Thanks for clearing that up. I did read posts 1&2. I'm not ready to try making my own packs just yet. I guess I was under the impression that the little Cell Saver did charge the cells individually. That is what gave me the idea to use these as a way of paralleling several batteries at a time using the Cell Savers and it would "sort of" balance all of the cells at the same time, though I'm not sure it would work that way. I know the times I've used the Cell Saver and then measured the cells afterward, they were all exactly the same voltage. I only have one of them right now, but if this will work, I would buy more. Between my son and I, we will have several batteries going on the chargers all day at the field. Perhaps I would just be better off doing it the way I do now and just get a couple more cell savers. I have enough chargers to charge three packs at a time. Blessings, Terry |
Naperville, IL
Joined Jul 2005
Joined Jan 2002
Actually, it's best to start with single LiPo cells, not conventional packs.
With conventional packs you have a point - after you've got all the adapters you need for all packs, and provided no cell fails in a pack. There's no easy way to replace a failed cell in a conventional pack. Most of LiPo failure cost comes from having to replace a pack where a single cell in it has failed. That would be fine, if LiPos were a buck a cell, but they aren't. - RD |
| Thread Tools | |
| Lipo gets cold while charging | Mark Gund | Batteries and Chargers | 18 | Mar 27, 2010 06:53 PM |
| Multiplex 3s2p 4000 mah LiPo pack - charging/balancing? | AntonL | Batteries and Chargers | 11 | Feb 01, 2005 10:10 PM |
| Are LiPo changing size while charging? | Bocaben | Batteries and Chargers | 1 | Oct 31, 2003 03:35 PM |
| LiPo pack balancing poll | RD Blakeslee | Batteries and Chargers | 13 | Sep 16, 2003 02:28 PM |
| Charging a car battery while charging my pack? | Vertical | Batteries and Chargers | 18 | Aug 01, 2003 10:25 PM |
