 PM
AP4 my NEW depron Pusher build thread evermax Aerial Photography 54 Nov 04, 2005 11:45 PM
J-3 Cub build Thread fish2keel Scale Fuel Planes 36 Feb 05, 2005 08:53 PM
NEWBIES...Easy Build and Fly...Free Plans... gpw Foamies (Kits) 93 Apr 30, 2003 07:36 PM
