Espritmodel.com Heli Air
Old Jun 29, 2005, 04:19 PM
Poland
Joined Sep 2003
F/F Timer
Hi everyone.
I'm from Poland and I'd like to build 5inch wingspan Wilga for electric power.
I'm looking for schematics of little timer for my model.
I found picture of timer like that, but there i no word about schematic.
Help me guys. Pleaase.
P.S.
Sorry for mistakes.
sebbur is offline Find More Posts by sebbur
Old Jun 30, 2005, 08:47 AM
JMP_blackfoot's Avatar
Birthplace of Aviation
Joined Jul 2003
I think it is detailed here :
http://www.aeronutz.flyer.co.uk/FFTimers.html ?
JMP_blackfoot is offline Find More Posts by JMP_blackfoot
Old Jun 30, 2005, 10:24 AM
peter frostick's Avatar
south shields. England
Joined May 2004
sebbur
I have just started playing with these timers to freeflight test a model built for future Plantraco RC guidance! If you make the capacitor 22 Mfd, and the leak resistor 270K, the motor runs for about 15 seconds before starting to slow down --- (this assumes you are using an IRLM 2502 mosfet?) Doubling the resistor value will I hope! double the run-down time; so a one meg resistor value should be good for about 35 seconds.
As the mosfet chosen has such a low gate voltage requirement, a quick connection of the yellow coloured swith on the diagram is enough to initiate the motor run sequence.
This is the the simplest use of the timer circuit, and so does not need a "voltage injector" circuit to set the duration --- the injector circuit can of course be used to fine tune the flight duration if you need more precision!!
I would recommend a tiny pcb (as drawn) to give the Fet a bit of heat-sinking, as it is not designed to be a controlled resistor --- for a single Fet 300 ma should be OK as absolute maximum current!
Good luck with the project
Regards Peter
peter frostick is offline Find More Posts by peter frostick
Old Mar 08, 2006, 12:49 PM
Joined Aug 2004
Peter Frostick,
Thanks for posting this little timer. I tried it out and it works great.
With IRF540 N channel mosfet, 100uF cap, and R=940K, the motor run time is about 20secs. But IRF540 is a dip type with heat sink …… so really heavy.
With IRLML2502, 47uF cap and R=1M, the motor run time is 53 seconds.
IRLML2502 is the only surface mount component on my PCB.
My timer at present is aprox 0.8 grams.
I still have to find a 1M SMT Resistor and also a 47uF SMT cap, that should make it lighter.
Raj
Raj Quest is offline Find More Posts by Raj Quest
Old Mar 13, 2006, 07:40 AM
Joined Aug 2004
Just finished the timer posted by Peter, added a Li-poly battery monitor.
100uF cap, 1M resistor, and an LED are "dip" type while others are SMT components. Weight is 0.95g and motor run time is 80secs.
Raj.
Old Mar 16, 2006, 09:57 PM
Wilga
Sounds like a very cool idea. I build Free Flight rubber power and I've never tried electric. A rubber powered Wilga would be a good project too. Maybe a peanut scale?
How will you build your Wilga? I have a small 3-view. (See the attached file). If you have better plans I'd like to see them. Do you have reference materials? Photos?
Best of luck!
Tom
buildawyvern is offline Find More Posts by buildawyvern
Old Jul 31, 2006, 01:38 PM
mr badwrench's Avatar
Joined Mar 2006
Hi, Ive been toying with micro Planes using a 1/64th scale RC car electronics for control. I was wondering If someone could lay out a circuit similar to your timer for me. I know what I need it to do but I drew Comicbook pages instead of paying attention in Electronice class So I dont know how to make the circuit.
I was wondering if you timer coulde be wired to run for 5-10 seconds every time it gets a signal from the RX??? this way I coule get a little more creative with my flying and controller setup...
mr badwrench is offline Find More Posts by mr badwrench
Old Jul 31, 2006, 05:45 PM
Joined Mar 2006
hey, I found something similar. I guess I just need to know what to look for.
http://www.rcgroups.com/forums/showt...02#post3817279
some nice schematics and drawings. with this I could gently pulse the power button and the motor would run constant even if there was RF interference causeing it to lose signal you would still have smooth power untill you stoped pulsing or signal was lost completly.
Old Aug 17, 2006, 01:26 AM
Joined Aug 2004
I just read this thread
Raj Quest do you have any photo from this pcb? i really want to try it
one more question, at what voltage the MAX flashes the LED? from MAXIM's data sheet they say 2.5-3.3V
Raj.
orck is offline Find More Posts by orck
Old Aug 30, 2006, 05:00 PM
billystiltner's Avatar
United States, VA, Clintwood
Joined Nov 2002
Peter
That is some really awesome changes to that circuit.
About 15 seconds runtime is all you really need when testing out new models in the living room. Any longer and the plane would probably hit the ceiling.
Thanks for sharing your circuit and parts layout.
Billy
billystiltner is offline Find More Posts by billystiltner
Old Aug 31, 2006, 07:30 AM
Registered Billy
Louisville, KY
Joined Dec 2003
I have built a couple of these as shown on the Aeronutz site and they work nicely. To keep the time consistent the voltage injected to the cap has to remain constant. In other words, as your motor battery voltage drops, the cap takes less time to discharge. The Aeronutz site also mentions using a separate injector battery to avoid this problem. The circuit also has a trim pot to make precise adjustments to the voltage/time. Nice and simple. I'm working on a simple design to try these out with as well. If it comes to fruition I will post it here.
Brian
bkopke is offline Find More Posts by bkopke
F.F.X. Foam Fighters PanzyPoof Electric Plane Talk 712 Jun 23, 2003 10:40 AM
New website for F.F.X. Park Fighters Ken Manuel Scale Electric Planes 6 Jan 22, 2002 11:12 PM
Harbor Freight F/F E-planes: Thomas B Indoor and Micro Models 7 Jan 13, 2002 09:24 PM
F.F.X. Foam Fighters PanzyPoof Foamies (Kits) 6 Nov 19, 2001 10:22 PM
elect F.F. power source vizslafiver Electric Plane Talk 5 Jul 31, 2001 10:57 AM
