Jul 04, 2005, 10:06 PM
Escondido, ca, usa
Joined Dec 2000
Radio Problems with Trex
I was checking control throws while doing some repair work on my Trex after a crash. I was getting enough forward cyclic control but almost no reverse. I thought I had stripped a servo gear, so changed it and the same problem exists. I then changed the receiver out to a brand new one, and still no difference. I then checked my right and left cyclic and I have more movement in one direction than the other. I thought maybe something was binding, so I checked the servo without the arms attached and it still shows the same problem. The last item I could think of is the transmitter. The transmitter is only a couple months old and I haven't dropped it or hit it hard. The transmitter is an Hitec Optic 6 and the receiver is a Hitec Electrom 6. Has anybody else had this type of problem? Any suggestions? I think this was the cause of my last crash, I went into a turn and it wouldn't pull up or pull out of the turn.
TIA,
Terry Throop
