Old Jul 02, 2005, 06:36 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
LRK and other larger homemade brushless motors, part II
Continued from part I:
http://www.rcgroups.com/forums/showthread.php?t=200588
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Jul 02, 2005, 08:32 AM
Mr DIY is offline
Find More Posts by Mr DIY
Mr DIY's Avatar
South Africa
Joined Aug 2003
Well ... I am still around watching this thread. At least I am not the person causing possible headaches this time. (LOL)
ProStreetRacer your motor does look interesting. From my experience gained here though, many people have built motors without a metal bell (used ali instead) only to discover a fair improvement when replacing the ali with ferrous material.
What you are saying is certainly going against the flow. Have you tried a metal bell yet for comparison?
Brian
Mr DIY is offline Find More Posts by Mr DIY
Old Jul 02, 2005, 11:28 AM
Art Newland is online now
Find More Posts by Art Newland
CD-ROM Junkie
Art Newland's Avatar
United States, WA, Bellingham
Joined Apr 2001
PSR, Thanks for the info, would sure like to hear about current and the voltage you are using. A question about the multistrands of fine wire, does this help the motor to be better? Or are you using it for another reason? I've used 2 and 3 strands, usually because I needed larger wire than I had on hand, certainly found it easier than single of large gauge to wind.
Art Newland is online now Find More Posts by Art Newland
Old Jul 02, 2005, 06:04 PM
t-turley is offline
Find More Posts by t-turley
Joined Mar 2001
t-turley is offline Find More Posts by t-turley
Old Jul 05, 2005, 03:30 AM
JoshT is offline
Find More Posts by JoshT
Bigger is better:)
Huntington Beach CA (USA)
Joined Jul 2005
Help
im building a very large motor and i have some questions. my first question is for the can of the motor i thought about using a coupler for copper pipe. i know that copper isn't magnetic but would it still work. maybe if i put a flux ring around the outside of it? anyway if it will work the ID of it is 55mm and i was planning on using 2mm thick magnets so i figure that i will need a stator that is about 48mm in diameter. that would give me about a .7mm airgap right. oh the copper coupler is 2mm thick. my second question is where can i get a stator that is 48mm in diameter and about 40 to 50mm tall? i think i might have a drill to rip apart tomarrow but i dont think the stator will be big enough in diameter. oh yeah im building this motor for an electric boat and im looking for something around 1000W maybe less im not sure right yet still working on the boat so idk how much thrust i need to get from the prop yet. any input or help would be greatly appreciated.
thanx in advance
Josh
JoshT is offline Find More Posts by JoshT
Old Jul 05, 2005, 03:49 AM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
mmmm
Dont use the copper between the magnets and the flux ring ,it would be the same result if you were to increase the magnetic gap by the same thickness,to answer your other question regarding the need of a flux ring of iron,yes a motor will work without it, but it will be drawing more amps and much less efficient.
olmod is offline Find More Posts by olmod
Old Jul 05, 2005, 05:12 AM
arx_n_sparx is offline
Find More Posts by arx_n_sparx
Dismembered Member...
arx_n_sparx's Avatar
Niagara Falls/Toronto area
Joined Dec 2003
Josh: I think most guys work the motor the other way. You find the stator, THEN you worry about finding/making the bell........
Brad
arx_n_sparx is offline Find More Posts by arx_n_sparx
Old Jul 05, 2005, 06:07 AM
ProStreetRacer is offline
Find More Posts by ProStreetRacer
Joined Jun 2005
Art,
I use 3 Li-po cells, @ 2100 mah and 12c, 21-25 amp draw continuous. As for the multi strands, I have always had good results using multi strands, even back in the old days of wiring up brushed motors. I do remember that the Kalt Helicopter used a motor that had one big wire in it and it was very efficient, lasted a long time on a charge and made good power. The helicopter was a piece of s#!t, but the motor was cool. And yes, you're right about winding the multi strands, they are much easier to wind !!!
ProStreetRacer is offline Find More Posts by ProStreetRacer
Old Jul 05, 2005, 07:02 AM
Joined Feb 2001
Litze/multistranded wire has no advantage, see message 8764 "Litz wire revisited ":
http://groups.yahoo.com/group/lrk-to...64?viscount=30
And
http://www.torcman.de/peterslrk/Skin-Effekt.html
Old Jul 05, 2005, 07:04 AM
Joined Feb 2001
Originally Posted by JoshT
im building a very large motor and i have some questions. my first question is for the can of the motor i thought about using a coupler for copper pipe ...
Iron. Not stainless steel, wood, carbon, epoxy, glass, copper, aluminium. Just plain iron. More tips and tricks, homepages, manuals. Tests and checks may save you from frying your controller. Thread is active, bookmark it for future refence and subscribe to it:
http://www.rcgroups.com/forums/showthread.php?t=240993
A 1000Watt diy motor:
http://www.rcgroups.com/forums/showthread.php?t=333317
Vriendelijke groeten Ron van Sommeren
e-motor building tips & tricks
diy outrunner discussion group
int. E fly-in & diy outrunner meet, August 28th, Nijmegen, the Netherlands
Old Jul 18, 2005, 12:15 PM
t-turley is offline
Joined Mar 2001
I have decided to have another crack at this motor from post 1 of the original thread. I've done a lot more reading, and have been encouraged by the success of the same motor on the Powerditto site. I don't quite understand some of the translation, though, in particular:
"Are interconnected the windings as with 2 successively wound 12N/14 P (with distributed coil) to be then parallel switched. That means:
AabBCcaABbcC AabBCcaABbcC
And then the red and the blue group of coils phasenweise parallel.
For the prevention of asymmetries and circle stream it empfielt itself to manufacture the parallel connection additionally also at each "jump" (Aa-aA)!"
I think I get the gist of the parallel connections, but what is the advantage? And what does the last sentence mean?
Tony Turley
Old Jul 18, 2005, 07:07 PM
Joined Feb 2001
To prevent circulating currents it is advised to make the parallel connections in more than one place.
Old Jul 19, 2005, 02:41 PM
latrans is offline
Find More Posts by latrans
Joined Aug 2004
Found something interesting the other day in an old compaq tapedrive machine of some sort. There were two large brushless motors of about 60mm - 70mm diameter and maybe 10mm in height, each have 18 teeth. What makes these different is that the teeth are arranged so that they point inward towards a circular magnet ring that is about 25-30mm in diameter. Essentially they're big inrunners similar in configuration to ones that I've found in small hard drives. I know that this is nothing ground breaking but I've never found any of this size before and was just wondering if anyone thinks that they might be useful.
Latrans
latrans is offline Find More Posts by latrans
Old Jul 19, 2005, 04:18 PM
Joined Feb 2001
diy inrunner from hard-disk:
http://www.cenara.com/users/ce00359/LRK220.htm
LRK and other larger homemade brushless motors t-turley Power Systems 627 Jan 16, 2006 06:07 PM
LRK and other larger homemade brushless motors: Part 2 Mr DIY Power Systems 156 Jan 03, 2005 10:48 AM
"Effecient homemade brushless motors Show Case" jlm0924 Power Systems 1 Jul 13, 2004 07:31 PM
larger homemade brushless t-turley Power Systems 10 Jan 04, 2004 01:44 PM
FW Ta 400, 4.35m, six lrk-torquemax diy homebuilt brushless motors Ron van Sommeren Scale Kit/Scratch Built 0 Jan 13, 2002 02:52 PM
