Old Jul 11, 2005, 01:02 PM
radbradbb2 is offline
Find More Posts by radbradbb2
Janesville,wisconsin
Joined Apr 2005
The only thing i never liked about the kits was the 1mm screws. I have searched everywhere and still don't have a 1mm drill bit. Maybe consider up sizing the screws to a 1.5 mm screw so they would go in very snug with a 1/16 american drill bit.
radbradbb2 is offline Find More Posts by radbradbb2
Old Jul 11, 2005, 01:41 PM
RNAF is offline
Find More Posts by RNAF
RNAF's Avatar
The Netherlands
Joined Dec 2003
Oh yeah, that's rather annoying. It's rather strange though, GWS' planes are fully available in America, but in European countries they're hard to get.. Like Holland. We do use metric...
Anyhow. Would a Speed 400 DD work in a GWS Warbird, like the Spitty? I got a 2 cell 1500 mA pack, which doesn't weigh a lot and could compensate with the heavy motor.
Dave
RNAF is offline Find More Posts by RNAF
Old Jul 11, 2005, 02:02 PM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
Originally Posted by L0stS0ul
I'm about to try this exact setup in my corsair. I bought the slope glider so I could figure out what I wanted as I built it. I think this will be a good setup. All of the parts should be in this week and I'll hopefully maiden this weekend.
Motor/Gearbox - GWS EPS-400C-DS BALL BEARING MOTOR/GEARBOX D GEAR
Prop - APC 10 X 7 SLOW FLYER PROPELLER
Battery - GWS 11.1 VOLT 1300 MAH LIPOLY BATTERY PACK
Speed Controller - CASTLE CREATIONS PIXIE 20P BRUSHED SPEED CONTROL
The propeller seems a little to heavy to 3 cells Li-Po.
I like to suggest you to replace a GWS EP9050HD.
GWS4CEO is offline Find More Posts by GWS4CEO
Old Jul 11, 2005, 02:05 PM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Dave
The propeller can try to use a GWS EP7035 for 2 cells.
However, the larger nose WW-II like Zero, F4U... are not be recommanced for 400DD.
Old Jul 11, 2005, 02:35 PM
L0stS0ul is offline
Find More Posts by L0stS0ul
Ship first, Improve often
L0stS0ul's Avatar
Virginia
Joined Apr 2005
Thanks for the tip Mr. Lin, I'll definitally try out your recommendation
L0stS0ul is offline Find More Posts by L0stS0ul
Old Jul 12, 2005, 06:50 AM
TrevC is offline
Find More Posts by TrevC
Crowthorne, Berkshire, UK
Joined Apr 2002
RNAF
Sorry about the delay in replying to your query, I surf mostly over lunch!
The brushless I used from RCM Direct is a little outrunner. They mention a gearbox in their literature/website, but its hard to see how you would fit one. Anyway, mine's fine as a direct drive with the orange 8060 prop on 2 LiPos. It draws 10A static, and will climb very steeply, but not vertically. 3 LiPos would make it awesome, but I'll stick with 2 as this gives adequate scale performance, around 15 minutes flight time, and is under stressing everything.
Although it was supplied with a GWS adaptor, it wasn't a direct bolt on replacement for the kit motor - I had to saw off some of the wooden "stick". All-up weight is 15oz (about 450g)
Trev
TrevC is offline Find More Posts by TrevC
Old Jul 12, 2005, 10:03 AM
Time Pilot is offline
Find More Posts by Time Pilot
Joined Jan 2004
You should be able to find something like this:
http://www.houseoftools.com/product.htm?pid=58002
If I'm remembering right that there are 25.4mm to an inch, the 0.039 bit is pretty well 1mm.
Time Pilot is offline Find More Posts by Time Pilot
Old Jul 12, 2005, 10:34 AM
RNAF is offline
RNAF's Avatar
The Netherlands
Joined Dec 2003
Yes, 2,54 cm per inch
Old Jul 12, 2005, 02:51 PM
RNAF is offline
RNAF's Avatar
The Netherlands
Joined Dec 2003
TrevC I tried to PM you, but I can't. I'm currently seriously considering a GWS P40 with my Speed 400 plus Direct Drive. Would it fit, or not? I really haven't seen a GWS Warbird up close, so I can't decide for myself if I could fit this motor. Sorry to ask again, but no one's given me a usuable answer (about this motor, that is).
Dave
Old Jul 13, 2005, 07:23 AM
TrevC is offline
Joined Apr 2002
Dave
Not sure if you're asking whether the 400 DD will fit or the brushless I'm using. The brushless with the supplied adaptor should fit, it's quite a small diameter. Bear in mind this is an outrunner, so you'll need some clearance around the spinning can.
I wouldn't recommend a DD 400 - we tried this in my son's Formosa after the kit 370 fried on 8 cells, and performance was very disappointing. It was much better when we fitted the GWS geared 400 with the D gearing. This power unit only costs £10 in the UK.
Is the P40 out yet? If not, I can recommend the F4U - big wing for most forgiving flying performance, big cowling for installing motors, gearboxes etc.
Trev
Old Jul 13, 2005, 08:41 PM
pipercubj3 is offline
Find More Posts by pipercubj3
Joined Jun 2005
Need help on setup P51D
pipercubj3 is offline Find More Posts by pipercubj3
Old Jul 13, 2005, 09:28 PM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
keep airplanes very light when use 400DD config.
I also like to remind you to keep airplanes very light when use 400DD config.
Wish this datas will help:
http://www.gws.com.tw/english/produc...tem/edp400.htm
Old Jul 14, 2005, 03:51 AM
The RC Rat is offline
Find More Posts by The RC Rat
But it wasnt like that b4
The RC Rat's Avatar
Melbourne, Australia
Joined Aug 2004
I just upgraded my Zero from a 370 to 400, kept the same 9x7 prop, C gearing and 2S 1500 LiPo.
It flies a lot faster and powers through wind better, but lost most of its aerobatic abilities due to the added weight.
The RC Rat is offline Find More Posts by The RC Rat
Old Jul 19, 2005, 05:28 AM
eran_k is offline
Find More Posts by eran_k
Eventually...I will fly
Israel
Yesterday i purchased a new F4U, it had a 400 motor, the guy at the store told me it's actually a 6v motor, so i should not use it it with 3S.
Is it true?
Eran
eran_k is offline Find More Posts by eran_k
Old Jul 19, 2005, 05:48 AM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
EPS400C D gear drive and EP9050 and GWS 3 cells 1300mAh. ICS480Li.
Is it true?
Eran
Pls use a EPS400C D gear drive and EP9050 and GWS 3 cells 1300mAh. ICS480Li.
And tell me what you feel?
Yippee! How about my old GWS War Birds come with EPS-300C? GWS4CEO GWS (Grand Wing Servo) 10 Oct 30, 2005 10:34 PM
Cool Dose the Formosa have the tenancy to tip-stall like some of the GWS war birds? mike7130 GWS (Grand Wing Servo) 5 Aug 16, 2005 01:48 PM
GWS War birds on 400's ? ctoms Parkflyers 15 Apr 07, 2005 11:37 PM
Question What's the best outrunner combo for GWS War Birds? lookoutbelow Parkflyers 42 Feb 04, 2005 03:35 PM
Alert gws war birds vs alpha war birds? tweissen Parkflyers 18 Aug 07, 2004 10:49 PM
