Old Jul 03, 2005, 04:59 PM
Joined Apr 2003
How to mount HS-55 servos to slowstick
The included brackets are way too large to mount HS-55's, how should I mount them?
ch2s is offline Find More Posts by ch2s
Old Jul 03, 2005, 06:33 PM
M0unt@in M0del$ minion
turbojoe's Avatar
USA, AZ, Mesa
Joined Jul 2002
Slide 'em closer together and drill new holes.
Joe
turbojoe is offline Find More Posts by turbojoe
Old Jul 03, 2005, 07:36 PM
Joined Apr 2003
Thnk I just notice there are other smaller predrilled holes for these smaller servos.
Old Jul 03, 2005, 07:42 PM
crashingagain's Avatar
Sacramento
Joined Nov 2003
My 55's fit the existing holes
crashingagain is offline Find More Posts by crashingagain
Old Jul 03, 2005, 07:55 PM
turbojoe's Avatar
USA, AZ, Mesa
Joined Jul 2002
Hmmm. All of my SS's are a couple of years old. Maybe they updated the design in this area to accomodate the smaller servos. I had to drill mine.
Joe
Old Jul 03, 2005, 07:56 PM
Livermore, CA
Joined Sep 2004
I just took a 1" piece of balsa, the same size as the fuselage and glued it to the underside of the fuselage and put the servos on the left and right side, with double sided tape. After I bent my push rods, I noticed it was a bit off, so I removed the servo and put a new piece of tape and stuck it back on to better center the rudder. Butch
Butch777 is online now Find More Posts by Butch777
Old Jul 03, 2005, 08:58 PM
HELL no you cant fly it!
lift off's Avatar
Joined May 2004
LOL! I took a load of rubber bands to mine!
lift off is offline Find More Posts by lift off
Old Jul 03, 2005, 09:41 PM
Outcast outlaw
As far away from RCGroups and the AMA as possible!
Joined Aug 2004
Mine too!
Red 61 is offline Find More Posts by Red 61
Old Jul 03, 2005, 10:58 PM
Whistling Death
RC4ZEKE's Avatar
WA,USA
Joined Jun 2004
I use double sided tape and a couple drops of CA to hold them to the sides of the metal fuse.
RC4ZEKE is offline Find More Posts by RC4ZEKE
Old Jul 03, 2005, 11:13 PM
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
It's been a while since I built a SS but if I remember correctly, the servo mounts have a big and small hole on each side. The small holes will work with the HS-55s but only if the servo mounts are slid on the fuselage tube so the small holes are facing each other.
I've used HS-55 servos on several SS without modifying the mounts.
Pete
PGR is offline Find More Posts by PGR
Old Jul 04, 2005, 12:44 PM
Oldie but goodie
Popsflyer's Avatar
At the Flying field
Joined Jun 2003
There should be 3 sets of holes on the S.S. servo mounts. The ones that fit the smaller servos like HS-55's are very small and can be hard to see. If all else fails, just drill some new holes to fit.
Popsflyer is offline Find More Posts by Popsflyer
Old Jul 04, 2005, 09:38 PM
Mentor, OH
Joined Dec 2004
you have to make sure that the mounts are on the tube correctly. if you look at the bracket, you'll notice that one side has a little more plastic on it (looks like a gusset for strength). these "gussets" face in opposite directions. one way to determine mounting direction is to mount a servo on the bracket before you slide it on the tube. mine came with the little holes so the everthing fit.
sgtdirt is offline Find More Posts by sgtdirt
Reply With Quote  (Disabled)
Discussion does any body know how mucch torqe hs-55 servos have foam and tape Electric Plane Talk 4 Apr 16, 2007 06:01 PM
Newbie Help: Slowstick and HS-55 Servos? kizzy Beginner Training Area (Aircraft-Electric) 22 Oct 11, 2005 01:50 PM
(2) HS-55 servos and (1) Astro 215D ESC shuohan Aircraft - Electric - Airplanes (FS/W) 2 May 06, 2002 06:52 AM
Hitec HS-55 Servos in an LMH Corona? Mark E Electric Heli Talk 9 Nov 19, 2001 07:12 PM
Anybody use HS-55 Servos with the GWS R4-P Receiver? mrebman Parkflyers 9 Sep 22, 2001 05:08 PM
