Old Jul 05, 2005, 03:30 PM
littleport2003 is offline
Find More Posts by littleport2003
United Kingdom, Leighton Buzzard
Joined Sep 2004
Can I Run An IPS Motor On 800Mah cells
hi guys
this may sound like a stupid question, but is it ok to run a gws IPS motor on 5 800MAh Ni-Mh cells in serise to give 6volts and will this pack last longer than 5 300MAh Ni-Cd cells in serise?
Thanks MAtt
littleport2003 is offline Find More Posts by littleport2003
Old Jul 05, 2005, 03:45 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Youy can run teh motor, but I seriously doubt the plane will fly...too much weight.
best efficiency would be 10 cells anyway, unless you use the RLC motor..
Old Jul 05, 2005, 03:48 PM
Joined Sep 2004
vintage1 flew her the other day with the nicads it only weighs 5oz but the nicads only last 4mins
Old Jul 05, 2005, 04:02 PM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Go for LIPOS then. And get 45 minutes
I got a very decent 3s pack of 450mA/h cells that should fly easily that long..from weston UK.
You are on a losing wicket with the low voltage heavy metal stuiff. The motors are far more efficient at higher voltages, and you only need about 2A max to fly...if you are flattening 300mAh in 4 minutes you must be pulling over 3A..that will kill an IPS in short order - unless its the RLC motor.
Have a look at www.shaman.co.uk/models/cans/RXC.html
Thats the assembled wisdom of the ezone on IPS running EFFICIENTLY..
Old Jul 05, 2005, 04:25 PM
Joined Sep 2004
I would go for lipos but i realy don't have the money im 15 trying to keep one rc plane flying and paying for microlight lessons at 85 pounds an hour. and lipos need expensive chargers aswell right?
p.s prolly a stupid question, but what the RLc motor?
What would be the cheapest way to get this plane flying for more than 5mins?
please help guys i miss flying my planes
MAtt
Old Jul 05, 2005, 05:57 PM
StCalvin is offline
Find More Posts by StCalvin
ooops
StCalvin's Avatar
Dekalb,Illinois
Joined Oct 2003
All you really need is 6 to 7 cells ( nihms) at around 300 Mah. Depending on the plane you'll get 10 to 15 mins. I fly a 280 motor with 7 cell 300 mah and reguarly get close to 15 mins.
StCalvin is offline Find More Posts by StCalvin
Old Jul 05, 2005, 06:44 PM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
RLC is a hotter wound IPS motor. Works better on lower voltages.
I only paid 19 quid for my 3s LIPO pack. So its not that bad to go LIPOS on IPS.
Your flight times suggest a non-optimum setup - best double check what gearbox and prop you have..?
Old Jul 06, 2005, 03:37 AM
Joined Sep 2004
vintage1 im 15 where the heck am I gunna get 19quid and then i need to get an expensive charger!
Old Jul 06, 2005, 04:16 AM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
dunno. Buy some oil futures?
Old Jul 06, 2005, 04:26 AM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
Matt
Drop me a PM with your snail mail address and I'll stick a couple of 7 cell 250mah NiCds in the post for you if you like. I'm not using them any more and so you're welcome to them. They will fly a GWS Pico Stick for about 7 minutes or so and a 5oz model should be no problem. At the very least you'd get two more flights per session
If you want really long flights in that sort of model then LiPo is the way to go, the old Perkins-distributed 700mah Lions were about the first readily available cheap upgrade over here but there are better alternatives now. Even the old Lion packs would give 45 minute flights with a 10oz IPS-powered model. The JP LiPo charger sells at 16 and is good for up to 3 cells.
Leccy
leccyflyer is offline Find More Posts by leccyflyer
Old Jul 06, 2005, 08:46 AM
Joined Sep 2004
will they be ok
hi
the model with bateries weighs 5oz so will those batteries still be ok?
Thanks MAtt
Old Jul 06, 2005, 08:58 AM
lift off is offline
Find More Posts by lift off
HELL no you cant fly it!
lift off's Avatar
Joined May 2004
If you are going to run an IPS motor on three cell you DANG well better have it in a
"C" gear ratio. Otherwise the motor will last 1/2 a flight.
lift off is offline Find More Posts by lift off
Old Jul 07, 2005, 07:37 AM
isvana is offline
Find More Posts by isvana
Random Flier
Oxford (UK) and Mtn View CA (USA)
Joined Nov 2002
Bah! When I was young... (etc etc)
Errr... doesn't that rather depend on the prop? I think your statement would better read "...you DANG well better know the relationship between volts in, prop, and gearing".
Well, you could always build the charger yourself. And you could always try your local electronics store for discarded batteries: for example, ex-cell phone batteries. Also ex-cell phone Li-Ion chargers. Or a used laptop battery pack. etc etc.
Reminds me of a good idea: a "Cheap" forum for doing R/C on a budget!
isvana is offline Find More Posts by isvana
Old Jul 07, 2005, 08:07 AM
Allan Wright is offline
Find More Posts by Allan Wright
Gambler-AG DLG Designer
Allan Wright's Avatar
Lee, NH, USA
Joined Jun 2001
Find someone who bought these a while back and has upgraded to lipos, you can most likely pick up their charger and several packs (perfect for IPS planes) for a few pounds plus shipping.
http://www.rcgroups.com/links/index.php?id=3929
Allan Wright is offline Find More Posts by Allan Wright
Old Jul 07, 2005, 10:26 AM
BuzzBomber is offline
Find More Posts by BuzzBomber
BuzzBomber's Avatar
Newton, NJ
Joined May 2003
Not to be the voice of dissent here, but I just wanted to offer an anecdote related to the original question. Up until this year, my father was flying a GWS Tiger Moth on the stock IPS motor/GB with an 8 cell 720maH AAA nimh pack. Believe it or not, it flew stronger(better climb) and for longer(20 minutes!) on that heavy brick of a battery than it did on the stock 6 cell 1/3AA nicad pack. That said, I do believe that 7 or 8 cell nimh packs in either 1/3AA (300maH) or 2/3AAA (400maH) are the best CHEAP solution to flying an IPS. The 6 volt pack you mention is not enough, as the others said, but it you had a few more cells, you could probably make something work. If you've any chance to save up a few more pounds, lithium polymer is definitely the choice to make.
BuzzBomber is offline Find More Posts by BuzzBomber
Discussion Can you run a "3cell" motor on 4 cells midrian Power Systems 6 Apr 23, 2007 10:46 AM
Discussion Can I run a Hacker 20-20L on 4-cells? papa38 Power Systems 11 Oct 26, 2006 06:41 AM
How many cells can i run to speed 400 motor? Rizza Flying Wings 3 Dec 10, 2004 09:54 PM
GearBox on an IPS Motor Rogerdoger Parkflyers 26 Dec 16, 2002 10:39 PM
Cool Why can't I burn an IPS motor up??? Model Aero Parkflyers 14 Jan 31, 2002 03:50 AM
