Old Jul 09, 2005, 12:19 PM
martin_uk is offline
Find More Posts by martin_uk
West Midlands, England
Joined Jul 2005
Question
Can i use any brand of Receiver with a Hitec TX ?
Hi, ive got a Hitec Optic 6 TX for my helicopter and am buying a plane shortly and want to know if i have to buy a Hitec receiver for the plane or can i use any brand of receiver such as Futaba?
martin_uk is offline Find More Posts by martin_uk
Old Jul 09, 2005, 12:53 PM
nemonis is offline
Find More Posts by nemonis
Joined Apr 2005
Martin:
You should be able to use any brand PPM (FM) receiver with the Optic 6, as it is capable of shift select (an issue in the US, I don't know about the rest of the world). The only receivers that wouldn't work (assuming same frequency) are PCM receivers made by other manufacturers.
I hope this helps!
God bless!
Wayne J.
nemonis is offline Find More Posts by nemonis
Old Jul 09, 2005, 02:52 PM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
And if martin_uk means you're in the UK (it helps if you fill in your location) then there are no shift problems on 35MHz anyway.
Steve
slipstick is online now Find More Posts by slipstick
Old Jul 21, 2005, 06:09 PM
Joined Jul 2005
Ive now bought my plane and its got a Futaba receiver, ive put my Hitec crystal in the Futaba receiver and tried using my Hitec TX but theres no communication
Do i need to get Futaba crystals to get it to work ? Also im not sure what you mean by shift select
Old Jul 21, 2005, 06:19 PM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
Martin
You need to use a Futaba receiver crystal in the Futaba receiver and a Hitec transmitter crystal in the Hitec transmitter.
You don't need to concern yourself with shift at all, it isn't an issue in the radios in the UK.
leccyflyer is offline Find More Posts by leccyflyer
Old Jul 21, 2005, 06:35 PM
Joined Jul 2005
Ah that makes sense - just thought they had to be the same make. So aslong as both brands of crystal are on the same channel then it should be ok then.
Can I use an AC adaptor with Hitec CG-330? John Webb Batteries and Chargers 8 Feb 16, 2009 02:21 PM
Discussion Can I Use the Berg 7 Receiver with a JR XP6102 newpatch Electric Heli Talk 14 Jan 03, 2007 01:26 AM
Discussion Can I use Berg MS4L receiver with FUTABA T14MZ (PCMG3 2048) 72MHZ Transmitter? sung_ch Radios 1 Jun 05, 2006 08:10 AM
Cen Genesis .46 broken-in but brand new with Hitec tx jet_jer Cars - Cars and Parts (FS/W) 12 Nov 27, 2004 05:10 PM
