| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#1 |
zen pilot
help needed on CG for flying wing model
I read some where that flying wing models with reflexed airfoils need to have there cg ahead of the neutral point, like at 15% of the cord. is this right ? my baby blew model is done but i need to balance it , i copied the plan out of a magazine but was unable to get where the cg is,. can any one help?
#2 |
Is it a "plank" type wing? I had built a plank wing with a simitar series airfoil, and the C.G. was at 6% if I remember correctly. I've also heard that the C.G. can be further back, which makes the wing less stable (i.e. you can have it enter a spin).
#3 |
Oz Member
O.K. while we're on the subject, what about Deltas? I'm looking at doing a Mirage, and realise that I will need reflex (Up Elevons) but I don't know where the C of g needs to be. It basically a pefect triangle, so there must be some kind of formula?
#4 |
Most flying wings and deltas are between 15 and 20%
#5 |
zen pilot
it is a plank wing .... so would would 18% be a good starting point? thanks alot in advance .
#6 |
Just built a double tapered combat wing. Just checked the CG. Its right on 18%. Flies likes It's on rails. If it's a symetrical wing follow the bottom contour of the wing for first flight trim. If It's flat bottom try 1/8 in up elevator trim for starters. Good luck and let us know how it works.
Gord |
| Thread Tools | |
| How can I calculate CG for flying wing? | Hermitt | Flying Wings | 8 | Sep 02, 2004 12:38 AM |
| Calculate CG for a flying wing? | Pjotrrr | Foamies (Kits) | 3 | Aug 27, 2003 04:14 PM |
| CG for a rear wing/canard type model | Jim McPherson | Power Systems | 3 | Oct 03, 2001 09:06 PM |
| I think my downthrust is set wrong on my Electric Flying wing, help! | e-sailpilot86 | Beginner Training Area (Aircraft-Electric) | 2 | Aug 08, 2001 02:54 AM |
| Airfoil choice for flying wing, help needed | slowflyer | Power Systems | 14 | Jun 23, 2001 03:20 AM |
