Old Jun 19, 2001, 10:29 AM
gassyanimal is offline
Find More Posts by gassyanimal
Ft.Gibson, OK
Joined May 2001
Do you run batteries all the way down after each charge?
Do you run batteries down after each charge or just once in a while? Does it change for different types of batteries or does it matter?
gassyanimal is offline Find More Posts by gassyanimal
Old Jun 19, 2001, 10:46 AM
barn buster 50 is offline
Find More Posts by barn buster 50
tyler, texas, united states
Joined Mar 2001
yes. it will keep your packs from developing a memory.
welcome to the zone
barn buster 50 is offline Find More Posts by barn buster 50
Old Jun 19, 2001, 11:39 AM
member73 is offline
Find More Posts by member73
member73's Avatar
Wakefield, MA
Joined Feb 2001
Doesn't this depend on what kind of batteries? Nicads should be run down, but NiMh should not. I could be wrong its been known to happen.
member73 is offline Find More Posts by member73
Old Jun 19, 2001, 11:42 AM
Joined Mar 2001
im not familiar wiht nimh batteries. i assumed you were talking about nicads
Old Jun 19, 2001, 11:50 PM
Look Out! is offline
Find More Posts by Look Out!
Houston/Katy Tx
Joined Feb 2001
Subject is covered plenty in the modeling science section. Many agree that a NiCad(nickle cadmium) battery should be fully discharged(down to one volt)before recharge. NASA discovered the "memory effect" when their NiCads were not exercised. Think of it as a sponge that needs to be squeezed out prior wiping up a spill. Nimh(nickle metal hydride) and Lithium ion chemistries are not as prone to these problems. Bottom line- for E-flight, run your plane 'til it cannot fly. Allow the battery to cool down. Charge your battery and fly again, or store the battery fully charged. Have fun.
Look Out! is offline Find More Posts by Look Out!
Old Jun 20, 2001, 12:37 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
I never run them down other than during flying. I wouldn't worry about a memory effect with the way we use them.
hoppy
hoppy is offline Find More Posts by hoppy
Old Jun 20, 2001, 04:46 AM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
With the new chargers it is not nessesary to run packs to zero after each flight. In fact running packs to zero is what can cause damage, although that is rare now to with the newer cells.
You used to have to run batteries all the way down, just so you knew how much to charge them! Chargers are smarter than us and can charge a dead or half discharged pack now.
Just run as they are and trickle about once a month or so.
Fred Bronk is offline Find More Posts by Fred Bronk
wht batteries do you run in your XE2?? jschick Foamies (Kits) 5 Nov 13, 2003 07:28 PM
What do you guys put all your STUFF in? Ralph_D Parkflyers 23 Sep 18, 2003 02:04 AM
How do you know if the motor is still ok after a crash? Magna Electric Plane Talk 1 Aug 08, 2003 11:00 AM
How do you measure Static Amps? Within 5 seconds of a fresh charge or? rparigoris Power Systems 3 Mar 20, 2003 10:30 AM
What battery do you run on your 400X istrebitelace Foamies (Kits) 0 Aug 11, 2002 02:44 PM
