Hi Guys,
New Video here: Fast Stryker - Fast Stryker JustGoFly 550TH Motor - Land at your Feet Video Motor in the video is a JustGoFly 550TH Pusher Some mods - Our 3.17mm aluminum L Brackets - very strong - it will not bend without alot of force, aligned exactly on the thrust line 90 degrees - not facing down. At the speeds in the video - my stryker is being torn apart - lots of stress marks and the tape is just not enough to keep the plane from warping. The wooden elevons are good - but balsa is not strong enough - unless you wrap with covering. Strong hinges, and rods. Servos: I like GWS Park HPX Servos which I use in my TwinJet and are 58 oz/in torque - way overkill. But I have never broken a gear and I hate replacing servos due to gear breaks. I don't know if these will fit the stryker, but I will be trying them on my current (next) build. In the video I'm using 30 oz' inch HD1900's. I have found that the cheap HD1900's are strong, and fast but they don't snap to center as quickly as some other servos. I've also found more faulty HD1900's than I would expect in the lot that I have purchased. The S1123's are good, but I am concerned over their 21 oz/in torque. I've not crashed with them, I may focus on the S1123 in my very fast setup since they have always proven to work very well. You do NOT need speedy servos or digital servos. I tried digital servos and they just piss me off when the gears break. They are very precise but metal gear are required and honestly I have not noticed the precision so the cost is wasted on these very expensive digital servos. When the nose breaks - use a FLEXIBLE glue. I use GOOP or Welders. Some of the other glues break and my Stryker nose looks like the older Spock's face. <Tell me you don't know what I mean >I am GLASSING the newest Stryker which is #3 for me. All three still work, but one wing is twisted - you'll have to see subsequent "Fly between the trees" videos to understand why that one is twisted. Me an another guys challenge each other and when he flys between two trees, I have to do it faster, lower and inverted ![]() The second one runs fine as you can see on the video but needs more strength for higher speed. The third will be glassed. If you glass the whole stryker you will add to much weight and make the plane very tail heavy. Glass under the plane, around the complete nose, back to where the lead edge of the wing ends. Glass a strip around the whole tail, where the elevons plug into the foam. And use THICK glass ( I used 5 oz glass) to glass around the motor mount. I use 1.5 oz for the plane, but 3/4 or 1 oz is fine too. I like ALOT of strength used selectively. I use 30 minute epoxy and 50% alcohol added to water it down. This makes it take alot longer to dry, but makes the epoxy more flexible and alot stronger. Re-enforce the motor mount: This motor will rip the whole motor mount area off the plane if you do not re-enforce the motor mount. You can also use BALSA to replace the foam - done by a buddy when we learned about the foam being ripped off due to the torque, and you can use a strip of metal roof flashing - above and a small one below the plane. You need no angle on the motor on this fast plane - mount it on the thrust line - not like the stock mount which mounts high and points down. I can fly six inchs above the ground and slam the throttle and she will remain rock solid level. Balance I use the very very front the the hand hold area - actually just outside the front of the area to balance the plane. This means I dig out the front compartment to push the battery all the way forward. I always glue the nose on the plane. It will break eventually - so what, glue it and go fly again. I have done no re-enforcement of the upright stabilizers. I have been very happy with them, normally I would put a CF strip on each side of them, but be careful adding tail weight. I use 2-56 rods and a Z bender for one side and dubro connector for the other. Clevis's are fine to use as well. Use a little fuel tube over the clevis to lock it closed. I hate plastic clevis's and have broken a few. I prefer the metal ones. Enjoy - the Stryker is a GREAT PLANE ! We're loving it and I find more guys enjoy this as their second plane as an aileron trainer. Usually I'll set them up with the JustGoFly 500T which is infinite vertical and about 80 mph, and show them how to pull back that left stick until they are ready for speed. I don't think the guys I fly with realize how unique a crew of flyers we have. We'll have six 80+ mph Strykers all chasing each other around the sky while we laugh like crazy. I hope this helps, Vinnie |
South Shields, U.k
Joined Mar 2008
Hi guys... havent posted on here before so firstly id like to say hi to all
![]() I usually fly 3d helicopters but recently purchased an F27C stryker for a bit of fun. I ran the setup (30A eflite ESC and stock motor using various 1800 - 2200 3S packs Flightpower/revolectrix/Emax 20 - 25c) for about 8 flights before one of the servos decided to pack in. I then changed out the servos for a pair of Hitec HS5245 MG digital servos so i could be done with it once and for all. I also added a UBEC and disabled the stock Eflite 30A BEC. These are the only things ive changed so far. Now i dont know if its just me but it definately seems slower recently. I have only got about 14 flights on her from new. Could i have burned out the motor already? Also i have got a medusa 28-40-2500 afterburner motor which ive found from an abandonded heli project. If i were to fit this motor to the current setup what should i expect? Would it be okay with the stock 30A ESC seeing im not drawing from it for the servos/RX? If not what would be the best size ESC to use without breaking the bank? What would the recommended prop be for good all round speed/performance? Sorry for all the questions lol Thanks Lee |
My Stryker is not fast enough Help!!!
I'm running a Turnigy 28-35 2700kv motor, Turnigy 40amp esc, 4.5x5.5 apc prop and 3s 2200 lipo. My stryker might be a tad faster than the stock setup. I am wanting speed around 100mph. I don't want to do a bunch of reinforcing, I want to run it on just the foam body with stock spars and elevons. I think I can achieve this keeping speed around 100mph. I am looking for a motor, prop, battey setup that will do the job. If possible cheap, like hobbycity cheap. I will pay up to $50 for a motor if it is worth it. Does anybody have any ideas?? Keeping away from scorpion, e-flite, mega... An off brand that will do the job, preferably.
Please help! |
I can help you out with the speed on a budget.. Sent you a pm
But for starters you will need to add a carbon spar across the motor mount at a minimum for 100 mph. The stock servos and elevons also will eventually fail at that speed. I can get you to 100 mph on 4s for about $136, 3s $126 This is NOT using crappy hobbycity motors. Also this 100 mph will be a flat and level speed.. expect 125 mph+ in dives. The motor you would receive is a 6 pole 100 gram inrunner that is currently not available in the US. I also have a 6s setup that would take 2, 2200 3s packs but would push you over 120 mph. If you have 2200 3s packs that may be a less costly option.
Joined Feb 2008
how about a 120mph stryker?
I have 2200ma 4c batteries (25C) a big fat 60a speed controler. Currently running a 4x4.4 apc on a kontronic Fun 400-28. I draw about 28 amps on the ground. Fuse is fully fiberglassed, painted and re-inforced with carbon. What changs can I make to take it to the next level?
Glad to see more chatter here. I was just thinking this week, "Does anyone else still fly their Strykers?"
I'm having tons of fun with mine. I had it up for 20 minutes with only 7 minutes of throttle today with a few WOT high speed passes and mixed aerobatics. It glides so nice and smooth and yet will turn and burn. I'm still running 3-cell 2200 25C packs so it slows down nicely when landing. |
Seward, NE
Joined Nov 2006
hey skunk,
I was just floating around with my stryker tonight and thought I would check in... I trimmed a tree yesterday with my t-28 but got super lucky and came out of it with no damage. I made the mistake of flying when my dx-7 battery was a little too low I guess. The signal wasn't strong enough to get to the plane when it got just over a bunch of trees. It just quit responding and started gliding down. I heard a click and saw a branch move slightly then the power turned back on and my plane came up from behind the tree. LUCKY!!! SO, I have been thinking about buying a FunJet and can't decide what motor to put in it so I thought about pulling the Stryker motor out and trying it with the FJ... I had a motor from graysonhobby that I bought for a thrust vectoring f-22 (didn't work out) so I thought I would stick it in the Stryker tonight and the results were amazing! I didn't think that little outrunner would be able to perform up to stock stryker standards but I think it might even be a little faster. It is much lighter too so the Struker really performed well. So, now I am not sure what to do but I might move things around a bit... I will never get rid of my Stryker though. It is so easy to fly and so much fun to float around for awhile before ripping holes in the sky. :-) |
| Thread Tools | |
| F-27 Stryker How Far Can You Take It? Part 3 | Fred Bronk | Parkflyers | 560 | Jul 03, 2005 01:04 AM |
| F-27 Stryker How Far Can You Take It? Part 2 | Michael Heer | Parkflyers | 861 | Apr 10, 2005 10:02 PM |
| F27 Stryker...How far can you take it? | ChuckD | Parkflyers | 536 | Feb 16, 2005 06:33 PM |
| Corona: How far can you build, Kit only | NewRotorSoon | Electric Heli Talk | 4 | Mar 03, 2003 10:55 PM |
| Slow Stick on Kokams.... or how long can you take it? | Tres Wright | Parkflyers | 20 | Jan 21, 2003 09:20 AM |
