Joined Jan 2002
While the pooh-poohers nit-pick about "the masses" and big pack problems; please, the folks using simple 2 and 3-cell packs: bear in mind that the disclosures in the first two posts of this thread represent an easy, simple and cheap solution to problems which have arisen with series-charged packs.
Chinese cells, 8C 2000 mah, are now readily available @ ~ $10 per, Sermos connectors are among the least expensive, and a safe, reliable 3S 2000mah pack can now be built for less than $35. An important advantage of parallel charging is that cells matched by medicine men are not required. - RD |
Kansas
Joined Sep 2003
Brian |
Joined Jan 2002
But as you know, manufacturers COULD make a foolproof system for “the masses”: http://www.rcgroups.com/forums/showt...ies+discharge+ - RD |
I'd like to add another caveat against parallel charging. Not that there's anything wrong with it in theory, but in practice problems can creep in.
I modified a PC PSU to set the output to 4.2v on the 5v line, and added a variable current limit that I could adjust to suit the number of parallel charged cells. It worked fine and can deliver 45A, but I became concerned about the actual charge current each cell might receive. There's no easy way to be sure every cell is connected properly when you have say 10 cells in parallel. On 3 only cells this is naturally less of a worry. It's obvious that for each missing cell the current increases to the rest. Also depending on your charging harnesses resistance paths some cells may charge more quickly. If you terminate the charge early you may increase the likelihood of imbalance developing. If you leave everything until the charge current has tapered to a low value then I suppose that is less likely. In contrast in a series charging system it is obvious if a connection is faulty - there's no charge current! As you might tell from my moniker I'm a relative newcomer to electric flight and I'm still developing my own charge strategies. I've decided I'd rather build a series charger that can monitor each cell via taps and taper the charge current if any cell requires voltage clamping at 4.2v. The tapering is only to minimise clamping power dissipation during any equalisation charge. I think this is a reasonable compromise of simplicity/complexity as against building say 6 or 7 individual isolated single cell chargers in one case. It is unlikely to result in increased charging times except when equalisation is required, and then only dependent on the degree of imbalance. Regular use should mean this is minor. It also means my series packs can be fully soldered with short, low resistance leads and the pack only needs a pair of heavy duty dis/charge leads, and a light duty ribbon for tap monitoring/equalisation. Hopefully this sort of pack construction will become more widely available in the future. What do you think? It's for my 5s3p packs. -- Steve |
Arlington,VA USA
Joined Jan 2001
The perfect solution:
Use 1P packs!
![]() I made this almost 4 years ago. AUW: 2.2 oz. ....now all I have to do is make this work for my helis and I'm set! All kidding asside, parrallell charging has it's place. Many on this forum will find the info in this thread usefull. It's nice to have several technical options to choose from, each with their own unique positive/negative merrits. Pullin' |
And why would you since you are on the verge of selling yet another
lipo balancer on the market..... Quote:
Joined Jan 2002
Thanks, Rhett
"Us Folks" has gone 'round and 'round, again. Returning to the first post: "There’s nothing new in any of this. It’s repeated here, because newbies to LiPos may not know about it and because recent discussions of LiPo charging apparatus have been dominated by means for electronic balancing during series charging, even for small, 2S and 3S packs, which comprise most of the market." - RD |
Joined Jan 2002
- RD |
It's hard to shed the lazy habits garnered over many years regarding charging NiCd/NiMh. I really want a system that I can plug together with a pretty good expectation that the packs will be safely charged with no further checks. I'm more discliplined at home but at the field there's lots of distractions and I'd like a little more assurance I haven't slipped up. Safety aside, these packs are expensive!I do find these discussion interesting though. I think I'll go ahead and build my own charger. I'll probably just finish when a commercial offering apears! -- Steve |
RD, it is always good to see your posts on this alternative charging method. It is ideal for 3-cell packs which I would imagine are the most widely used. It is too bad that one of the major manufacturers have not offered a dedicated charging system like this for 3 cell packs. It really just comes down to making a good connector that would make it "idiot proof".
John |
Joined Jan 2002
Right on, John.
A prototype, using Multiplex six-pole plugs, has been built: http://www.rcgroups.com/forums/showthread.php?t=236246 That thread is also referenced in post #6. - RD |
| Thread Tools | |
| Lipo gets cold while charging | Mark Gund | Batteries and Chargers | 18 | Mar 27, 2010 06:53 PM |
| Multiplex 3s2p 4000 mah LiPo pack - charging/balancing? | AntonL | Batteries and Chargers | 11 | Feb 01, 2005 10:10 PM |
| Are LiPo changing size while charging? | Bocaben | Batteries and Chargers | 1 | Oct 31, 2003 03:35 PM |
| LiPo pack balancing poll | RD Blakeslee | Batteries and Chargers | 13 | Sep 16, 2003 02:28 PM |
| Charging a car battery while charging my pack? | Vertical | Batteries and Chargers | 18 | Aug 01, 2003 10:25 PM |
