Old Apr 23, 2002, 12:23 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Astro Micro Meter Low Volt Modification
Chuck Haverlah in Thousand Oaks CA figured out how to modify an Astro Micro Meter so it does not consume any power from the source (uses an auxilliary 9v transistor battery) and will operate down to zero volts. Chuck was also kind enough to talk me through the modification.
This modification is very useful for measuring amps, watts, and volts for the battery packs and motors we are often concerned with for our very micro models. For example, a 4-cell NiMH or NiCd pack will drop its voltage below 4 volts pretty quickly undur a load. The Astro Micro Meter officially works at 4 volts and above (in practice it quits at about 3.75v). It also consumes some power from the source. This easy modification solves both those problems.
I've written up the technique with photos and a diagram and put it on my site. Here's the Link.
Regards, Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
FS : Astro Micro Meter model 100 wamdue Aircraft - Electric - Airplanes (FS/W) 0 Apr 23, 2005 10:38 PM
Astro Micro Meter 100 problem? Rod Power Systems 4 Jun 28, 2004 09:07 AM
FS astro 010 w/controller, astro micro meter, astrofierfly w/controler ujr Aircraft - Electric - Airplanes (FS/W) 10 Sep 21, 2003 11:30 PM
WTT: Astro Micro-Meter for Whattmeter JohnM Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2003 09:04 AM
WTT: Astro Micro-Meter for a Whatt-meter JoeR Aircraft - Electric - Airplanes (FS/W) 2 Sep 29, 2002 07:47 PM
