Old Jul 19, 2005, 05:52 AM
Joined Jun 2005
Edp400c
my setup is EDP400c and nicd 7.2V..i read that other than the stock 1080 prop.i can use EP7035 prop...is that ok??the 7035 is a hyper drive prop...
pipercubj3 is offline Find More Posts by pipercubj3
Old Jul 19, 2005, 06:28 AM
Eventually...I will fly
Israel
Originally Posted by GWS4CEO
Pls use a EPS400C D gear drive and EP9050 and GWS 3 cells 1300mAh. ICS480Li.
And tell me what you feel?
Mr. Lin
but is the 400 motor a 6 or 7.2v?
eran_k is offline Find More Posts by eran_k
Old Jul 19, 2005, 07:47 AM
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
We flew under this combination, and sound like BL performance!
Originally Posted by eran_k
Mr. Lin
GWS is not call the motor in that way.
So I am not sure what a EPS400C motor should be called? But if this is from a GWS EPS400C D gear drive power package, just do what I said. match with EP9050HD, 3 cells GWS 1300mAh Li-Po.
Try this way! We flew under this combination, and sound like BL performance! Make your GWS WW-IIs alive from a gentle sheep turn into a wild cat!
GWS4CEO is offline Find More Posts by GWS4CEO
Old Jul 20, 2005, 09:31 AM
Ship first, Improve often
L0stS0ul's Avatar
Virginia
Joined Apr 2005
This setup works great :)
I maidened my corsair last night with the EPS-400C D gear, EP9050HD prop, and 3 cell GWS 1300 Lipo.
WOW was that thing faster than I thought it would be. I did about 2 5 minute flights on the battery at about 3/4 throttle and the battery never even got warm at all. It looked so nice in the air and flew very well even though it was a bit tail heavy. I thought the CofG was at 55mm but with my fat fingers it might have been closer to 60mm. I'm going to move it forward either way.
Great Times.
I posted a video of the maiden in my gallery. The video is not so good due to it being from my digital camera but you can get an idea on the speed. Thing climbs great and is very responsive. I love it.
Thanks for the tips Mr. Lin and what a fun plane to fly and build!
L0stS0ul is offline Find More Posts by L0stS0ul
Old Jul 20, 2005, 10:15 AM
crazy builder
flying_pig's Avatar
San Diego Gillespie Field, California, United States
Joined May 2001
eran k,
i have an e-starter with a simlar setup to the 400 warbirds and i am currently changing from the stock motor (i think its a 7.2) to a zagi 400 which i know to be a 6v motor
i'll post my findings as soon as i can
I'm also considering trying a tuned zagi 400 which has been timed for reverce rotation later
flying_pig is offline Find More Posts by flying_pig
Old Jul 23, 2005, 03:51 AM
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Great Times.
You got it! Glad to hear enjoy the same result like I had!
Wish there will be more Ezoners get this tip apply to there GWS WW-II and Formosa.
Old Jul 23, 2005, 02:10 PM
2948 scale Combat
critter1340's Avatar
Maryland
Joined Aug 2004
I have been flying GWS 400 motors in my Spitfire and Spitzeo for a year now it helps in C/G
Thank you Mr. Lin
I have not seen the P 40 on sale yet.
critter1340 is offline Find More Posts by critter1340
Old Jul 24, 2005, 01:17 PM
Outcast outlaw
As far away from RCGroups and the AMA as possible!
Joined Aug 2004
A slow flier prop? On a warbird?
Red 61 is offline Find More Posts by Red 61
Old Jul 24, 2005, 03:42 PM
2948 scale Combat
Maryland
Joined Aug 2004
Yes, that is all I have. Bags of GWS slow fly
Not running with the big dogs yet
Old Jul 30, 2005, 12:00 PM
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Wish to see more reports about set up GWS WW-IIs to be with EPS400C D gear drive!
Pls share your happy experience here!
Old Jul 31, 2005, 03:29 PM
Confused? Who, me?
Roger Lombard's Avatar
United Kingdom, England, North York
Joined Jan 2005
Well, I got me a 400 D and thought about where to put it bearing in mind it's 50% heavier than the 350. Seemed a pity to weigh down the Zero or the Corsair. Now which warbird needs weight up front?
Right - my ex-350B and now 400D Spitfire is at scramble readiness - tomorrow may see the maiden. I don't have a 9050HD so its got an APC 9075 thin electric.
Roger Lombard is offline Find More Posts by Roger Lombard
Old Jul 31, 2005, 05:43 PM
Outcast outlaw
Joined Aug 2004
The ZERO absolutely needs more weight in the nose.
Old Jul 31, 2005, 06:29 PM
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
You may try EP9050HD for 3 cells, or other similar size prop near 9050.
Originally Posted by Roger Lombard
.... I don't have a 9050HD so its got an APC 9075 thin electric.
As I mention in the beginning how to match the system and props, You may try EP9050HD for 3 cells, or other similar size prop near 9050.
9075 is a little too much heavy in this application.
Overload will make you feel the performance like soft, yet battery energy lost quicker. Unless, the above set up is too hot for you, you may try 2 cells with EP1060HD.
Old Aug 01, 2005, 01:51 AM
Confused? Who, me?
Joined Jan 2005
Sorry Red61 - my Zero has the lightest front end loading of any of my warbirds but it DOES have a little more downthrust than standard and it has the wings reset to the correct AOI.
I'm assuming you've reset your wings?
And thanks Mr Lin, I'll bear your advice in mind
Old Aug 01, 2005, 02:04 AM
Joined Sep 2004
how did you do it?
.................than standard and it has the wings reset to the correct AOI.
How did you reset your angle of attack??? I'm going to leave mine std to take advantage of the "automatic lift" that red 61 has mentioned, but am curious how you adjusted yours; shims??? recarve fuse??? or..... ?.
thx,
LarryR
LareeRudee is offline Find More Posts by LareeRudee
Yippee! How about my old GWS War Birds come with EPS-300C? GWS4CEO GWS (Grand Wing Servo) 10 Oct 30, 2005 10:34 PM
Cool Dose the Formosa have the tenancy to tip-stall like some of the GWS war birds? mike7130 GWS (Grand Wing Servo) 5 Aug 16, 2005 01:48 PM
GWS War birds on 400's ? ctoms Parkflyers 15 Apr 07, 2005 11:37 PM
Question What's the best outrunner combo for GWS War Birds? lookoutbelow Parkflyers 42 Feb 04, 2005 03:35 PM
Alert gws war birds vs alpha war birds? tweissen Parkflyers 18 Aug 07, 2004 10:49 PM
