Old Nov 01, 2005, 12:27 PM
COplanegeek is offline
Find More Posts by COplanegeek
COplanegeek's Avatar
United States, CO, Aurora
Joined Feb 2004
F-27 w/ canard
This is a better quality photo, note the vertical stabs are 4mm coroplast and I ran a carbon fiber tube throguh each, through the wing, into the bottom and out again to act as a skid on the underside.
COplanegeek is offline Find More Posts by COplanegeek
Old Nov 01, 2005, 11:31 PM
crash test dummy is offline
Find More Posts by crash test dummy
Foamsmithing forever!!
crash test dummy's Avatar
Sugar Grove, Il.
Joined Aug 2004
Nice looking camo. I just ran a test on my Stryker with a 5X5 Zagi prop tonight. She is pulling 32 AMPs at 305 watts , my motor is rated at 30 AMPs and 275 watts. Once she unloads it should be ok. She should really move out. I'll find out tomorrow AM.
CTD
crash test dummy is offline Find More Posts by crash test dummy
Old Nov 02, 2005, 06:23 PM
ltownflyer is offline
Find More Posts by ltownflyer
non lottery winner
ltownflyer's Avatar
USA, PA, Levittown
Joined Oct 2005
hello all,
anyone intrested in a futaba flight pac I have one up for bid on ebay auction #6009428329 under my ebay name tmaxximum. On the same line of thinking, anyone know the best way to ship a fully built trainer with a wingspan of 65"? I am having trouble finding a box for it. thanks ltown
ltownflyer is offline Find More Posts by ltownflyer
Old Nov 03, 2005, 01:04 AM
johnandles is offline
Find More Posts by johnandles
adelaide Sth Australia
Joined Jul 2002
confused
Hi,I have too bought a gen 3 ,but am confused at the mountain of info I have read!..What I need to know is whats the census on covering ,I.E. ,glass/polyeurathane/brown paper/pva etc.??
My setup will be..
himark 2815/2000 (same as himax)
30 amp esc,
6x4apc,
3sETEC 1700.
any help
johnno
johnandles is offline Find More Posts by johnandles
Old Nov 03, 2005, 02:45 PM
Sugar Grove, Il.
Joined Aug 2004
johnandles,
I glass mine. However almost any covering will help make a stronger fuse. If you glass be sure to use a .50oz or .75oz cloth to keep it light. I use a slow cure [2 hour] epoxy thinned 50% with alcohol. It is heaver than using Min Wax but it is stronger too.
CTD
Old Nov 04, 2005, 02:32 AM
Joined Jul 2002
Thanks CTD, did you cover top and bottom of the wing and the complete fuz and nose cone?
Thanks again,
johnno
Old Nov 04, 2005, 02:02 PM
Sugar Grove, Il.
Joined Aug 2004
John,
I did the entire fuse but I didnt do the nose. I rapped the nose in yellow duct tape. I did top and bottom cause after I went to brushless speeds, I would wear out a fuse pretty fast from all the bank and yank. The wings would bow up at the wingtips after a while. Spars would work fine, however after glassing you can paint with any paint and it will stick. It's hard to get paint to stick to EPP foam. Also you limited to color if you go with short cuts or another latex based spray paints.
CTD
Old Nov 04, 2005, 02:54 PM
BoboG is offline
Find More Posts by BoboG
If it flies do it!
BoboG's Avatar
Mount Vernon, WA
Joined Oct 2005
Newbie looking for expert thoughts
Good afternoon. It is good to see that other people are looking to get more out of their Stryker. I am new to the site and have learned a lot. After days of reading, and still not finished, I just couldn’t wait any longer to post.
I have had a Stryker for about 4 months now and love it but now I need more speed. I recently found this site but unfortunately after I ordered all the parts listed below.
There is one thing I would still like to do with my Stryker but haven’t figured a way to do it. I would like to know if there is any way to use the combat module with the setup listed below. I will admit that I have not finished reading all the post yet but would love suggestions, advice, or recommendations that everyone can provide.
I will be putting up photos as the build is underway.
*Multiplex BL-480/4D
----Rotor Magnet – Neodymium
----Motor KV (RPM/Volt) – 3250
----No Load – 1.7A
----Maximum Current – 37A
----Maximum Power – 250+ watts
----Maximum RPM – 50,000 rpm
*Castle Creations speed controls (Phoenix-80)
----Continuous 80 amps (I know it is over kill but it is what I have)
----Surge 120 amps
----Resistance 0.001 Ohms
----Weight (with wires) 2.1 oz. (60g)
*Propeller
----APC 5.5x4.5 or
----APC 5.5x7.5
*Battery
----Thunder Power 2100mAh 3-Cell 11.1V LIPO 16GA
*Reinforcement tubes (tubes pulled off old Strykers)
----Pre-installed with stock Stryker body
----2 tubes installed across back wing 18in each
----2 tubes down the length of the of the Stryker
*Elevon
----Balsa elevons
----Nylon Hinges with pin lock
*Fiberglass
----.75 Oz Cloth
----Pacer Z-Poxy 30 min Formula thinned with 25% alcohol
--------2 Layers Leading edge of wing 2 in wide
--------2 layers back of plane for motor mount
*Aluminum clamshell mounts
*Cut vent holes for cooling where they were meant to be
*Created custom hatch set out of fiberglass and nylon hinges
*Hitec Electron 6 receiver
*Hitec HS81 MG (metal gear) servos
*Generation 3 fuselage
This is my second modified Stryker due to being shot out of the sky in the middle of pulling up after a power-dive and cracking the plane just behind the battery compartment, but you should have seen the other guys plane. It’s in about 30 pieces; he didn’t pull up soon enough, too close to the ground I guess. I survived and was still able to fly but don’t think a crack you can see light through is a good thing
Don’t worry the other guy is rebuilding his as we speak.
BoboG is offline Find More Posts by BoboG
Old Nov 04, 2005, 07:52 PM
HienrichDorfman is offline
Find More Posts by HienrichDorfman
"Meters, Mr. Towns..."
Joined Jan 2004
Hooked:
Great info here! After following you guys for a while I bought a blank plug and just used some items I had:
Aveox 27/13/3 direct drive
Phoenix 35
GP 3300 (8)
6x4
Oh my....!
Now I must go faster but don't want to be at the liability end of an "un-guided" missle.
I'm not experianced with glassing. Do you vac bag these plugs or just work it with a trowel, blade etc?
Is there a thread just about glassing?
Hienrich
HienrichDorfman is offline Find More Posts by HienrichDorfman
Old Nov 05, 2005, 12:52 AM
Sugar Grove, Il.
Joined Aug 2004
Phoenix 35
GP 3300 (8)
6x4
Oh my....!
Hienrich
If you look here it will answer all your questions, very good thread.
http://www.rcgroups.com/forums/showt...hreadid=161218
CTD
Old Nov 05, 2005, 01:03 AM
BoboG is offline
If it flies do it!
BoboG's Avatar
Mount Vernon, WA
Joined Oct 2005
Originally Posted by crash test dummy
John,
CTD
As far as painting the EPP foam I have found, through much trial and error that a spray can of “Krylon Fusion for plastic” paint does a very good job at staying put. The paint goes on with ease and if you give it enough time to cure (3 hours or so) you can even get away with using masking tape over it without loosing the paint.
I know this may be a shortcut but it is lighter than glassing the plane and still looks good.
On my plane I used some 400 sand paper, lightly sanded the foam to take out the rough spots and painted. I am not saying you can get an outrageous shine with it but the paint job does look good.
just my 2 cents
Old Nov 05, 2005, 09:35 AM
Sugar Grove, Il.
Joined Aug 2004
BOboG,
I have glassed mine mostly to make it stronger. I don't want to build a new fuse every 3 months and thats about how long it would take until the wingtips started to bow up. I think a spar from wingtip to wingtip would help. I have used latex based spray paint on my Strykers and it looked good. However it would wear off the belly from landings. I used Krylon Kids Tuff, I havn't tried krylon's Fusion.
CTD
Old Nov 05, 2005, 11:43 AM
SPEED-E-FLYER is offline
Find More Posts by SPEED-E-FLYER
INDORUS EXPARAMINTO
SPEED-E-FLYER's Avatar
Springfield, Missouri, United States
Joined Jul 2002
I have a Stryker Carcass hanging on the wall that I'll get to someday.
I have looked thur most of this thread and have not seen a Clipped wing version.
I'm sure it's here somewhere.
But looking at the plane it looks like a no brainier.
Cut the wings where they are glued.
Get rid of those huge twin tail fins and put some smaller winglets.
Anyone do this yet?
Larry
SPEED-E-FLYER is offline Find More Posts by SPEED-E-FLYER
Old Nov 05, 2005, 06:32 PM
SHELBY1 is offline
Find More Posts by SHELBY1
It's me Glacier Girl
Joined Aug 2004
Oh you have one of the old Gen1 versions. I would advise using the Gen2 or 3 versions as a speedster. The 1 is heavier and weaker.
As for cutting down the wings, and installing smaller tail fins.........
You mean something like this?
SHELBY1 is offline Find More Posts by SHELBY1
Old Nov 06, 2005, 10:38 PM
BoboG is offline
If it flies do it!
BoboG's Avatar
Mount Vernon, WA
Joined Oct 2005
My first 3 flights with the lipo went off without a hitch. The 4th flight however something went wrong. Horribly wrong. I was up about 120’ and for some reason lost control of the plane. It headed strait down TWO (Photo below). The plane was basically a stock Stryker with some minor modifications. TP2100, Glassed leading edge and extra carbon fiber tubes along the TE. This is the worse crash I think I have ever had. Time to order a new fuse and radio gear, oh that’s right besides the plane being broken into pieces it appears that the radio gear didn’t survive. It is no longer working. The servos are still good though.
Before and After photos
F-27 Stryker How Far Can You Take It? Part 3 Fred Bronk Parkflyers 560 Jul 03, 2005 02:04 AM
F-27 Stryker How Far Can You Take It? Part 2 Michael Heer Parkflyers 861 Apr 10, 2005 11:02 PM
F27 Stryker...How far can you take it? ChuckD Parkflyers 536 Feb 16, 2005 07:33 PM
Corona: How far can you build, Kit only NewRotorSoon Electric Heli Talk 4 Mar 03, 2003 11:55 PM
Slow Stick on Kokams.... or how long can you take it? Tres Wright Parkflyers 20 Jan 21, 2003 10:20 AM
