Old Jul 06, 2005, 03:53 PM
Gort@69 is offline
Find More Posts by Gort@69
Klaatu . Borada . Nikto !
Gort@69's Avatar
United States, WA, Seattle
Joined Jun 2005
Multiplex Easy Star Thread #21 - what more can I say??
Isn't this where the thread starter waxes eloquently about the plane and how short a time it took the last thread to get over 500 posts?
Anybody that's been reading this forum more than ten minutes already knows what a great reputation it has ..
Anyhow here's how to get to Easy Star Thread #20
PS - for those who have lots of time to kill, the Easy Star Fan Page has a full list of links to each of the old threads thru the Forum tab..
Gort@69 is offline Find More Posts by Gort@69
Old Jul 06, 2005, 04:53 PM
Hammer Head is offline
Find More Posts by Hammer Head
the journey is the reward
Hammer Head's Avatar
Canada
Joined Apr 2002
Repose Q
What sort of time are you guys getting on 1050 mah 8 cell packs and the stock motor when flying as a glider (climb glide as long as you can, climb, glide, repeat)?
HH
Hammer Head is offline Find More Posts by Hammer Head
Old Jul 06, 2005, 05:12 PM
Gort@69 is offline
Gort@69's Avatar
Joined Jun 2005
re-pose my question, too
what are the "tested-and-approved" reinforcements I should make to the Easy Star before I get it airborne?
I seem to recall reading one suggestion - a "barrel wrap" with fiberglass strapping tape.... To me, the term barrel wrap implies a spiral from the nose rearward - yes/no?
Old Jul 06, 2005, 06:00 PM
hunter58 is offline
Find More Posts by hunter58
hunter58's Avatar
the Netherlands
Joined Jun 2005
A list of modifications and reinforcements i have found, remebered and used:
Mods:
  • Canopy mod with tongue and velcro or magnet
  • Reverse rudder clevis and tyrap on fin
Reinforcements
  • Reinforced tape from tail over belley and nose
  • Barrelwrap nose section
  • Barrelwrap motorpod and wingsection
  • Tape frontside of wings
  • Put tape on ground touchingsection at wings
  • Put reinforced tape on wing at the bottom from start to wingtip
That's about it and by no means garantuee you wouldn't have any damage and need elaporsoup
Do not, I repeat DO NOT, interconnect the wings. The wings are designed to releasy from the fuse on highspeed impacts. Connecting the wings either bij tape, velcro or magnets makes the wings more vulnerable !!!
Keep this modification at hand for a later stage.
Ruud
hunter58 is offline Find More Posts by hunter58
Old Jul 06, 2005, 06:09 PM
hunter58 is offline
hunter58's Avatar
the Netherlands
Joined Jun 2005
HH
8 cells 1050 mAh is about 10 Watts. I use 7 cells 1300mAh which is 9.4 Watts.
With this 7 cells and no thermal activity and climbing at 3/4 power maximum I use 2 packs in about 90 minutes. So that makes about 3 quarters of an hour per pack. 8x1050 should be about the same or a bit more, I guess
Ruud
Old Jul 06, 2005, 06:23 PM
Time4RC is offline
Find More Posts by Time4RC
Unconventional
Time4RC's Avatar
Eastern Washington
Joined Jan 2005
Yes - since this is your first RC airplane, and you will likely hit hard a few times, barrel wrapping the nose is a good idea. 3M Extreme packing tape is a good choice.
Next is reinforcing the wings. A line of strapping tape along the bottom or better yet is to CA a strip of carbon tape to the bottom. This will greatly stiffen the wings during those inevitable inadvertant high-g maneuvers that occur while learning.
Those two are my top priority strengthening mods. I also like to stiffen the horizontal stabilizer with carbon tape as the stock setup was prone to flutter during dives.
Time4RC is offline Find More Posts by Time4RC
Old Jul 06, 2005, 06:43 PM
cheymike is offline
Find More Posts by cheymike
No place like cloud base!
cheymike's Avatar
Joined Jan 2005
What sort of time are you guys getting on 1050 mah 8 cell packs and the stock motor when flying as a glider (climb glide as long as you can, climb, glide, repeat)? HH
HH, I use 7 cell 1050's and considering that they are 1050's there isn't going to be a whole lot of difference between the 8 cell and 7 cell packs. My best flight so far was nearly 50 minutes, using some thermals. My average is probably somewhere around 20 minutes. I'm a glider pilot at heart, so I use every bit of lift I can possibly find and I hunt for it constantly if I'm not already going UPPPPPP!!!
Oh.. and I might as well confess... my SHORTEST time was around 6 seconds. DON'T forget to charge your batteries. They might have some residual power left in them and fool you at launch time!!
cheymike is offline Find More Posts by cheymike
Old Jul 06, 2005, 08:37 PM
Stantheman is offline
Find More Posts by Stantheman
Stantheman
LaGrange, Ky.
Joined May 2004
Carbon Fiber Tape
Where can one get carbon fiber tape and how is it applied to the surfaces? Do you just smooth it out and ca it onto the surface? Can it be cut with scissors? A short tutorial please?
Stantheman is offline Find More Posts by Stantheman
Old Jul 06, 2005, 08:57 PM
Canada
Joined Apr 2002
dupe post...system timed out or something...anyhoo...as below
Old Jul 06, 2005, 08:58 PM
Canada
Joined Apr 2002
Hi Mike
Wow that is impressive.
My best so far is about 23 minutes.
We are just coming into 'thermal season' it seems.
How long have you been flying RC and/or electric gliders?
HH
Old Jul 06, 2005, 09:01 PM
Canada
Joined Apr 2002
Hobby shops, Kite shops.
CA will do it.
Scissors is ok for most stuff.
HH
Old Jul 06, 2005, 09:05 PM
Canada
Joined Apr 2002
Ruud
Again, more good duration. Well done.
Man, maybe I just live in the ‘sink’ zone
HH
Old Jul 06, 2005, 10:53 PM
cheymike is offline
cheymike's Avatar
Joined Jan 2005
How long have you been flying RC and/or electric gliders? HH
R/C gliders, about 11 months now.. A GentleLady... electric (EZ* was my first if you don't count the Aspire EP I crashed and trashed on its maiden) about 5 months. Full scale gliders... I've been flying since '84 and have been staring at the sky/clouds for years both before and since learning to fly! There have been many hours spent learning the how/why/when/where of thermal activity!!
Old Jul 07, 2005, 12:20 AM
micsaund is offline
Find More Posts by micsaund
Fort Collins, CO USA
Joined Jun 2005
I took my brand-new ES out for the first time tonight. Had a MUCH better time with it than my previous (very first) plane, the SlowStick.
My very first flight lasted several minutes and I even glid (glided?) it back in for a smooth landing. I was very impressed with the docile qualities of this plane!!!
Mine did have a tendancy to turn right which trim would not really fix - I think my rudder is a tad slanted and not entirely vertical. That's one thing to adjust.
I did coat the nose and tail section with the thinned goop which seemed to help a bit with protection on the couple rough landings I had. I'm not sure I'd do it again as it did react very slightly with the Elapor, but not detrimental.
I plan to make a rudder out of balsa (and an elevator probably) and hinge them on for better flexibility.
Anyway, I will be recommending the ES over the fragile SS to every n00b I talk to - a far better choice, at least in my experience! Thanks for all the help from everyone who posts in these enormous threads!
micsaund is offline Find More Posts by micsaund
Old Jul 07, 2005, 01:08 AM
Canada
Joined Apr 2002
The Ascent is a dog, looks nice hanging on my wall though.
Full scale gliding, very cool.
And yes, you are obviously most learned of the thermal Mike.
HH
Multiplex Easy Star - thread 8 Bad Attitude Foamies (Kits) 493 Aug 01, 2004 05:28 AM
Multiplex Easy Star - thread 7 Zoomzoom Foamies (Kits) 506 Jun 21, 2004 04:40 AM
Multiplex Easy Star - thread 6 Zoomzoom Foamies (Kits) 495 Jun 03, 2004 12:36 PM
Multiplex Easy Star - thread 5 Treetop Foamies (Kits) 503 May 18, 2004 05:47 PM
Multiplex Easy Star - thread 4 jcosta Foamies (Kits) 501 May 03, 2004 05:15 AM
