Espritmodel.com Heli Air
Old Apr 21, 2001, 09:38 PM
Cocoa, Florida
Joined Mar 2001
Reversing Astro .010 motor
Can you reverse this motor by simply changing any two of the 3 wires going to the motor? How about timing?
I want to use this motor as a pusher (Zagi style) on a light 10 oz. foam flying wing .... might use a .020 Astro. Is the .020 with factory esc as easy to reverse? Thanks guys.
injunnut is offline Find More Posts by injunnut
Old Apr 21, 2001, 11:25 PM
Member
Northwest Territory
Joined Jan 2001
According to AstroBob, you are correct. Exchange any two of the wires between the on-off control and the motor.
Lee
El Pe is offline Find More Posts by El Pe
Old Apr 21, 2001, 11:39 PM
Steve McBride's Avatar
Agra, Oklahoma
Joined Feb 2000
Indeed, swap any 2 wires and you are set. As the 010 is sensorless the timing is set by the controller.
The 020 with factory ESC is not easily reversed as it is a sensor type. It would be out of the scope for most of us.
The 010 will work great on a 10 ounce model. In fact I have flown an FMA Razor with one and while the power was lacking, it did fly fine. The 020 would be overkill on a 10 ounce model.
Good luck!
Steve
Steve McBride is offline Find More Posts by Steve McBride
Old Apr 22, 2001, 12:01 AM
Cocoa, Florida
Joined Mar 2001
Thanks Steve, You told me exactly what I was expecting (not necessarily hoping) to hear .... on both counts. ---injunnut---
Astro 010 motor for Hornet lee1010 Micro Helis 4 Dec 19, 2003 08:18 PM
astro 010 motor housing dia? power Power Systems 2 Sep 28, 2003 01:54 PM
WTB Astro 010 motor thor4944 Aircraft - Electric - Airplanes (FS/W) 22 Dec 28, 2002 08:33 PM
WTB Astro 010 motor only 16t MKH Aircraft - Electric - Airplanes (FS/W) 0 Jun 12, 2002 10:52 AM
For Sale: Astro 010 motor Domeno Aircraft - Electric - Airplanes (FS/W) 1 Mar 19, 2002 03:11 PM
