Old May 08, 2009, 01:46 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
skunkworks2006,
If you battery pack is not stock and you run a motor heat sink, then you can use a little more prop.
I suggest you read this thread...it is not very long:
http://www.rcgroups.com/forums/showthread.php?t=880705
A buddy was going to thoroughly test the stock motor last night, but he didn't have a 3mm prop adapter........Damn....last minute surprise.
If he can borrow that motor again (or keep this one longer), he will post numbers on the above linked thread...it'll have RPMs too. I told him to test up to 37A on ground. At above low 30A draw people better know what they are doing and some throttle control may be required besides heat sink.
KV of stock motor was measured at near 2200KV ...I always knew it was about 2150 KV.
1880 KV value is not real......
I know of one example: on a totally different motor the KV was off by about 500KV.
Im looking for feedback on APC Pylon 6.5X5.0 prop from him and for him to increase the pitch till he gets to 37A. He will start his testing with 6X4 then go up.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old May 08, 2009, 02:17 PM
gotboostedvr6 is offline
Find More Posts by gotboostedvr6
zoom zoom
gotboostedvr6's Avatar
USA, NJ, Mt Laurel
Joined Oct 2007
I run 6x5 on 4s 5000 stock motor.. but it had mods
gotboostedvr6 is offline Find More Posts by gotboostedvr6
Old May 13, 2009, 10:11 AM
skunkworks2006 is offline
Find More Posts by skunkworks2006
skunkworks2006's Avatar
Michigan
Joined Nov 2006
What servos are you guys running in the hot strykers? I have a bunch of the HXT 900's but I don't know if I trust them. HS-81's? Do I need MG's? I don't care to have the best or fastest, but I sure don't want an airborne failure either.
skunkworks2006 is offline Find More Posts by skunkworks2006
Old May 13, 2009, 02:20 PM
GryphonRCU's Avatar
Joined Mar 2008
skunkworks2006,
For piece of mind on a 120MPH strykers even after it hits the ground a few times would be Hitec 81MG or now days hitec 82MG with 10% more torque, 10% less speed....still GOOD speed on servo....both even faster and stronger on 6V.
For 130+MPH Strykers go with Hitec 85 MG.
Gryphon
Old May 13, 2009, 04:22 PM
zoom zoom
USA, NJ, Mt Laurel
Joined Oct 2007
IMO Full size digi or go home. Peace of mind is worth more to me then an ounce of weight
DS-821 FTW
Old May 13, 2009, 06:21 PM
Michigan
Joined Nov 2006
Thanks.
I put HS-82 MG's in it. At least now I don't need to worry.
Old May 13, 2009, 10:50 PM
FoamCrusher is offline
Find More Posts by FoamCrusher
If it floats....sail it!
FoamCrusher's Avatar
Elk Grove, CA
Joined Sep 2002
Originally Posted by GryphonRCU
skunkworks2006,
For 130+MPH Strykers go with Hitec 85 MG. Gryphon
Or if the 85 MG is too thick, a HS-5125MG thin wing digital...but have a thick wallet before you go shopping since they are 2X the price of the 85MG's
Even though the speed and torque are almost exactly the same between the two, to me the digitals just have a crisper, more responsive feel. Couple them with either a Futaba FASST or Xtreme Power Systems XtremeLink 2.4 GHz system with higher resolution on the servo signal (15 bit resolution for the FASST or 16 bit for the XPS versus 8 or 10 bits for the Spektrum) and you get much finer servo positioning and better control. At 100+ mph you need all the control you can get.
FC
FoamCrusher is offline Find More Posts by FoamCrusher
Old May 14, 2009, 02:02 PM
Michigan
Joined Nov 2006
Flew my stryker last night for a brief moment between rain drops.
set-up:
stock (unpainted) body, fins, ailerons, hatch, etc...
stock motor and motor mount
APC 6x4 (for now)
Futaba 4-channel single conversion RX
Super Simple 40amp ESC
HS-82 MG's
Zippy 2200 25C 3-cells
I glued in a carbon strip on edge across the body through the motor mount area, and used some strapping tape over it and the servo's and wires.
I had a short time with it, but long enough to see that I'm going to have a blast with this one. I'll most likely prop up to a 6x5 at some point and may try a 4-cell. But it's pretty fast and has unlimited vertical now. Yet, it stills slows down nicely for easy landings. I can see why this thing has been so popular. Up until now, I was flying a home-built "B-Model" with lipos on the stock brushed motor. It was fun and pretty quick for the park, but nothing like this.
Old May 19, 2009, 02:24 PM
ty_horn is offline
Find More Posts by ty_horn
Philippians 4:13
Seward, NE
Joined Nov 2006
Hey guys,
I have had my StrykerC for a couple years now and have had no probs at all. Love this plane. I would like to know if there is a Hobby City motor out there that will push this plane a little faster though. Anyone out there found one?
ty_horn is offline Find More Posts by ty_horn
Old May 19, 2009, 02:27 PM
ty_horn is offline
Philippians 4:13
Seward, NE
Joined Nov 2006
F-27C model is brushless and does 65MPH stock, and with 6X5.5 APC E prop that will become 72 MPH.
Nice. does this cause any problems with the stock esc or motor?
Old May 26, 2009, 11:47 PM
Michigan
Joined Nov 2006
I've managed to break/crack the motor mount wear the motor screws in place. I got it CA'd back in plqce and put a piece of 3M strapping tape across the top.
Has anyone modified to make it stronger?
I've never had a bad landing on this one (yet) so I don't know why it has happened
Old May 27, 2009, 03:28 AM
GryphonRCU's Avatar
Joined Mar 2008
ty_horn,
The motor is not maxed out with stock setup.
First step is to go to APC E 6X5.5, then the stock 25A ESC and battery will be the bottle necks not the motor.
Read the pages on the following link.
With better ESC, and 3S battery you can go to APC Pylon 6.5" diameter by 5.0 pitch or 5.5" pitch. Take amp measurements and report back.
Install full size heat sink and use full throttle sparingly in the summer.
Have fun,
Gryphon
Old May 27, 2009, 10:08 PM
Michigan
Joined Nov 2006
Any ideas on reinforcing the motor mount?
Anyone? ....Beuhler?....
Old May 28, 2009, 02:03 PM
tashley is offline
Find More Posts by tashley
Aerial Images of Texas
tashley's Avatar
The Texas Gulf Coast where hurricanes come to play
Joined Aug 2003
Read back a few pages and you'll find more than one option for reinforcing the motor mount and or constructing a new mount system altogether.
tashley is offline Find More Posts by tashley
Old May 28, 2009, 02:54 PM
Michigan
Joined Nov 2006
A couple of pics
Here are a few pictures of my Stryker. I may just run a new stock motor mount, but will likely reinforce it with epoxy and an alum. disk.
F-27 Stryker How Far Can You Take It? Part 3 Fred Bronk Parkflyers 560 Jul 03, 2005 01:04 AM
F-27 Stryker How Far Can You Take It? Part 2 Michael Heer Parkflyers 861 Apr 10, 2005 10:02 PM
F27 Stryker...How far can you take it? ChuckD Parkflyers 536 Feb 16, 2005 06:33 PM
Corona: How far can you build, Kit only NewRotorSoon Electric Heli Talk 4 Mar 03, 2003 10:55 PM
Slow Stick on Kokams.... or how long can you take it? Tres Wright Parkflyers 20 Jan 21, 2003 09:20 AM
