Old Jul 01, 2005, 02:14 PM
Lutin is offline
Find More Posts by Lutin
Montreal St. Hilaire, Canada
Joined Feb 2002
LensRc motors what the diffence between a 15t,17t and 25T
Hi all
would like some info on the diffence between a 15t, 17t and 25t CDrom motor
and the 20mm and 22.7 mm size motors
must be simple but....
thank you for your help
paul
Lutin is offline Find More Posts by Lutin
Old Jul 01, 2005, 02:20 PM
headless is offline
Find More Posts by headless
Does anyone hear a cat?
headless's Avatar
Tallahassee, FL
Joined Sep 2003
www.lensrc.com shows specifications on each of the motors you inquired about
for example, the page about the 17t 22.7 motor says:
Recomended Setups:
With GWS 8x4 Direct Drive Prop
at 7.2 Volts
7600 RPM
5 Amps
10 Ounces of Thrust
35 Watts
With GWS 7x3.5 Direct Drive Prop
at 10.5 Volts
12500 RPM
4.3 Amps
11 Ounces of Thrust
44 Watts
whereas the 15turn 22.7 motor page says:
Recomended Setups:
With GWS 8x4 Direct Drive prop
at 7.2 volts:
6.3 Amps
11 Ounces of Thrust
RPM 8100
With GWS 7x3.5 Direct Drive prop
at 10.5 volts:
5.8 Amps
13 Ounces of Thrust
RPM 13700
headless is offline Find More Posts by headless
Old Jul 01, 2005, 03:46 PM
Lutin is offline
Joined Feb 2002
ggg thank you headless
this is stupid of me.... i did not see that i could go to a spec. link on each motors
Thank you
sorry about that guys
Discussion what is the diffrence between outrunning motors and inrunning motors nashiem Electric Motor Design and Construction 5 Aug 19, 2007 08:19 PM
What is the difference between these motors? louisd Power Systems 1 Sep 27, 2005 02:24 PM
What is distance between foci of elipse for lift generated by wing? stevenfrancis2000 Power Systems 1 Aug 06, 2001 10:04 AM
What is the difference between JR and Hitec servos foam_man Beginner Training Area (Aircraft-Electric) 1 Jun 25, 2001 07:38 AM
What is the difference between the Jarma480 & the Multiplex480? Scott C Electric Plane Talk 1 Jun 20, 2001 07:32 AM
