Old Jan 18, 2012, 11:30 AM
Vogon is offline
Find More Posts by Vogon
Vogon's fly
Vogon's Avatar
Nottingham - UK
Joined Aug 2004
Windrider A380
Yes, mine is still servicable.
Folk keep trying to show off with their new Hobbyking version, and then I impress them with my grown up model.
Vogon is offline Find More Posts by Vogon
Old Jul 11, 2013, 02:13 AM
Ben_E is offline
Find More Posts by Ben_E
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
I just had to pull the A380 down from the shelf yesterday!!
I'm falling in love with this bird again
Ben_E is offline Find More Posts by Ben_E
Old Oct 26, 2013, 05:17 PM
limodune is offline
Find More Posts by limodune
limodune's Avatar
Australia, QLD, Toowoomba
Joined Oct 2011
I have purchased one of these from Windrider and will receive it this week, the build will include EDF's, flaps, retracts and vinyl and will be flown from a grass strip
Does anyone have an all up weight with EDF's and retracts added, also any suggestion on motor choice would be appreciated
Ben -E that first pic looks great
limodune is offline Find More Posts by limodune
Old Oct 26, 2013, 05:26 PM
Ben_E is offline
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
[QUOTE=limodune;26474738
Mike[/QUOTE]
Thanks! Love this plane :-)
Ben_E
Old Oct 30, 2013, 02:10 AM
limodune is offline
limodune's Avatar
Joined Oct 2011
Wow -- ordered this Friday and it turns up in the post today Wednesday from Hong Kong, thanks Ming for the quick post
I am going to make this with a one piece removable wing like my other airliners, 4 edf's, add full length CF spares, fowler flap's, retracts, light's and vinyl, I am not sure 4 50mm edf's will get it off grass I have no experience with these --something to think about
Old Nov 04, 2013, 02:58 AM
limodune is offline
limodune's Avatar
Joined Oct 2011
After looking back through the posts and video's I thought I would lift up the nacelles for more ground clearance for when the under carriage are added as they seem a little low, I took off 18mm 3/4'' off the top of the pylons keeping the same profile and scribed in the front section so now the pylon meets the center of the wing, I have done this to help with those 'not so good' landings
Old Jul 25, 2014, 01:14 AM
limodune is offline
limodune's Avatar
Joined Oct 2011
Made some more progress with the a380 wings, added some foam pad's and plywood plates for the retract mounts and cut the pockets out for them to park, at the same time cut out an area in the wings for electronics to sit, then cut out and hinged some fowler type flaps and cut pockets that will have hidden servos and push rods, also cut out a grove to take the 6 cables along the wing for the 4 x 50mm EDFs I will use, to finish off a couple of CF strips were added to the end of the wings and ailerons for strength
It was a lot easier to do this working on 2 separate wings than 1 big fixed wing like I have done in the past, next job will be to glue the wings into the belly of the fus and then make the cuts for a 1 piece removable wing
Old Jul 30, 2014, 03:12 AM
limodune is offline
limodune's Avatar
Joined Oct 2011
Just finished the one piece wings
After I cut them from the fus I put a couple of lolly sticks into the wing join for good measure, opened up the bay for the main retracts to park in, and to secure the wings I have put a couple of pins in the front of the wing center that locate into some ply on the fus and at the back its held down with two bolts going in to a piece of ply under the foam with nut serts installed
Last mod is the front retract bay then I can install all the electrics and think about flying it
Old Aug 10, 2014, 01:09 AM
limodune is offline
limodune's Avatar
Joined Oct 2011
Got some more progress done, I made up the plywood plate for the front retract and steering servo , cut it in to the foam and finally glued the fuselage together, then made up the front strut and cut the opening for it, I have got to make up some trucks for the mains then all the fab work is done
I put the wings on the fus and added a battery to test the throws and flaps and took a short vid
Windrider A380 first test of throws and flaps (0 min 28 sec)
Old Aug 27, 2014, 04:02 AM
limodune is offline
limodune's Avatar
Joined Oct 2011
Finally got the front strut installed, the wiring loom made and fitted and all the edf's in, weather permitting I will maiden the weekend
Old Aug 27, 2014, 04:12 AM
Ben_E is offline
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Pulled my A380 off the shelf again and threw it off the cliff
The nacelles are mounted with magnets, and since our landing site is full of trees one popped off whilst trying to reach the ground safely...
No major damage, so it will fly again soon
Love this bird!!!
Ben_E
Old Sep 04, 2014, 11:50 PM
limodune is offline
limodune's Avatar
Joined Oct 2011
Got to the field for a maiden and took my a320 along also, flew the a320 first, then the a380 got a range test and a couple of taxi tests but then the wind got a little blustery and was swinging around some, so it got parked and I will maiden another day
One thing I noticed this aircraft has HEAPS of power on 4s and that is with the throttle pulled back to 75% way more than my a320
Old Sep 09, 2014, 11:44 AM
Metallica2000 is offline
Find More Posts by Metallica2000
Campinas - Sao Paulo - Brazil
Joined Jul 2008
Hi limodune,
nice mod! but, could you list the full setup (Escs, EDF..ect)that you use in this bird ?
thanks!
Metallica2000 is offline Find More Posts by Metallica2000
Old Sep 10, 2014, 04:45 AM
limodune is offline
limodune's Avatar
Joined Oct 2011
ESC 55 amp x 4
EDF Change Sun 4200 kv x 4 on 2-4s batteries 3000 30-40 c
5amp 5v ubeck added (all red wires disabled on the 4 ESC)
Flying weight with batteries 3kg-6 3/4 lb
here are some numbers I got testing the edf in the nacelle, had to add a layer of thin foam around the duct to make them a tight fit, all the fan's were removed and balanced on a magnetic type balancer
2800 mah 30c battery @ 25% -32 amps 400 watts
2800 mah 30c battery @ 95% -42 amps 620 watts
3000 mah 40c battery @ 25% -37 amps 490 watts
3000 mah 40c battery @ 85% -42 amps 620 watts
Old Sep 10, 2014, 06:41 AM
Joined Jul 2008
Uow!
nice numbers Mike!
The EDF size is 50mm ?
Do you have any issues flying this bird ? is Easy as the A380 tiasang?
Thanks again!
Build Log Build & fly thread : WindRider Airliner - Big scale PSS marclr Slope 484 Jul 11, 2013 04:03 AM
For Sale Windrider Airliner - A380 in Qantas livery tyga78 Aircraft - Electric - Jets (FS/W) 0 Dec 10, 2006 06:36 AM
Windrider airliner option Ming Slope 25 Dec 10, 2005 10:31 PM
Windrider airliner option Ming Foamies (Kits) 2 Jul 24, 2005 08:42 AM
