Old Jul 02, 2005, 08:57 AM
pgleich is offline
Find More Posts by pgleich
United States, MN, St Paul
Joined Jun 2005
Tail boom slotting and push rods
Have a Bobolink and need advice about slotting the tail boom for the vertical stabilizer.
Safety? Tools? Surface preparation? Reinforcement after slotting? And while I'm at it... what about putting the the pushrods on the outside of the boom?
pgleich is offline Find More Posts by pgleich
Old Jul 02, 2005, 09:42 AM
Wylie Shaw is offline
Find More Posts by Wylie Shaw
Clearlake, CA. USA
Joined Jun 2000
Push Rods
Hi, Anywhere you make an opening in the CF Boom you weaken it...if you do wrap some nylon or thread around the boom just in front of and back of the openning and glue it with ca...you can take real fine sandpaper 320 and up and just break the glaze then wrap it and glue it....running the push rod sheaths down the boom on the outside is better as you don't have to cut the boom....just warp it every 3 inches or so with nylon thread and glue it with CA ....
Wylie S.
Wylie Shaw is offline Find More Posts by Wylie Shaw
Old Jul 03, 2005, 02:53 PM
MikeHLG is offline
Find More Posts by MikeHLG
London
Joined Apr 2004
I would recommend you do not slot the boom for the fin. Instead, cut two slots in the fin so that it can slot in to the boom. This way you do not weaken the boom and it is easier to get it vertcal IMO.
If you use bondable teflon outer tubing for your pushrods (and I think you should) then you should not wrap with nylon thread as you will crush the tube and add drag to the pushrod. It bonds very well with CA though.
MikeHLG is offline Find More Posts by MikeHLG
Old Jul 03, 2005, 03:48 PM
pitoniakmike is offline
Find More Posts by pitoniakmike
Joined May 2005
Mike,
what source do you use for teflon tubes.
thx,
mp
pitoniakmike is offline Find More Posts by pitoniakmike
Old Jul 03, 2005, 04:33 PM
MikeHLG is offline
London
Joined Apr 2004
Well. I live in the UK and get from http://dlg-supplies.co.uk/
I think you can get it form here http://www.tailboom.com/teflon.php in the States.
Old Jul 07, 2005, 12:10 PM
pgleich is offline
Joined Jun 2005
I appreciate all the ideas. I'll probably slot the boom although the slotless method is intriguing. The Bobolink boom is tapered and that makes me concerned that the stabilizer inside the boom will not bond as securely. Although the pushrod tubes are less attractive on the outside of the boom it seems like they can be attached more effectively reducing flex.
Soarstar tail boom repair help dilbert Foamies (Kits) 5 Oct 09, 2001 03:10 PM
Anybody know where I can get a replacement tail boom? f2racer Foamies (Kits) 2 Sep 12, 2001 09:55 AM
Aileron push rods Eon Beginner Training Area (Aircraft-Electric) 3 Sep 11, 2001 02:24 PM
ELMH Tail Boom Fixing HankF Electric Heli Talk 4 May 27, 2001 12:52 AM
need tips on securing push rods electrohead Electric Sailplanes 3 May 13, 2001 01:34 AM
