Old Jul 01, 2005, 07:48 PM
cwdance1 is offline
Find More Posts by cwdance1
Joined Mar 2005
Pin out for Compaq PS4060 power supply?
I want to use this to power a charger and can't seem to find the any information on what the voltage output is on this power supply. Please HELP.
Thanks in advance
cwdance1 is offline Find More Posts by cwdance1
Old Jul 02, 2005, 12:55 AM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
http://www.nfdc.net/home/cbdb/12%20V...r%20Supply.htm
dacaur is offline Find More Posts by dacaur
Old May 27, 2011, 03:27 PM
Doramius is offline
Find More Posts by Doramius
Joined May 2011
I know I'm drudging up an old thread, but the link is dead, and I really am having trouble finding this pinout.
Doramius is offline Find More Posts by Doramius
Old May 28, 2011, 01:01 AM
dacaur is offline
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
Got this from the waybackmachine..... (http://wayback.archive.org/web/)
http://web.archive.org/web/200503191...r%20Supply.htm
The pic you need should be this one:
Old Sep 22, 2011, 05:44 PM
etraud is offline
Find More Posts by etraud
United States, TX, El Paso
Joined Apr 2009
Hi all,
cwdance1, were you able to use this power supply for the chargers?
if so, could yuo please share? I found one on an old server, looks powerful!
THANKS!
etraud is offline Find More Posts by etraud
Old Oct 13, 2011, 07:55 PM
guuber is offline
Find More Posts by guuber
Joined Oct 2011
Compaq Proliant PS4060 (298581-001) Pinouts.
Hello,
To start with I'll warn you that I am not certain that the following procedures to get the PSUs running are in any way harmful to them or not. Having said that, I have tested both procedures without harming my PSUs.
I have managed to get them running both with and without the redundant PSU back-panel from the server they were built for.
These back panels don't have a lot of sophisticated chips on them but the PCB seems multi-layered and not too easy to reverse-engineer. I have not been able to find schematics for them either.
Doing a quick check I found out that with run with the back-panel, the 12V output gave 12,5V while run the way shown in the picture below it gave 13.2V. The 3V and 5V outputs gave the same voltages with or without the back-panel (3.8V and 5.7V)
I have only seen the 3 PSU back-panel version (single and double PSU models exist as well) and on those you bridge the following to start the PSUs:
Pin 13 in the J1 connector to ground
Pin 14 in the 44pin connector to ground
By the way, the picture linked earlier in the thread isn't from a PS4060 at all.
Hope this helps someone. My reason for digging into this was because I needed a PSU for a PC and had 4 of those laying around from a overclocking project that never got finished, 6 years ago.
Cheers!
Guuber
guuber is offline Find More Posts by guuber
Old Jul 08, 2015, 08:45 AM
lx_gadjet is offline
Find More Posts by lx_gadjet
Joined Jul 2015
in a Compaq (298581-001) just connect pin 13 and 24 to "common"(B1 , B2 , B3)
lx_gadjet is offline Find More Posts by lx_gadjet
Old Dec 03, 2015, 10:43 AM
Fuyutsuki is offline
Find More Posts by Fuyutsuki
Joined Dec 2015
Originally Posted by guuber View Post
Hello,
Cheers!
Guuber
I can't see the pic! I really need to know how to start and use this psu, it's for testing car amps, what should I jump with what?. Please if you're so kind show me some schematic.
Thank you!
Fuyutsuki is offline Find More Posts by Fuyutsuki
Help! Pin out for the Electric Power 3s1P 2200 mah Lipo bolarobric Batteries and Chargers 10 Feb 07, 2006 08:30 PM
Advice for a good field power supply Ogre Batteries and Chargers 23 Dec 26, 2005 10:34 PM
Anyone Out There Have A Decent Power Supply For Sale or Trade? KZZ Aircraft - Electric - Airplanes (FS/W) 5 Jun 02, 2003 01:45 PM
For Sale Pyramid Power Supply Joe Elston Aircraft - Electric - Airplanes (FS/W) 7 Mar 21, 2003 08:01 PM
Malibu Lights for inexpensive 12v power supply Keitha Batteries and Chargers 3 Dec 12, 2002 01:40 PM
