Santa Rosa, Northern CA, USA
Joined Oct 1999
Stabs?
Sheez, I think the stabs are all wrong, for the big XC version. First, by proper design the pivot should be at MAC of the stab, actually a tiny bit in front of MAC. (Not at the leading edge!) If you pivot at the LE, you are asking for a major load on the servo. Next, a pin behind this pivot point should control the stabs. Why? With the main pivot in the right place, the stabs will follow the wing. With the control behind the pivot, any slop will make soft controls, not flutter. I think the Sag has too much sweep in the stab to make this work. I also think that dynamic / static balance is a problem. Although it would change the look of the plane, I suggest a proven stab design that does not have these problems. I would also stay with full flying as they trim so well (VS. a fixed tail or T-tail). How about a Falcon 800 Stab (or similar) scaled up to fit your Sag? Use this and a bell crank. Happy Landings, Dave |
Ok; As for motor setup Ill probably go with an Aveox F12 for the main reason that I already have it. I had to steal it out of my Magic sport plane but sacrifices happen
Ive been putting the numbers in Motocalc and from the motors I have it looks to be the most reasonable choice. Ill try to get a couple images of the stab and associated hardware and post them. I had always thought that any fully moving control surface needed to pivot at the cg of the surface itself. Similar to Daves statement about the sweep/pivot point not making for a balanced setup. Adam |
ontario canada
Joined Jan 2002
bellcrank
use a bellcrank and a strong servo,keep in mind that ;its wasnt that the sagitta performed better than most in its class,it was its sweet handling .
if i was you i would question the effects of prop wash on the flying stab i have flown a similiar plane and found that under power the stab responce was very slow,i believe the stab was directly in the wash [shook the stabs loose] it seems a shame to alter the design but maybe its needed,i would hesitate changing anything if its not needed,i would hate to loose the flight charateristics of the sagitta because in my oppion thats what made the xc so sweet! ramair hey adam, i know you have heard me say that before but really ask around,,its like the old paragon,,its not perfect,but its hard to improve on,many have tried!! thermals by itself!!!! |
| Thread Tools | |
| FS: Sagitta XC Glass Fuse | jcstalls | Aircraft - Sailplanes (FS/W) | 0 | Dec 31, 2002 09:59 PM |
| FS: Sagitta XC kit | jcstalls | Aircraft - Sailplanes (FS/W) | 0 | Dec 31, 2002 09:54 PM |
| Move this forum to "Electric Flight"? | jbourke | Ornithopters | 10 | Sep 17, 2002 02:55 PM |
| Sokol - Electric Pylon "101" Questions | BOBWRC | High Performance | 10 | May 06, 2002 01:48 PM |
| FS: 2M Electric Hawk "hotliner" | tufnik | Aircraft - Electric - Airplanes (FS/W) | 3 | Apr 15, 2002 06:36 AM |
